Integral of Sqrt of (49-4x^2) and Differentiating Answer
In summary, the student attempted to solve for x using substitution and differentiation but ran into errors.
ana111790
42
[tex]\int\sqrt{49-4x^2}[/tex]
I have done the integration to the best of my ability. My teacher requires that I differentiate the answer to get back to the original integrand. Can someone please check my work and help me along with the differentiation?
U substitutions, and double angle formula ((sinx)^2=1/2 - (cosx)/2
[tex]7\int\sqrt{1-(2x/7)^2}[/tex]
cosu=2x/7
-sinu du=2/7 dx
u=arccos(2x/7)
Integral Rewritten as:
[tex]\int[/tex][tex]7\sqrt{1-cos^2}* -7(sinu)/2 du[/tex]
[tex]7\sqrt{1-cos^2}= sinu[/tex] therefore:
=[tex]-49/2\int(sin^2u)du[/tex]
=[tex]-49/2\int(1-cos^2)/2 du[/tex]
=[tex]-49x/4 + 49(sinu)/2 + C[/tex]
=[tex]-49x/4 + 49(sin(arccos(2x/7)))[/tex])/4 + C[/tex]
Differentiation:
[tex]-49/4 + [49(cos(arccos(2x/7))]/(4 \sqrt{1-(2x/7)^2}) * 4/49[/tex]
=[tex]-49/4 + (2x)/(7\sqrt{49-4x^2})[/tex]Does this make sense at all?
How can I get to the original integrand given [tex]\int\sqrt{49-4x^2}[/tex]
Careful, the square root sign always returns the positive root
[tex]\implies \sqrt{\sin^2(u)}=\left\{\begin{array}{lr}\sin(u), & \sin(u)\geq 0 \\ -\sin(u), & \sin(u)\leq 0\end{array}[/tex]
For this reason, [itex]\cos(u)=\frac{2x}{7}[/itex] is a poor choice of substitution.
Here, there is another error; [tex]\int \cos^2(u) du \neq -2\sin(u)[/tex]
How do you suggest I solve it? I have literally spent days on this problem and I'm still lost :(
Try integration by parts instead.
Edit there is a little trick necesary, so show me what you get after applying integration by parts once, and I'll help you from there
I have tried Integration by Parts and it seems to never end.
I separated the integrand into 2 fractions, by multiplying top and bottom by sqrt(49-4x^2) to get:
49/ sqrt(49-4x^2) - 4x^2/(49-4x^2)
The 1st fraction I can integrate easily, the second I used Integration by Parts so that:
u=x^2
thus du=2x
dv=1/(1-(2x/7))
v=7/2 * arcsin(2x/7)
I kept doing IBP up to 5 times, and could not get an answer.
According to the book the answer should be xsqrt(49-4x^2) + 49/2 arcsin(2x/7) + C
u=x^2
thus du=2x
dv=1/(1-(2x/7))
Hmmm... why not just use dv=dx and u=sqrt(49-4x^2)...what do you get after applying IBP once like this?
ana111790 said:
u=sqrt(49-4x^2)
du = -4x/(sqrt(49-4x^2)
dv=dx
v=x
According to the rule: Integral of udv = uv-Integral of vdu
x*Sqrt(49-4x^2) + integral of [4x^2/(Sqrt(49-4x^2)]
Good :smile:... now comes the tricky business; let's call your original integral [itex]I[/itex]:
[tex]I\equiv \int \sqrt{49-4x^2)dx[/tex]
What happens if you add and subtract 49 to the numerator of integral of [4x^2/(Sqrt(49-4x^2)]?:wink:
Yes,
[tex]\int\frac{49}{\sqrt{49-4x^2}}dx=\int\frac{49}{7\sqrt{1-\left(\frac{2x}{7}\right)^2}}dx[/tex]
You forgot to divide by that 7
Welcome:smile:
hum... sqrt(sin^2(x))=abs(sin(x)). in trig substitutions, as far as i know, we almost always take the triangle to be in the first quadrant, so i don't think we should be so particular about this.
so sqrt(1-x^2)=cos(t) when x=sin(t) . here i prefer that x is vertical instead of horizontal.
cos^2(x)=(1+cos(2t))/2 and the result should follow. i think this was what the op was looking for.
1. What is the integral of sqrt(49-4x^2)?
The integral of sqrt(49-4x^2) is equal to (1/4)(49x - 2x^3) + C.
2. How do you differentiate sqrt(49-4x^2)?
To differentiate sqrt(49-4x^2), you can use the chain rule and the power rule. First, rewrite the expression as (49-4x^2)^1/2. Then, take the derivative of the outer function (power rule) and multiply it by the derivative of the inner function (chain rule). This will result in the derivative of sqrt(49-4x^2) being equal to (-2x)/(2sqrt(49-4x^2)) or -x/sqrt(49-4x^2).
3. What is the graph of the integral of sqrt(49-4x^2)?
The graph of the integral of sqrt(49-4x^2) is a curve that starts at the origin and increases towards positive infinity as x increases. It has a maximum point at x = 0 and then decreases towards negative infinity as x continues to increase.
4. Is the integral of sqrt(49-4x^2) defined for all values of x?
No, the integral of sqrt(49-4x^2) is not defined for all values of x. It is only defined for values of x where 49-4x^2 is greater than or equal to 0. This means that the integral is defined for x values between -7/2 and 7/2, as sqrt(49-4x^2) becomes imaginary for values outside of this range.
5. How can the integral of sqrt(49-4x^2) be used in real-life applications?
The integral of sqrt(49-4x^2) can be used in various real-life applications, such as calculating the area under a curve, finding the arc length of a curve, and determining the work done by a force. It can also be used in physics and engineering to solve problems involving velocity, acceleration, and displacement.
