- #36
A.T.
- 3,470
Events can be simultaneous, not locations.cfrogue said:My problem with this method is that this causes the x locations in O, x and -x to be simultaneous in both O and O'.
These equations do not describe two events in each frame, they describe all events on the light cone in each frame. The derivation by atyy only shows that all events on the light cone in one frame will also be on the light cone in the other frame, after LT. But It says nothing about whether two simultaneous events on the light cone will still be simultaneous after LT. Just because they both still are on the light cone, doesn't mean that they still have the same t-coordinate.cfrogue said:Thus, ct = +-x and ct' = +- x'.
Correct. I show this in post #30cfrogue said:They are in relative motion and therefore, the two points cannot appear synchronous to both frames.
cfrogue said:The goal is to use x' and -x' which will be struck by the light sphere at the same time in O' and then prove the corresponding x values in O are not synchronous by using the standard LT translations.
That is what I did in post #30, but I just swaped O and O', and instead of x and -x I express the positions in the syncronised frame as cT and -cT, where T can be any value.
A light sphere has a fixed center in every frame.cfrogue said:Then, I would like to figure out how a light sphere will have a fixed origin in O while at the same time also have a moving origin in O located at vt based on the necessary conditions of the light postulate for O'.
