Forced evaporative cooling in high humidity conditions
In summary, the individuals in the conversation are discussing alternative methods of cooling in a hot and humid environment without using energy-intensive air conditioning. They consider the effectiveness of evaporative cooling with a wet towel and fan, and the transfer of heat from the body to the towel or water. They also question the outcome of using a fan to blow water off the skin in high humidity.
oem_odm
hello all,
We live in a hot part of the world with the extra bonus of high humidity - around 90%. We don't have A/C, and don't really want to get it (energy use).
Evaporative cooling won't do much (towel on head) becuase of water saturation in air. Would a cold wet towel + fan force water to evaporate from a hot body (taking heat with it)?
thanks
Well if the towel starts off cold, you'll transfer more heat initially while you warm it up. And a fan always helps.
thanks Russ - I've seen you contribute to loads of peoples threads.
I like to have confirmed some general comments to which yes or no could be added by someone in the know...(Russ... :-p):
1. If the water on the towel is cooler than the body temperature, heat will transfer from the body to the towel. As the towel heats up, the transfer rate will slow down. Once the towel reaches the same temperature (or close) of the body, the transfer of heat will stop.
2. Would cool water on the surface of the skin, have the same effect. I'e, transfer heat from the body to the water (heating it up)?
3. If cool water does work, and it gets warmed up by the body, in high humidity the water would stay on the skin...and would only evaporate off the skin if done by a fan...(forced off).
4. If forcing water off the skin in high humidity works with a fan, blowing water off the skin - where does the blown off water go if the air is already at 90% humidity? - does it blow off on to the nearest adjacent surface... or go where ever the fan blows it?
thanks... :-)
1. What is forced evaporative cooling?
Forced evaporative cooling is a type of cooling technique that uses the natural process of evaporation to lower the temperature of a space. It involves passing hot, dry air over a water-saturated surface, causing the water to evaporate and absorb heat from the air, thus cooling it down.
2. How does forced evaporative cooling work in high humidity conditions?
In high humidity conditions, the air already contains a lot of moisture and is less likely to absorb more. Forced evaporative cooling still works by adding moisture to the air, but the cooling effect is reduced since the air is already saturated with water vapor.
3. What are the benefits of forced evaporative cooling in high humidity conditions?
Forced evaporative cooling can still provide some cooling relief in high humidity conditions, as long as the air is not fully saturated. It is also a more energy-efficient and eco-friendly option compared to traditional air conditioning systems.
4. Are there any disadvantages to forced evaporative cooling in high humidity conditions?
One major disadvantage of forced evaporative cooling in high humidity conditions is the potential for mold growth. The added moisture in the air can create a breeding ground for mold, which can be harmful to both the cooling system and the occupants of the space.
5. How can the effectiveness of forced evaporative cooling be improved in high humidity conditions?
To improve the effectiveness of forced evaporative cooling in high humidity conditions, it is important to have proper ventilation and air circulation. This allows the cool, moist air to be pushed out and replaced with drier air, creating a more efficient cooling process.
  • Other Physics Topics
13K
