Increasing the volume of solution lowers experimental error?
In summary, the conversation discusses the use of different volumes of HCl solutions to determine the rate law for a reaction with Mg. The person was told that using a larger volume of the HCl solution diluted in water would provide more accurate results. This is because the larger volume allows for more surface area for the reaction to occur, resulting in smaller relative uncertainty in volume measurements. However, it is important to note that using a measuring device with a larger absolute uncertainty is not advisable.
Macroer
28
This was part of a lab i preformed to determine rate law for HCl and Mg.
50 mL of 0.5M, 1M, 1.5M and 2M HCl solutions were made using water and this was used with Mg ribbon to find the rate law. The same 0.5M, 1M, 1.5M, 2M HCl solutions were made in 100mL solution that contained water. I was told that the 100mL solution of HCl diluted in water provided more accurate results, than the 50mL solution of HCl dilluted in water. I was wondering why this is the case?
Don't have that great an idea, but the increased volume of solution provides more surface area for reaction, therefore greater results?
What happens to the relative uncertainty in your volume measurements when you use larger volumes?
(Note this also depends on the absolute uncertainty your measuring device produces. Switching from a 10 mL volumetric pipet to a 1000 mL beaker to measure volume is not advisable!)
This wasn't the case as the same measuring device, with the same scale was used in both 50mL and 100mL
Correct. Now if you measure 50 mL and 100 mL quantities on the same measuring device, the absolute error is the same for both sets of measurements. Which set of measurements will have the smaller relative error and why?
I would say that increasing the volume of solution can potentially lower experimental error because it allows for a larger sample size and more accurate measurement of the reaction. When dealing with small volumes, even small errors in measurement can have a significant impact on the results. By increasing the volume, the margin of error decreases and the results become more precise. Additionally, increasing the volume can also help to reduce any potential systematic errors that may occur during the experiment, such as uneven mixing or temperature fluctuations. Overall, increasing the volume of solution can lead to more reliable and accurate results in experiments.
1. What is the relationship between increasing the volume of solution and experimental error?
Increasing the volume of solution can help to lower experimental error. This is because a larger volume of solution allows for more accurate measurements and reduces the impact of any errors in measurement.
2. How does increasing the volume of solution affect the precision of an experiment?
Increasing the volume of solution can improve the precision of an experiment. This is because a larger volume allows for more data points to be collected and reduces the impact of any outliers or errors in measurement.
3. Can increasing the volume of solution eliminate experimental error entirely?
No, increasing the volume of solution cannot eliminate experimental error entirely. While it can help to reduce the impact of errors, there will always be some degree of error in any experiment due to factors such as human error or equipment limitations.
4. Are there any downsides to increasing the volume of solution in an experiment?
Increasing the volume of solution can lead to longer experiment times and increased costs for materials. Additionally, if the solution is diluted too much, it may impact the accuracy of the results.
5. Is it necessary to increase the volume of solution for all experiments?
No, increasing the volume of solution is not necessary for all experiments. It is important to consider the specific needs and goals of each experiment and determine if increasing the volume of solution will be beneficial in reducing experimental error.
9K
