Orbital velocities in the Schwartzschild geometry
In summary: Yes, it is very wrong.From the correct equation \frac{d^2\phi}{ds^2}=0 you should obtain (no surprise):\frac{d\phi}{ds}=constant=\omegaThe trajectory is completed by the other obvious equationr=R=constantYou get one more interesting equation, that gives u the time dilation. Start with:ds^2=(1-r_s/R)dt^2-(Rd\phi)^2 and you get:\frac{dt}{ds}=\sqrt{\frac{1+(R\omega)^2}{1-r_s/R}}or:\frac{ds}{dt}=\sqrt{1-r_s/R}\sqrt{1-\frac{(R
  • #71
espen180 said:
Doing that produces the same result as putting the conditions into the general geodesic equation.
Provided you derive the correct equations of motion. So far, you have gotten the wrong ones.
  • #72
espen180 said:
After reading post #27, the similarity between the Newtonian expression and the one I arrived at makes it very difficult for me to believe it is incorrect. It also predicts that the photon sphere should be at r=3GM. Post #48 seems to confirm my belief here.
I tried to use the same approach to derive the coordinate acceleration of a particle dropped from rest at r relative to a stationary observer also at r. The result was
[tex]\frac{\text{d}^2r}{\text{d}t^2}=-\left(\frac{GM}{r^2}-\frac{2G^2M^2}{r^3c^2}\right)[/tex]
which goes to 0 as r approaches the Schwartzschild radius, I'm unsure what to make of that. It also changes sign when r<2GM, so I doubt its validity in that region. Still, it approximates the Newtonian expression at large r, differing only by about 1.4 ppb at Earth's surface.
Does it look correct? If neccesary, .
No, it is not correct.
  • #73
espen180 said:
I'll post my derivation:
Starting with the general case
[tex]\frac{\text{d}^2r}{\text{d}\tau^2}+c^2\left(\frac{r_s}{2r^2}-\frac{r_s^2}{2r^3}\right)\left(\frac{\text{d}t}{\text{d}\tau}\right)^2-\left(\frac{r_s}{2\left(1-\frac{r_s}{r}\right)r^2}\right)\left(\frac{\text{d}r}{\text{d}\tau}\right)^2-\left(r-r_s\right)\left(\frac{\text{d}\theta}{\text{d}\tau}\right)^2-\left(r-r_s\right)\sin^2\theta\left(\frac{\text{d}\phi}{\text{d}\tau}\right)^2=0[/tex]
impose [itex]\frac{dr}{d\tau}=\frac{d\phi}{d\tau}=\frac{d\theta}{d\tau}=0[/itex] to obtain
[tex]\frac{\text{d}^2r}{\text{d}\tau^2}+c^2\left(\frac{r_s}{2r^2}-\frac{r_s^2}{2r^3}\right)\left(\frac{\text{d}t}{\text{d}\tau}\right)^2=0[/tex]
Dropping the term in [tex]\frac{dr}{d\tau}[/tex] is what introduces your error.
Now I argue that since [tex]v=0[/tex] initially, and the particle and observer are per assumption at the same location in space-time, [tex]d\tau=dt[/tex], giving the equation in #50.
This is wrong as well. Try using the metric I posted for you.
  • #74
Yeah, I got
[tex]\frac{\text{d}^2r}{\text{d}\tau^2}=-\frac{GM}{r^2}=\frac{\frac{\text{d}r}{\text{d}t}}{1-\frac{2GM}{rc^2}}[/tex]
  • #75
starthaus said:
If [tex]\frac{dr}{d\tau}=0[/tex], what does this say about your differential equation? Do you still have a non-null [tex]\frac{\text{d}^2r}{\text{d}\tau^2}[/tex]?
kev said:
Yes.
starthaus said:
You realize that this is mathematically and physically impossible?
espen180 said:
A particle cannot have an acceleration if it has zero velocity?
starthaus said:
[tex]\frac{d^2r}{d\tau^2}=\frac{d}{d\tau}(\frac{dr}{d\tau})[/tex]
What does this tell you? You and kev are starting to worry me.
espen180 said:
The condition was that that [tex]\frac{dr}{d\tau}[/tex] was momentarily zero, not constantly. We are talking about free fall here.
starthaus said:
... Third off, you are mixing an initial condition ([tex]\frac{dr}{d\tau}|_{\tau=0}=0[/tex]) with the general condition [tex]\frac{dr}{d\tau}=0[/tex]. You are using the general condition (i.e.[tex]\frac{dr}{d\tau}=0[/tex] everywhere) in order to drop terms from your differential equation. You have done this error before meaning that you don't understand differential equations.
The radial motion problem was already solved in another thread. I already showed kev the solution for this problem.
Dear starthaus,
Since you seem to have a very poor grasp of the most elementary physics, let us go back back to Newtonian physics and review the basics.
Consider a ball thrown vertically upwards. To a good aproximation, if the ball is not thrown too high, the acceleration is 9.8m/s. At the apogee (the maximum height of the ball's trajectory or even more basically when the ball stops going upwards and starts falling back down again) the average velocity is zero or in the infinitesimal limit the velocity is momentarily exactly zero. At this point [itex]dr/dt = 0[/itex] and the acceleration is non-zero ([itex]d^2r/dt^2 = 9.8[/itex]m/s. If the acceleration was zero at the apogee the ball would remain at its maximum height and not fall down again. You can experimentally prove that this is not the case in your own back garden.
Now in the Schwarzschild metric dr/dt=0 means the vertical velocity of the test particle is momentarily zero at a given instant. (Recall that by definition dt means and infinitesimal interval of time - Please review an introductory textbook on calculus if you have forgotten this basic fact.) Setting dr/dt=0 says nothing about the motion of the particle in the next instant or in the previous instant. Therefore setting dr/dt=0 in the metric does not by itself, imply anything about (as you put it) whether dr/dt=0 is an "initial condition" or a "general condition". The only way you can determine if it is an initial condition (I prefer a momentary condition) or a general condition (I prefer to say a condition that does not vary over time) is by determining whether or not the acceleration of the particle is non-zero or zero. Setting [itex]dr/dt[/itex] equal to zero, does not by itself imply [itex]d^2r/dt^2 [/itex] must also be zero. If you think this is mathematically impossible, then you need to refresh your basic math skills as well as your basic physics knowledge.
  • #76
kev said:
Dear starthaus,
Personal attacks can't cover for your errors. If you don't know how to form and solve the equations of motion, there is always time to take a calculus class.
This is not what espen180 was doing. I think he finally understood his error. You need to be working a little harder to understand it.
Coming from you, this is rich :LOL:
What in [tex]\frac{d^2r}{dt^2}=\frac{d}{dt}(\frac{dr}{dt})[/tex] do you still struggle with?
  • #77
In my defense, I never intended dr/ds=0 to be true for s>0. I just wanted to derive that case before trying for the general case of nonzero dr/ds.
  • #78
True. I think that now you can explain to kev the error he's stuck in.
  • #79
Please re-read my last post slowly where I have tried to explain as simply as possible, why [itex]{dr}/{dt}=0[/itex] does not by itself imply [itex]d^2r/dt^2= 0[/itex].
  • #80
I don't need to, espen180 knows now how to explain to you your errors.I am certain he's now able to do a very good job explaining the many mistakes you're making.
Now, you wasted a lot of his time leading him astray, if you'd be so kind to stop posting nonsense, we can finish his second exercise, like we have finished the one set in the OP. If you listen carefully for a change, you might learn how to solve the problem.
  • #81
What espen was doing was analysing the initial acceleration with the initial condition that dr/dt=0. The initial acceleration in the limit that the velocity is as close to zero as you desire, is accurately given in the equation given by espen. His final equation is not in error. He made a minor slip in the interpretation of the equation due to confusion over coordinate time versus proper time, but he quickly acknowledged that, indicating that it was a minor oversight rather than an ingrained misconception on his part.
It has been explained to you by numerous people that a special case is not an error, but just a limited case of a more general solution. You have wasted a lot of time and caused a lot of confusion in many threads by claiming that any none fully generalised solution is an error.
As I explained to you before, by your definition, SR (the special case of flat spacetime) is an error and the Schwarzschild solution (the special case of a non rotating non charged gravitational body) is an error. Please stop this irritating habit.
  • #82
If you don't understand elementary calculus and how it applies to the equations of motion, it is ok. Why don't you listen for a little while and you'll learn how to solve the problems instead of hacking them.
You can start by understanding the solution for circular orbits, it contains the solution for radial motion as a particular case.
  • #83
It does? Doesn't circular motion assume dr/ds=0 for all s? Such that letting dø/ds->0 makes r go to infitiny?
  • #84
No, you only need to make [tex]\frac{d\phi}{ds}=0[/tex] in the third Euler-Lagrange equation I gave you in post 53. I solved for you both problems.
  • #85
Okay, if I want to find an expression for the acceleration of a particle without assuming dr/ds=0 initially, I have to solve
[tex]\frac{\text{d}^2t}{\text{d}\tau^2}+\left(1-\frac{r_s}{r}\right)^{-1}\frac{r_s}{r^2}\frac{\text{d}t}{\text{d}\tau}\frac{\text{d}r}{\text{d}\tau}=0[/tex]
[tex]\frac{\text{d}^2r}{\text{d}\tau^2}+c^2\left(\frac{r_s}{2r^2}-\frac{r_s^2}{2r^3}\right)\left(\frac{\text{d}t}{\text{d}\tau}\right)^2-\left(\frac{r_s}{2\left(1-\frac{r_s}{r}\right)r^2}\right)\left(\frac{\text{d}r}{\text{d}\tau}\right)^2=0[/tex]
So I figure the first step is to substitute the dt/dτ. The problem is that
[tex]\text{d}t=\text{d}\tau \sqrt{\left(1-\frac{r_s}{r}\right)\left(1-\left(\frac{\frac{\text{d}r}{\text{d}t}}{c^2}\right)^2\right)}[/tex]
which, if correct, would mean that I get a mix of derivatives of r wrt. t and τ. So I have no idea where to start, or if the equations are analytically solvable.
  • #86
You aren't listening...and you keep making new mistakes. Combine posts 84 and 53 and you'll get the solution you are after.
  • #87
Espen180 wat were u xpectin 2 deriv at d end of ur calculatn?
  • #88
He wanted the equation of motion for circular orbits. I solved it for him in post 53.
Now he wants the equation of motion for purely radial motion. He can use the solution at post 53 in order to find it.
  • #89
Espen180, starthaus has said it all. Jst b careful enough not 2 continue making mistakes.
  • #90
I was writing #85 when you posted #84, so pardon me for not noticing it.
The equation in #53, after imposing dø/ds=0:
[tex]-d/ds(1/\alpha*2dr/ds)-(2m/r^2)(dt/ds)^2-d/dr(1/\alpha)(dr/ds)^2=0[/tex]
[tex]\frac{\text{d}}{\text{d}s}\frac{2}{\alpha}\frac{\text{d}r}{\text{d}s}=2\frac{\text{d}r}{\text{d}s}\frac{\text{d}}{\text{d}s}\frac{1}{\alpha}+\frac{2}{\alpha}\frac{\text{d}^2r}{\text{d}s^2}[/tex]
It may be because I'm quite tired, but I think I need a push on solving this.
  • #91
You are on the right path (pay attention to the last term, the derivative wrt [tex]d/dr[/tex], you may have made a mistake , if you do the calculation right there will be some terms that will cancel out, at the end you will be rewarded by a very interesting (and correct) equation of motion.
An even easier approach, as I mentioned before, start with:
[tex]L=\alpha(dt/ds)^2-(dr/ds)^2/\alpha[/tex]
and form the Euler-Lagrange equation wrt [tex]dr/ds[/tex] and [tex]r[/tex] (it is the same as one of the geodesic equations). We can continue tomorrow.
  • #92
What is the value of [tex]\frac{dr}{dt}[/tex] for a particle in freefall at the moment of apogee?
  • #93
If you don't understand ordinary differential equations, I can recommend a few good courses. In the meanwhile, try trolling other threads.
  • #94
LOL. You're such a sweetheart. How can you be so helpful and so pleasant at the same time? Thank you so much for your brilliant, congenial, and non-condescending answer.
  • #95
If you spent less time trolling and more time studying you would have known that, given the ODE:
[tex]\frac{d^2r}{dt^2}+A\frac{dr}{dt}+B=0[/tex] for any [tex]a<t<b[/tex]
if you make [tex]\frac{dr}{dt}=0[/tex] for any [tex]a<t<b[/tex]
this means
[tex]\frac{d^2r}{dt^2}=0[/tex] any [tex]a<t<b[/tex]
meaning that:
[tex]B=0[/tex]
So, in general, [tex]\frac{dr}{dt}=0[/tex] is not a solution for the ODE. This is why we try solving the ODE with known methods rather than doing silly things like setting [tex]\frac{dr}{dt}=0[/tex].
Even worse is the naive attempt by certain members of this forum at calculating [tex]\frac{d^2r}{dt^2}[/tex] by inserting [tex]\frac{dr}{dt}=0[/tex] in the above ODE and declaring that [tex]\frac{d^2r}{dt^2}=-B[/tex].
Have you slept through your calculus classes or you never took any?
Now, if you could go troll other threads and leave me to help espen180 find the answer to his second question in this thread, that would be nice. We are almost done with the solution, if you have something to contribute, you are welcome but if you only plan to create trolling noise , than troll elsewhere.
  • #96
this means
meaning that:
[tex]B=0[/tex]
Now you're just being too much of a sweetheart. How can you be so non-condescending and provide such a direct and specific answer to my question? I'm sure espen180 will appreciate such non-condescending and straightforward answers as much as I did.
  • #97
He does. Especiially since I answer his questions.
  • #98
kev said:
Dear starthaus,
Completely seconded. In particular we must add to this the fact that in https://www.physicsforums.com/blog_attachment.php?attachmentid=167&d=1275053682" the author bizarrly argues that [tex]d^2r/ds^2[/tex] is the proper acceleration of a radially freely falling particle and this has been explained to him several times by many people over other threads but instead of accepting "the error" he continued backing his wrong idea with no consequences.
Physics is not just "mathematical skills"; it requires you to have a skill of painting a physial picture first (the thing that you really sound to be unfamiliar with) and then coloring it with the mathematical hues.
this means
meaning that:
[tex]B=0[/tex]
Uh, this is worse than I thought it would be. Of course [tex]\frac{dr}{dt}=0[/tex] is not a solution for the ODE and this is 100% true. But you're missing the fact that there are other equations (basically conditions) involved so that differential equation is not alone to be given a condition (not a solution as you may wrongly have reckoned it to be), i.e. [tex]\frac{dr}{dt}=0[/tex], and this is by considering the motion to be momentarily or instantaneously at rest along the geodesic that particle follows. This has nothing wrong with it and therefore [tex]\frac{d^2r}{dt^2}=-B[/tex] is very correct with the condition given.
So if you don't have any idea as to what probably the whole "physical picture" is, please do not throw stones across the threads.
AB
  • #99
If you don't know how differential equations describe the equations of motion, that's ok.
If you want to learn, then it is not necessary to add your name to the list of trollers, wait a little for espen180 to use the tools I gave him and you'll learn.
No, I'm not missing anything, I am just pointing out that several of you are blissfully basking in the same elementary mistake. Instead of trolling, can you try deriving the equation of motion? It is really simple, you know.
It is not necessary to resort to your hacks about "momentary" and "instantaneous" motion. If you knew how, you could have derived the general equation of motion, applicable for any [tex]t[/tex]. How about you tried that instead on spending so much energy in ranting? Feel free to use the hints that I gave out in this thread.
  • #100
Forum rules can be found here: https://www.physicsforums.com/showthread.php?t=5374.
Your repeated violations are too obvious and numerous to point out, and continue in this post.
  • #101
kev said:
You are making the assumption that [itex]d\tau=dt[/itex] when the particle is stationary in the metric but it easy to show that is not correct.
True.
Start with the full Schwarzschild metric:
[tex]c^2 d\tau^2 = (1-r_s/r)c^2 dt^2 - \frac{1}{(1-r_s/r)} dr^2 - r^2 d\theta^2 -r^2 \sin^2 (\theta) d\phi^2 [/tex]
True, espen180 already knows that.
Impose [itex]dr=d\phi=d\theta=0[/itex] to obtain:
Wrong.
espen180 has switched to radial motion, so your condition [tex]dr=0[/tex] is clearly incorrect. The rest of the derivation fails because your initial premise is false.
Once again, the correct condition is [itex]d\phi=d\theta=0[/itex] (but espen180 already knows that). The correct metric is [tex]c^2 d\tau^2 = (1-r_s/r)c^2 dt^2 - \frac{1}{(1-r_s/r)} dr^2 [/tex]
Starting from the correct metric you can derive the general equation of motion. Once you get the equation of motion you can get the correct expressions for acceleration, speed, whatever you need. Don't hack in [tex]dr=0[/tex]. No need for that.
  • #102
Wrong.
That makes no logical sense. How does "espen180 has switched to radial motion" result in "your condition [tex]dr=0[/tex] is clearly incorrect", given that the latter obviously wasn't referring to radial motion?
On what basis is that condition wrong when referring to a stationary particle, as in kev's post you quoted?
  • #103
All espen180's posts after post 56 refer to radial motion.Since kev attempts to answer post 56, his attempt to set [tex]dr=0[/tex] in the metric is clearly wrong since [tex]r[/tex] is variable.
(espen180 makes a lesser mistake than kev by attempting to set [tex]\frac{dr}{d\tau}=0[/tex])
  • #104
starthaus said:
All espen180's posts after post 56 refer to radial motion.Since kev attempts to answer post 56, his attempt to set [tex]dr=0[/tex] is clearly wrong.
So kev is wrong that [tex]dr=0[/tex] for a stationary particle because espen180's post refers to radial motion? Still makes no logical sense.
  • #105
That post was about the acceleration of a particle immediately after being dropped from rest. The word "rest" should justify the dr=0 in the geodesic equations.
