What differentiates expensive meat cuts from cheaper ones?
  • Thread starter jackson6612
In summary: This leaves the gelatinized tissue in the meat, so that it may be advantageous to start with a richer liquid.So, if you are looking to make a stew, cheaper cuts (with connective tissue and lean muscle) are better suited than expensive cuts. Slow cooking will soften the connective tissue without toughening the muscle, so it is advantageous to start with a richer liquid.
jackson6612
334
Cheaper cuts of meat with connective tissue and lean muscle fibre are suitable for stewing, and tastier than stews using expensive cuts, as long slow cooking will soften the connective tissue without toughening the muscle. Slow cooking leaves the gelatinised tissue in the meat, so that it may be advantageous to start with a richer liquid.
Reference:
http://en.wikipedia.org/wiki/Slow_cooker#Advantages
What differentiates expensive cuts from cheaper ones? Is it less connective tissue and lean muscle?
Reference:
I think the main difference is that it's leaner.
Leaner meat has less taste, but is better for stewing.
Oh, gosh, please don't get me started.
My grandfather worked his entire life at a leading meat company, and my father worked there a few years himself.
The "you get what you pay for" is a myth. It's a marketing campaign, and I routinely cook "out of this world OMG where did you get this?" steaks that cost less than $3 a pound.
Gah! $50/lb "kobe" beef? Oh, please.
Reference:
The less expensive cuts are now fads and cost more than the traditionally better cuts.
On the other hand, many cheap steaks [cheap for the cut, and usually at discount stores] come from old milk cows, not good beef cattle.
my understanding is that cheap cuts of meat are better for stews because if you try to cook them like a filet you will be chewing on rubber.
It's the aging process. Cuts which used to be less than a dollar a pound many years ago, are now 8 dollars a pound and up.
I did not know that! Stands to reason they're not just going to let old Bessie go to waste, though.
There are many factors, but to generalize:
1,) The right meat for the correct cooking application. If you want to make a pot roast, or anything using a slow-cooking procedure, a cut with plenty of connective tissue is a MUST. That tissue, under low heat, with moisture (braising for instance) becomes finger-licking good gelatin... see ribs.
2.) Marbling of fat: This is a matter of what you like in your steak, but also informs you how to cook the meat. A piece of tenderloin should be treated carefully, because as a lean cut it's going to be prone to drying out. A rib-eye or porterhouse can be cooked for a longer period to allow the marbled fats to do their magic.
3.) How you cut it: THIS MATTERS. Take a nice skirt steak for instance; this can be perfect for a nice marinade, or a thin-sliced pan application.
The biggest factor is the balance between the amount of connective tissues you need to reduce to gelatin, intramuscular fat, and lean protein. Once you grasp that, any cut of meat can be cooked to perfection.
Cyrus: The "shoeleather" effect occurs when meat with plenty of connective tissue is cooked for a short time, or at HIGH heat. The actin, collagen, and other goodies contract and turn into little bits of rubbery death. Use moisture and medium-low heat over time and you get gelatin. Ribs are the best example: They have TONS of connective tissue, but when cooked for many hours they literally fall off the bone. Much of the unctuous feel is from gelatin, not fat as well. In a stew, the same happens, and the gelatin goes into thickening the stew and giving it texture.
When you make a stock, the reason you use carcass and roasted bones is for the benefit of flavor, but also to render the rick connective tissue to gelatin. If you clarify the stock with a protein and acid mixture, you get consomme, which in the fridge will turn into meat-jello.
So, if you're going to slap a steak on the grill, a medium cut of sirloin, a porterhouse, T-bone. delmonico, or other cut that is relatively far from the head and hoof is a good choice. If you're making a stew, you can use pretty much anything, but a brisket requires a tough cut and a big one... hence the use of brisket. Stew meat is cut, so it can come from a variety of sources.
Finally, as Ivan Seeking said, there is the matter of age of the cow or bull, but that's not something you can discern from sight AFAIK. I know that in the case of chickens, you once again choose a younger chicken (roaster-broiler) for most applications, but an older hen, also called a Stewing Hen, is great for braising, poaching, and... yeah, stew.
As for dry aging, you can do that at home with a really good piece of beef. If you have a nice roast, it's going to concentrate the flavor of the beef, and some other chemical goodness will occur. Some people love the taste, and others loathe it.
Yes, I've done some work with the meat mafia.
all i know is that a lean cheap beef roast simmered in a crock pot for half a day just falls apart and is wonderful if seasoned to my likes.
and prime rib (much less than $120 at places I've been) is just divine.
i also know some people that can barbecue "brisket" well, another cheap cut of meat. i think it tends to involve a long vinegar marinade, followed by a long slow roasting.
Time + Heat + Connective Tissue = Gelatin = Yummy. :smile:
Ah, reminds me...I haven't made oxtail soup in a while. Definitely yummy.
That's a good one, and I really love the rich flavor you get from it. I think the name just spooks too many people, but I love the Filipino version of oxtail soup most. Chinese oxtail dishes are pretty terrific too... god this is making me REALLY hungry.
braised shanks
Evo said:
braised shanks
Mmmmmm... a super-hot cast iron skillet, a couple of ribeyes, seared then slapped in the oven to medium-rare, with a side of Ossobuco, and braised shanks, grilled onions and fingerling potatoes.
Like everything else, supply and demand.
One of the most expensive cuts is the tenderloin. It's tender, which people like, but it's also lean, which isn't a desirable quality. However, the real reason it costs so much is that the supply is low. The largest tenderloin you can find is going to weigh about 6 pounds.
A ribeye, on the other hand, is both tender and fatty. Theoretically, it would cost more per pound than a tenderloin but it's much larger than a tenderloin, so it doesn't cost quite as much because there's a larger supply.
A porterhouse is a ribeye plus a tenderloin, with a bone in between. While the bone actually makes it more flavorful, people aren't willing to pay for something they won't eat, so it typically fetches a lower price per pound than a ribeye just like a bone-in chicken breast costs less per pound than a boneless one. While I would actually pay more to have the meat on the bone, most people would rather have it removed, so I luck out.
To sum it up, there are things people like: flavor (fat), size, and tenderness. There are things that people don't like: bone, connective tissue, toughness. In addition to that, there are market forces driving the price as well. There are also many reasons that people are willing to pay more for a steak from a steakhouse than from a market that were addressed in other posts.
Every now and then I will pick up a whole tenderloin from the Costco or BJ's (yes, believe it or not these wholesale places carry *great* meats) and trim and cut into filets. I have a signature filet dish with a porte glaze. It's my own variation on steak au poivre. Served with rosemary-garlic roasted potatoes and steamed asparagus. Oh man I'm hungry.
You need to post that in the food thread. Yum!
Will do!
1. What factors contribute to the cost of meat cuts?
The cost of meat cuts is determined by multiple factors, including the type of animal, its age, the cut of meat, and the quality of the meat. The more desirable the cut and the higher the quality, the more expensive the meat will be. Additionally, factors such as demand, supply, and market trends can also affect the cost of meat.
2. How do grading systems affect the price of meat cuts?
Grading systems, such as the USDA beef grading system, play a significant role in determining the price of meat cuts. Higher grades indicate better quality meat, which is typically more expensive. For example, USDA Prime grade beef is more expensive than USDA Choice or Select grade beef.
3. What is the difference between marbling and muscle content in meat cuts?
Marbling refers to the visible fat within the muscle tissue of meat. It is a significant factor in determining the tenderness, juiciness, and flavor of the meat. Higher marbling levels are associated with more expensive cuts, as they are considered to be of higher quality. On the other hand, muscle content refers to the ratio of lean meat to fat in a cut, with leaner cuts typically being less expensive.
4. Do different cooking methods affect the price of meat cuts?
While cooking methods do not directly affect the price of meat cuts, they can play a role in the overall cost. For example, tender cuts of meat, such as filet mignon, may require less cooking time and skill to prepare, making them more expensive than tougher cuts that require longer cooking times and more expertise.
5. Are there any other factors that can contribute to the cost of meat cuts?
Yes, there are other factors that can affect the cost of meat cuts. For instance, the location and reputation of the butcher or store selling the meat can also impact the price. Additionally, factors such as organic or grass-fed labeling, as well as specialty or exotic cuts, can also add to the cost of meat.
