A growing ball in ideal fluid
In summary: However, the pressure and density at the ball would be different from the surrounding fluid because of the extra mass.
asheg
54
Hi every one,
consider ideal fluid claiming the space all over, and a ball in it which is becoming larger and larger with radius of zero at the begin. Is such a situation possible? Doesn't it in contradiction with ideality (in-compressibility of the fluid). If it's not so, Do places far away from the ball surface sense any change? Is there any wave propagation kind equation for ideal fluids.
Are Div(v)=0 and Curl(v)=0 sufficient for this problem.
(Please give me hints and not the result or solution, since it's on me)
Thank you.
Well if the space is infinite, then there should be no problem with incompressibility. On the other hand, if you don't specify incompressibility (this depends on what you consider an "ideal" fluid) then of course a finite volume could accommodate a growing ball.
If the fluid is truly incompressible, then places far away from the ball would instantly "feel" the divergence. If there is some compressibility, then you might have acoustic waves radiating from the ball. If the fluid is stratified, then the disturbance might excite internal gravity waves as well.
Lots of possible results. What are you envisioning?
Thanks for your reply.
I think if the incompressible be what you say (changes propagates instantly all over space)
then the velocity distribution would be:
V(R,t) = t^2/R^2
t is time
R is Radius from center
Because the radius of ball at time t would be t and the velocity of fluid there would be 1 same as velocity of ball's surface.
But according to navier stokes it is different:
Div (v) = 0
d/dt(v) + v.Grad(v) = Grad(P)/rho
How one can get the answer from above equation? How to calculate P?
The zero divergence (solenoidal) condition is for the fluid parcels themselves. If you postulate a growing "ball" of something in the middle of the fluid, then of course you can't include its volume in your fluid mass conservation. The fluid on all sides of the "ball" continues to satisfy div v = 0.
Hello,
Thank you for your question. I can provide some insights on this scenario with an ideal fluid and a growing ball.
Firstly, it is important to note that the concept of an ideal fluid is an idealization and does not exist in reality. It is a simplified model used in fluid mechanics to study the behavior of fluids. In an ideal fluid, there is no viscosity, no turbulence, and no compressibility. Therefore, the statement that the fluid is "claiming the space all over" is not entirely accurate. In reality, the fluid would be contained in some sort of container or boundary.
Now, regarding the growing ball in the ideal fluid, it is not in contradiction with the ideal fluid assumption of incompressibility. In an ideal fluid, the density is assumed to be constant, and therefore, any change in volume will not affect the fluid's density. The ball can grow without causing any change in the fluid's properties.
As for the question of whether places far away from the ball's surface sense any change, the answer is yes. This is because any disturbance in a fluid will cause a wave to propagate through it. However, in an ideal fluid, the wave propagation is governed by the Euler equations, which do not have a wave equation like in the case of a compressible fluid.
Finally, regarding the equations Div(v)=0 and Curl(v)=0, they are not sufficient to solve this problem as they only describe the fluid's kinematics (velocity and vorticity), but do not take into account the growing ball's dynamics. To solve this problem, you would need to incorporate the equations of motion for the ball, along with the Euler equations for the fluid.
I hope this provides some helpful hints for your problem. Best of luck!
1. What is a growing ball in an ideal fluid?
A growing ball in an ideal fluid refers to a hypothetical scenario in which a ball placed in a fluid experiences continuous growth in its size without any change in its shape or density. This is often used as a simplified model to study the behavior of fluids in various situations.
2. What is an ideal fluid?
An ideal fluid is a theoretical concept in which a fluid is assumed to have no viscosity, i.e. it flows without any resistance. In other words, it is a fluid with perfect flow characteristics and does not experience any internal friction or loss of energy.
3. How does a growing ball behave in an ideal fluid?
In an ideal fluid, a growing ball would experience uniform growth in all directions without any change in its shape. This is because the fluid exerts equal pressure on all sides of the ball, causing it to expand evenly.
4. What factors affect the growth of a ball in an ideal fluid?
The growth of a ball in an ideal fluid is affected by the density of the fluid, the size and shape of the ball, and the rate at which the ball is growing. Additionally, the viscosity of the fluid may also play a role in the growth process.
5. What are the real-world applications of studying a growing ball in an ideal fluid?
The concept of a growing ball in an ideal fluid has various real-world applications, such as in the study of fluid dynamics, material science, and even weather forecasting. It can also be used as a simplified model to understand the behavior of gases and liquids in different scenarios.
