Reference for simplicial homology and cohomology
  • Thread starter lavinia
  • Tags
    Reference
In summary, the simplicial complex defines a set of mappings from the standard simplex into the space, but the orientation of a simplex does not have to be specified. The boundary operator is given by a function that assigns a sign to each face of a simplex, and the cochains are the same as the chains. The singular chain complex defines a chain complex of mappings from the standard simplex into the space, where the orientation of a simplex is not specified.
lavinia
694
I would like to read more about this version of simplicial homology and cohomology. Any reference or explanation is welcome.
I hope this description is correct.
Triangulate a smooth manifold and assign an orientation to each simplex in the triangulation.
Define the boundary operator with respect to this orientation.
This defines the simplicial chain complex.
for the cochain complex use exactly the same simplices but define the coboundary operator as the transpose of the boundary operator. It maps k chains to K + 1 chains while the boundary operator maps k chains to k-1 chains.
Thanks in advance.
Spanier is a standard reference for simplicial homology. Other classics are Hilton and Wylie, and Eilenberg and Steenrod.
An actual textbook,decently short, and containing a proof of the deRham theorem is Singer and Thorpe.
http://www.abebooks.com/servlet/SearchResults?an=singer,+thorpe&sts=t&x=63&y=11
It seems that once one has a few basic computational theorems, especially Maier Vietoris, it does not matter what theory one is using. Theorems on what happens when you "add cells" are also basic.I am not sure I understood the subtlety of your question. Did it involve the use of oriented as opposed to ordered simplices, or the application to triangulated manifolds, or was it a general question about simplicial homology?
a triangulation seems just to be a homeomorphism from a simplicial com-lex so the question seems to reduce to understanding the homology of a simplicial complex. At any rate Hilton and Wylie seem to do the oriented version as do Singer and Thorpe, while perhaps Eilenberg Steenrod do the ordered version. Singer Thorope apply it to a triangulkated manifold.
The only place I have seen it proved that a smooth manifold has a triangulation is in a book by Munkres that I used to have. It took up the whole book.
However one can give a short description of a proof by saying one embeds the manifold in R^n and restricts, then tweaks slightly, a fine triangulation of R^n.
Doesn't every singular simplex canonically inherit an orientation (since it is defined as a homeomorphism from the standard singular simplex, which has an orientation, into the space)? Of course, these orientations may not define an orientation of the space - obviously simplicial complexes (triangulated spaces) are more general than oriented manifolds (actually, not all manifolds are triangulable, so that's not quite true).
I too don't understand the question - you don't need manifolds to define simplicial (co)homology. It is relatively easy to show that the simplicial (co)homology of any triangulated space is isomorphic to its singular (co)homology.
You are right that the homology question does not require a manifold. Sorry for being confusing.
it is just that the problem I am trying to understand requires a 4k dimensional manifold.
I think the authors think of each geometric simplex as the image of a single mapping of the standard simplex. The other mappings, those that map the standard simplex with a different ordering of vertexes are not included in the chain complex.
You can choose an orientation of a simplex by choosing an ordering of its vertices. Equivalent orderings are considered the same as the chosen one so I guess there is an equivalence relation where they are all identified.
To me this all seems a little unusual. For instance,the boundary operator must be determined by a function that assigns a sign to each face of a simplex and this sign depends on the simplex and the chosen orderings.
Also the cochains are the same as the chains. there are no homomorphisms of chains into the integers as in singular cohomology. There is a single graded group of ordered simplices made into a chain complex in two ways - one with the boundary operator, the other with its transpose.
I will look at Spanier to make sure there isn't some subtlety to this way of doing things.
Arghh, it lost my long post - let's write it all up again...
I think I see what you are getting at. The definition of a simplicial complex, as it stands on wiki, seems to me to be very strict. We require that the faces of the simplices not only "match up" but "are the same" whenever they overlap.
Now, in the definition of the singular chain complex, there is nothing to say that for any given σ, the chain -σ is equal to σ with the opposite orientation. For example, if we take the chain given by σ:[0,1]->[0,1], σ(t)=t, there is nothing in the definition of the singular chain complex which says that -σ = σ' where σ' is the map σ':[0,1]->[0,1], σ'(t)=1-t.
However, the following probably can be said: [(-1)^n]σ' is homologous to σ where σ' is given by a reordering of vertices with sign n.
Hence, it seems to me that we arrive at this point: we can either think of σ with a negative orientation and -σ to be different in the chain complex, which means we will require a much stricter version of a simplicial complex (and probably require a finer triangulation), or we can acknowledge that they will end up being homologous and work in the chain complex where they are identified (in fact, we may like to identify more than just these to make things even easier on ourselves).
You should just view the simplicial chain complex as being a subcomplex of the singular chain complex, where this inclusion is a quasi-isormorphism. Of course, the correct statement of this depends on the above - we may want to work with the chain complex where -σ and σ with the negative orientation are already identified. But in the end, we should still get quasi-isomorphisms and the same homology and everything should follow smoothly.
I didn't follow this - the cochains of the simplicial cochain complex are still homomorphisms of chains into the integers (or other coefficient group) - this is how they are defined! The only difference now is that, in most cases, we now are working with a finitely generated module where the dual will be isomorphic to the original with the obvious identification. Taking the transpose maps gives precisely the cochain complex.
We know this is the right cochain complex - for example, the UCT says that the homology determines the cohomology. If we accept that the simplicial homology is isomorphic to the singular homology, then their cohomology must also be the same, so indeed taking the transpose maps and then taking homology gives us precisely the singular cohomology.
Thanks Jamma and Mathwonk.
From what you are saying it seems that I can view a simplicial complex just as a collection of ordered finite subsets of a set with the condition that if a subset is ordered then each of its subsets must also be ordered.
The boundary operator is then determined by the orderings.
I'm not sure if it is defined in this way - but I think it can (and for all intents and purposes, we act as if it is).
For example, we "know" that we can triangulate a Mobius band, we can even draw a picture to show that we can. However, the technical definition of a simplicial chain complex would require the boundaries of the little triangles to be exactly the same maps. Can we be sure that we can find the correct maps so this all works out?
I think the resolution probably goes something like this. We can triangulate our space, and don't really need to worry when the maps at the faces aren't exactly the same, we only need to know that they are the same up to a boundary. From there, one can probably make statements like you have in terms of the subsets of vertices, and their orderings and so on. If one can triangulate a space using simplexes in a way such that the overlapping faces are the same subsets, then one can probably be sure it all works out up to homology (or that one could potentially find the exact maps, if required). So in the end, you are right.
Incidentally, it seems you've independently stumbled upon the idea of a "simplicial set". These can basically be thought of as purely algebraic models of topological spaces (actually, I think that they could be more general than just simplicial complexes - I know there is a geometric realisation functor). One can study the homotopy theory of these objects and so on. The idea behind them is basically right inline with what you were saying about collections of ordered finite subsets - you have your vertices, 1-simplices which are ordered pairs of vertices and so on, and you have "face maps" and "degeneracy maps".
I'd advise you to check them out!
Interesting post Jamma.
One thought: A triangulation determines a topological space that is homeomorphic to the original. It is just the subset of the standard simplex in Euclidean space (dimension = number of vertices in the triangulation minus 1) spanned by the simplices in the triangulation (simplices identified by their vertices). This homeomorphism makes the maps on overlapping faces the same.
In this paper I am trying to read, a map between Euclidean simplices with the adjoint boundary operator and the de Rham cochain complex is given and the author says that it is an isomorphism between simplicial cohomology and de Rham cohomology. The forms are
r![itex]\Sigma[/itex][itex]^{r}_{i=0}[/itex]x[itex]_{i}[/itex]dx[itex]_{0}[/itex]^...^dx[itex]_{i-1}[/itex]^dx[itex]_{i+1}[/itex]^ ...dx[itex]_{r}[/itex]
where the x[itex]_{i}[/itex]'s are barycentric coordinates.Another half thought: For a smooth triangulation the integrals of forms are the same on overlapping faces since the maps are reparameterizations of each other - I think. So the de Rham cohomology only cares about the underlying set in some sense.
what coefficients is he using? deRham usually uses reals and simplicial usually uses integers.
I'm assuming we are looking at simplicial homology with real coefficients.
real coefficients. The pupose of the paper is to find a combinatorial formula for the signature of a 4K manifold. Torsion cohomology classes don't count because they all die under the cup product.
ok, i believe you know more algebraic topology than me, but I still comment. Over a coefficient field, cohomology is just dual to homology so to show the deRham cohomology spaces are isomorphic to the simplicial ones, one only has to show they are dual to simplicial homology.
Of course it might be easier to shown they are dual to singular homology.
And of course cohomology has a cup product making it a ring, and so one also want this to correspond to the wedge product in deRham cohomology,...blah, blah,...
Mathwonk I have not tried to verify this claim and don't know how the proof would go. Let's see if we can figure it out. The authors refer to Whitney's book, Geometric Integration Theory.
which claim? the duality is the "universal coefficients" theorem for cohomology.more likely you meant the fact that differential forms exist dual to all homology classes.
In section 6.2, Singer and Thorpe prove the isomorphism between deRham and simplicial cohomology for a smoothly triangulated manifold.
In Bott -Tu, the first result in chapter 2 proves the isomorphism between deRham cohomology and Cech cohomology. On p.191 they prove the isomorphism between singular and Cech cohomology.
In Spivak's differential GEOMETRY THE LAST EXERCISE OF CHAPTER (11) of volume I, proves the isomorphism between deRham and singular cohomology.
the last result of chapter II of Ronnie Well's "differential analysis on complex manifolds",
is the sheaf theoretic proof of the deRham theorem, probably an isomorphism of Cech and deRham cohomology.
I recommend Singer Thorpe as most elementary, and Spivak or Bott -Tu as most clear.
Wells' proof is the modern slick formulation of the idea that the theorem is proved if it is only proved locally, an idea apparently due to Weil.
So the best place to look would be the proof due to A. Weil.
here is an alternate link:
http://www.nd.edu/~lnicolae/Fanoethesis.pdf
Thanks Mathwonk. I just glanced at Singer and Thorpe and they use the same differential forms. I guess they are reproducing Whitney's proof. Before reading it though I would like to try proving it for myself.
yes, they say in the introduction their proof is taken from Whitney's book. I just notioced that. I don't have a copy of Whitney. I don't see any attempt to prove that the ring structure given by wedge product agree nwith the one by cup product though. maybe i missed it.
a more serious criticism of Whitney's proof is that he apparently did not even prove the isomorphism is functorial. This is a serious drawback to the simplicial approach.
see:
http://www.jstor.org/discover/10.2307/2040817?uid=3739616&uid=2129&uid=2&uid=70&uid=4&uid=3739256&sid=21100789689321
Not sure yet. Thanks for that link. It opens up a whole new idea for me, the idea of PL forms.
BTW: While this paper I am reading does not discuss the cup product it does give what the authors call the simplicial analogue of the Hodge star operator.
homology and cohomology seem quite intersting. i.e. a simpliciual complex has a well defined homology and cohomology but it is not clear how to associate one simplicial complkex to a topological space like a manifold. I.e. every triangulation dioes so but there arte many of them. the cech process also does so but there arte a lot of open sets.
'the deRham process associates a complex but the space are infinite dimensional. the same holds for the singular procedure.
so the processes that associate finite dimensional complexes do not seem canonical, and the canonical ones seem to give infinite dimensional spaces. so one has to relate all this.
I just noticed that the forms
are not smooth at the boundaries of r simplices so they are not in the de Rham complex. I think this is why Singer and Thorpe construct smooth partitions of unity around the simplicial complex.
But I wonder if the de Rham complex is extended to continuous forms that are smooth except possibly on a set of measure zero where they are identically zero whether it still gives the real cohomology and whether the barycentric coordinate based forms give an isomorphism of cohomology,
I don't know quite how you would take d of a form that is not smooth.to repeat my philosophical remarks above, it seems the job of computing (co)homology is to approximate an infinite dimensional complex by a finite dimensional one having the same (co)homology groups.
e.g. the deRham complex is infinite dimensional and intrinsic, while the simplicial one is finite dimensional, and depends on choices, as is the cech complex associated to a finite cover.
if they give isomorphic cohomology then you deduce that the one depending on choices was independent of the choices, and also that the intrinsic one had finite dimensional cohomology. double bonus. obvious perhaps, but cool.
In terms of your non-smooth forms, it feels like you may want some smooth structure on your simplicial complex - I've certainly heard of piecewise linear triangulations. It seems though that the most obvious way to prove things is:
Simplicial [itex]\cong[/itex] singular [itex]\cong[/itex] De Rham
Mathwonk is correct about proving that the De Rham complex is dual to the singular homology group (integrate along the chain) - I believe that this induces a pairing between the singular and De Rham cohomology groups which gives the desired isomorphism.
[Edit]:
Actually, I should probably put:
Simplicial [itex]\cong[/itex] singular [itex]\cong[/itex] smooth singular [itex]\cong[/itex] De Rham
since there is a pairing not for arbitrary chains, but for smooth chains. I presume it isn't too difficult to show that the chain complex of smooth chains is quasi-isomorphic to that of singular chains (chain homotopy will involve "smoothing out" chains).
no wonder eilenberg and maclane decided they needed to axiomatize this topic.
in addition to those 4 theories above, there are cech, alexander, cellular, derived functor sheaf definitions,...etc...etc ...
the book by eilenberg maclane is also quite illuminating.
1. What is simplicial homology and cohomology?
Simplicial homology and cohomology are mathematical techniques used to study the topological structure of shapes, spaces, and surfaces. They involve breaking down a shape or space into simpler building blocks called simplices, and then analyzing how these simplices fit together to form the overall structure. Homology and cohomology are closely related concepts, with homology focusing on the algebraic structure of a space and cohomology focusing on its topological structure.
2. How are simplicial homology and cohomology used in scientific research?
Simplicial homology and cohomology have applications in a wide range of scientific fields, including biology, physics, chemistry, and computer science. They are used to study the topological properties of complex systems, such as protein structures, fluid dynamics, and neural networks. They also have practical applications in data analysis and image recognition.
3. What are the main benefits of using simplicial homology and cohomology?
Simplicial homology and cohomology provide a powerful tool for understanding the underlying structure of complex systems. They allow researchers to analyze and compare different shapes and spaces, identify patterns and symmetries, and make predictions about their behavior. They also provide a rigorous mathematical framework for studying topological properties that may be difficult to visualize or describe in other ways.
4. What are the main limitations of simplicial homology and cohomology?
One of the main limitations of simplicial homology and cohomology is their reliance on simplicial complexes, which may not accurately represent the true structure of a shape or space. This can lead to errors and inaccuracies in the analysis. Additionally, these techniques may not be suitable for studying highly irregular or non-geometric structures, such as fractals.
5. How can I learn more about simplicial homology and cohomology?
There are many resources available for learning about simplicial homology and cohomology, including textbooks, online courses, and research papers. It is recommended to have a strong background in abstract algebra and topology before delving into these concepts. Additionally, attending conferences and workshops on the subject can provide valuable insights and opportunities for discussion with experts in the field.
  • Differential Geometry
