- #36
PeterDonis
Mentor
- 45,370
- 22,520
arindamsinha said:I understand that the event may actually happen for an observer falling into the black hole, but by our clock, this falling observer also never reaches the event horizon! So I stand by the statement that the event "does not exist" or come to pass ever, by our clock.
You can look at it this way, as long as you only draw valid conclusions from your statement. For example, it is valid to conclude that events at or inside the event horizon can never causally affect you (because no causal influence can travel faster than light), so in that sense you can behave as if they don't "exist". But it isn't valid to conclude that *nobody* can ever feel any causal influence from those events, because someone could always choose to fall into the black hole.
arindamsinha said:This is where I see a conflict. From our point of view, drawing a geometric parallel, two lines are asymptotic and only meet at infinity, and never cross over.
You have to be careful interpreting what "only meet at infinity" means. You appear to be picturing it the way it would work on a flat Euclidean plane: two parallel lines on a plane "only meet at infinity", meaning that you can extend them to any finite length you like and they will never meet.
This is *not* true for the worldlines of two infalling objects that meet inside the horizon. "Length" along worldlines in spacetime means proper time, and the two objects will meet in a *finite* amount of proper time. You already agree with this, but you apparently haven't fully comprehended what it means. It means that the two lines are *not* "infinitely long" before they meet below the horizon, in the way that parallel lines on a Euclidean plane are "infinitely long" before they meet. You can only extend the two worldlines for a finite length before they meet, even though doing so covers an infinite range of the distant observer's time coordinate.
In other words, when you have extended the two lines "to infinity" according to your clock, you have only extended them to a finite length in geometrically invariant terms. You have chosen a time coordinate that is so distorted at the horizon that it extends finite lengths (i.e., finite proper times) so they look like infinite lines. The analogy you are trying to draw with "infinite lines" in ordinary plane geometry does not work; the lines that "look infinite" to the distant observer because of his choice of time coordinate are *not infinite*.
arindamsinha said:I am getting the feeling that there is still some lack of appropriate interpretation of GR in this area
No, it is just that you don't fully understand what the standard GR picture says. The above may help.
arindamsinha said:That is, unless we accept the other possible explanation that black holes never really fully form, but get aymptotically closer to forming all the time.
No, this "explanation" does not work; it amounts to claiming that the lines that "look infinite" in your time coordinate really are infinite, in the way parallel lines on the Euclidean plane are infinite. That is not correct. See above.
