Unraveling the Role of Pseudo Forces in the Ultracentrifuge: Can They Do Work?
In summary, pseudo forces can do work and the calculation of work done is dependent on the frame of reference. However, pseudo forces do not have a reaction force as they are simply a result of viewing things from a non-inertial reference frame. In the case of a small block sliding on a large block, the work done is due to the inertial force in the non-inertial frame, but in the inertial frame, there is no work done as there is no real force acting on the small block.
dpsguy
69
Its been bugging me for a while now-can pseudo forces do work? Is the calculation of amount of work done dependent on our frame of reference?
Cmon!Does nobody know?I've been waiting for 3 days!
I assume by pseudoforce, you mean an inertial force like centrifugal force?
In any case, the work done by a force definitely depends on the frame of reference. (Even without involving noninertial frames.) After all, in a frame in which the point of application doesn't move, the work done is zero.
As for pseudoforces being able to do work, I see no reason why not. (As long as you are in a frame in which those forces exist.)
I suspect that it would be reasonable to state that work was done by a pseudo force (centrifugal force due to gravity) in making the Earth bulge at the centre during its formation.
I have a subsidiary question :
Do you consider that gravity is a pseudo-force ?
But do pseudo forces really exist? I mean, a force should have an equal and opposite reaction,no? Now consider a small block placed on top of a large frictionless block. The large block is accelerating.If we analyse the situation from the frame of reference of the small block ,we use a pseudo force in a direction opposite to the acc.,so that we can apply Newtons laws.But where is the reaction to this pseudo force?
And if the force does not exist,how can it do work?
As for the work done being dependent on the frame of reference, I have just one question.In a hydroelectric plant water falls from a great height from a dam and causes the blades of a turbine to rotate. Suppose water falls with a terminal vel. v.If an observer falls along with the water,(assuming that he does not die on falling!),the water is at rest with respect to him and hence its energy does not change.So how would he explain the turning of the blades given that he knows the turbine is fixed to the ground and cannot come up to meet the water. Where would the blades get the energy from if the water does not lose any?
I have looked at this thread for a couple days and thought about it. Help me out here if I am wrong. In the case of centrifugal force, well I should'nt really call it a force, because its NOT, we have to be extra carefull. It is INERTIA, that allows the object to want to fly off along a tanget to the circular motion. But a REAL force is created when that object that is able to move, it DOES move and run into, say the wall of the car. That is equal and opposite, to anwser your question dpsguy. If there is no wall, there is something like a string with a mass spinning around, the same analysis will hold for that situation, with the force of the wall being replaced by the tension in the rope, or whatever its RIGIDLY attached to.
As for your water wheel example, your falling with a terminal velocity v. So in your frame of reference you have zero kinetic energy, but the water wheel appears to be moving towards you at a velocity v, so it appears to have the kinetic energy in this frame. hmm, as for gravitational potential energy, I *think* in your moving frame of reference you can call that zero, so the water wheel also has a changing potential energy relative to you. Its like thinking of the situation in opposite. In the wheels frame of reference, the water comes down and hits it. In the waters frame, the wheel comes up and hits it. The only thing I am not sure about what I said is that if that were true, the heavy water wheel appearing to move at a velocity v, would have a huge amount of kinetic energy, and it seems to discredit what I wrote, so don't believe it! Someone help me out, now I am confused too! :-)
Thinking a simple example.
With application of sudden brakes to a truck, a box appear to slide forwards on the surface of truck.
We call that as the truck is retarding, in the frame fixed with the bus we have to consider a pseudo force in forward direction.
Now my question is that, as the box moves forward against friction, which force is doing work against friction?
The difference between inertial (pseudo) and "real" forces is that real forces have agents (something that exerts the force) while inertial forces do not. Inertial forces are simply due to viewing things from a non-inertial reference frame. There is no reaction to an agentless force!
Consider your example of a small block sliding without friction on large block that is accelerating. If you view things from the accelerating frame of the large block, then the inertial force "pushes" the small block along. So the inertial force does work on the small block, increasing its kinetic energy. (Of course, from the inertial frame of the ground, the small block is just sitting still--there's no friction or other real force acting on it.)
If you view things from the frame of the small block--an inertial frame--then you'll expect to find a real force pushing that large block. (Else why would it accelerate?)
From the frame of the water/observer, the turbine (and the Earth itself!) is rushing towards him with plenty of energy! And the speed of the water with respect to the Earth will change when it hits the turbines, of course. If you want to analyze the interaction from the inertial frame moving with speed v, you must stick to it. (Since the water is really accelerating as it falls, this is a messy frame to use.)
You can understand the frame dependence of work and energy more simply by analyzing this problem: An "ideal" car (no internal friction, air resistance) uses an amount of fuel to accelerate from 0 mph to V mph. We know the energy needed is [itex]1/2 m v^2[/itex]. And to accelerate from V to 2V, it takes an additional 3 times that energy (the total energy is [itex]1/2 m (2v)^2 = 2 m v^2[/itex]). But what if you viewed things from a frame moving at speed V? In that frame the second burst of speed only takes the car from 0 to V? Does the amount of fuel needed depend on the frame that you view things from? :wink:
Then gravity is a pseudo-force ... because for someone in free fall gravitational force doesn't exist (GR). I'm not sure of me that's why i asked it before but i didnt get any answer :(
That would also eplain why when you put a not-calibrated accelerometer on a table it indicates that the acceleration is pointing up and with an intensity of 9.81.
That's because if you put your accelerometer in an elevetaor in space with nothing around it : it indicates 0 (elevator isn't moving). If you want someont in the elevator to feel like if he were on earth, you have to make the elevator go up with an accelration of 9.81.
gravity as a pseudo-force
Sorry for ignoring your question, but I was purposely trying to stick to classical mechanics and avoid GR considerations. While you are right that gravity is a "pseudo-force" in a GR context, you can't simply treat it like an ordinary inertial force (like centrifugal force) within classical mechanics.
My GR is quite rusty, unfortunately, but my trusty (but dusty) copy of Adler, Bazin, & Schiffer (Intro to GR) backs me up with this quote: "... it is impossible to have gravitational forces take the same mathematical form as fictitious forces within the framework of classical analytic mechanics". (You need a description within a four-dimensional space. I'll let GR experts fill in more details.)
It seems that I wasent all that far off in my reasoning then, right doc al? Could you explain the problem I faced when I came to your conclusion. If we look at the water falling at speed v, the m in mv^2 is small, but if we look at the earth-wheel system, the m in the mv^2 is HUGE. This frame seems to have too much energy associated with it. We would expect the water to be vaporized upon contact, since so much energy is being transfered. Is the total energy generally conserved from one frame to another, or does it change? Also, does the massive kinetic energy somehow get reduced by a similarly huge potential energy?
I tried to use a mathematical approach...and got confused.
Suppose the mass of falling water is m and that of the turbine is M(what's more reasonable- m>M or M>m?)Also suppose that the height at which water attains terminal velocity is h metres above the turbine.
Firstly, consider the situation from an external,inertial reference frame.
Taking the ground as reference level,PE of water is mgh and its KE is mu (where u=0.5xv^2).So K=mgh+mu where K is the KE with which the turbine rotates.Here work is done by water on the turbine.
Now consider the RF falling at vel. v.Taking the referene level at height h the PE of turbine is -Mgh and its KE is Mu.So K=-Mgh+Mu.Here work is done by turbine on itself.
This means that m=M(u-gh)/(u+gh) which seems to be a special case.If the masses do not satisfy this reln. will the blades not rotate?Or is this some limiting case, or what?
Also,Doc Al, by saying that fuel needed does not depend on the RF, are you not contradicting what you said earlier-that work depends on our reference frame?
Not at all. (I hope you realize that the amount of fuel used cannot depend on the frame of reference!) Calculation of work and kinetic energy does depend on frame of reference. Why don't you work through that example with the car and see for yourself.
Sorry,Doc Al, but I don't see your point.Suppose x l of fuel are used in accelerating from 0 to V. Then 3x l are used up in going from V to 2V.If our RF is moving at a vel. V,then the increase in KE is only 0.5m(V^2). But we know that 3x l of fuel have been used. How would the observer explain this anomaly?
Also, in the turbine example,the final KE of the turbine would be the same irrespective of the RF(obviously?). Hence whether we work in the RF of water or the turbine,the work done on the turbine will be same(see mathematical approach).Please correct me if I am wrong.
I've isolated an handy "test" (not infallible) to determine whether or not work is done by a force. Since work is the mechanical transfer of energy, then if an object is observed to change speed, height, shape, or temperature, then work must have been done. (Absence of any of these changes does not definitely indicate "no work," however).
In a rotating reference frame( a turntable for example) , the centrifugal force will appear to be the force that pulls a ball toward the outside of the circle. But this force will not accelerate the ball. The increase in speed of the ball comes from the tangential force (by friction) from the floor. The rotating observer will see the "coriolis effect" as the ball drifts to the left or right as it progresses to the outer edge of the turntable. The ficticious centrifugal force does not do the work even in the rotating frame of reference.
But the inertial reaction of coming to a quick stop (in a car): in the car's frame of reference, it does appear that the inertial force causes the passenger to accelerate forward into the windshield. As Doc Al mentioned, this only "works" if you stay in the accelerated reference frame, but since you can't (you just crashed your car), you always must be able to identify the object that really did the work (in this case the windshield).
That's the problem I asked you to figure out! To do that, you must consider that the work done on the car (by friction of the road) is different in different frames. And the fact that work is done on the earth. Give it a shot.
How can kinetic energy be independent of RF? Speed (obviously) depends on the reference frame.
When I get some time later I will post comments on your water/turbine example. But it's a similar issue as with the car.
:confused: I gave it a shot...and missed.
I tried to take it one frame at a time.What I was trying to prove was that fuel needed during the second burst of speed is three times that needed during the first in the same RF.I had no problem with the stationary RF.
But I had a problem with the moving reference frame.Suppose the car and the RF are at the same point at t=0. If we assume RF to be at rest, the car seems to go back(with a decreasing vel.) a distance of 0.5vt on the first burst of speed and then comes back to its original point after the second burst(here t is the time taken to reach a vel.v from rest).Now my question is-where does the car get a vel.v from?And if the KE is decreasing,why is any fuel needed?Also, is the friction acting on the car not the same during the forward and backward journeys?And lastly,what do you mean by "work done against earth"?Please forgive me if I am sounding stupid,but I need an explanation.
Forget the last post,I was just too dense. Anyway I figured it out. but that analysis does not work in the case of the turbine. For one,there is no friction(neglect air resistance).
Say the electricity produced in the plant is proportional to how fast the turbine rotates.If the KE of turbine is dependent on the RF isn't the electricity produced too?
I seem to remember that when D'alembert first came up with the idea of pseudo forces he had to postulate they would work to describe accelarted frames of refernce. So that Pseudo forces work is a postulate added to the postulates of Newtonian mechanics.
In GR gravitational forces are just like a pseudo forces in thta they are frame effects and you can always pick another local refrence frame in which they do not occur.
The rotational KE of the turbine with respect to its axis will not be frame dependent. (But the translational KE of a turbine blade will be.)
You have to take into account the change in KE and momentum of the earth, produced by the reaction force of the tires against the road. In the second reference frame, the Earth's KE changes by a larger amount than in the first reference frame.
Eaxctly! When applying Newton's 2nd law to calculate [itex]F \Delta x[/itex], realize that you must include the "work" done on all the objects involved (Earth and car) and that [itex]\Delta x[/itex] is frame dependent. (For example, in the Earth frame the Earth doesn't move.)
Or simply use conservation of energy and momentum. Consider two masses M and m, at rest next to each other in some inertial reference frame. Their kinetic energies and momenta are both zero. Now add energy Q. This might come from having one of the masses push against the other one, or by exploding a firecracker in between them, or releasing a compressed spring, or whatever.
Now M moves to the left with speed V, and m moves to the right with speed v. Since both M and m are initially stationary, the change in their kinetic energies is
[tex]\Delta K_M = \frac{1}{2} MV^2[/tex]
[tex]\Delta K_m = \frac{1}{2} mv^2[/tex]
Now let's look at this in a second reference frame that moves with speed u to the right relative to the first frame. Before we add Q to the system, both M and m are moving to the left with speed u. After we add Q, M is moving to the left with speed V+u and m is moving to the right with speed v-u.
The change in kinetic energy for M and m in this frame is
[tex]\Delta K_M = \frac{1}{2} M (V + u)^2 - \frac{1}{2} M u^2
= \frac {1}{2} MV^2 + MVu[/tex][tex]\Delta K_m = \frac{1}{2} m (v - u)^2 - \frac{1}{2} m u^2
= \frac {1}{2} mv^2 - mvu[/tex]
So in the second frame, M changes its kinetic energy by a larger amount than in the first frame, whereas m changes its kinetic energy by a smaller amount. Note that MV = mv from conservation of momentum in the first frame, so MVu = mvu.
Water/turbine problem
I see 2 reasons why my mathematical approach was wrong:
1.we cannot neglect air resistance(else how would water attain terminal velocity ?)
2.the total energy will not be K in both cases as K is the sum of translational and rotational kinetic energies and translational KE will be different in the two cases, as helpfully pointed out by Doc Al .
But if I take these 2 points into consideration, the maths becomes very messy indeed.Am I still missing out on anything or have I actually chosen a very bad example to understand work done in different reference frames?
BTW, jtbell, I am not sure we can use momentum considerations of one RF in another, as you have done(MV=mv).As Doc Al had said earlier,when you use one RF , stick to it.Or did I get it wrong?Kindly elaborate.
Returning to pseudo forces
The reason I asked about work being dependent on the RF is because I wanted to know whether pseudo forces can do work or not. I think the question has been quite satisfactorily answered, thanks, Doc Al and all the others.
But I was thinking of an ultracentrifuge,which biologists use to separate components of a cell.The cells are taken in a solution in a glass tube which is then revolved at very high velocities in the centrifuge.We have been told that the cell components separate due to centrifugal force,with the heaviest settling down first at the end of the tube.But what if we viewed this from an inertial RF?What force would separate the components then?Also, is centrifugal force actually doing some work in this case?
1. Can pseudo forces do work in the absence of actual forces?
No, pseudo forces are only apparent forces that arise due to the non-inertial reference frame. They do not have a physical origin and can only be experienced by an observer in a non-inertial frame. Therefore, they cannot perform any physical work.
2. How are pseudo forces different from actual forces?
Pseudo forces are different from actual forces in two main ways. Firstly, pseudo forces do not have a physical origin and only exist in a non-inertial reference frame. Secondly, pseudo forces do not transfer energy or cause any physical displacement of a body, whereas actual forces can do work and cause physical changes in a body.
3. Can pseudo forces be measured or detected?
No, pseudo forces cannot be measured or detected directly as they do not have a physical origin. They can only be observed and calculated by an observer in a non-inertial frame.
4. Do pseudo forces follow Newton's laws of motion?
Yes, pseudo forces follow Newton's laws of motion just like actual forces. However, they are not real forces and do not have a physical origin. They only appear to exist due to the acceleration of the reference frame.
5. Can pseudo forces affect the motion of an object?
Yes, pseudo forces can affect the motion of an object in a non-inertial frame. However, they do not cause any physical changes in the object and cannot perform any work. The object's motion is still ultimately determined by the actual forces acting on it.
  • Classical Physics
  • Classical Physics
  • Classical Physics
