2-D Laplace equation in rectangular coordinates
In summary: This still doesn't solve the problem that K1 needs to be imaginary for the boundary condition to be satisfied.
faradayslaw
51
"The potential in the x-z plane is independent of z and given by a repeating step-function of magnitude 2(phi_0) and period 2a. The plane at y = y_0 is held at ground potential. Find the potential in teh region 0 < y < y_0." - Marion and Heald Classical Electromagnetic Radiation 3rd ed.
d2(X)/dx2*X^-1 + d2(Y)/dy2*Y^-1 = 0
X(x) must be oscillatory, and I can determine X(x) by standard Fourier analysis of square wave.
If X(x) is oscillatory, d2(X)/dx2 = -k1* X -> d2(Y)/dy2 = +k1*Y, to meet laplacian(phi) = 0.
Thus, Y(y) is a linear combination of growing and decaying exponential functions in y. But, this can never satisfy Y(y_0)=0. This is my problem, am I missing something important?
Thanks,
I was thinking more about the possiblity of meeting boundary condition y(y_0)=0 with linear combination of growing and decaying exponentials in y, and even if you make the coefficients in front of growing exponentials 0, and set D*E^-K1*y = 0 at y-y_0, this implies that K1-> Infinity, which yields trivial solution for phi, namely phi==0 (double equals means identically, don't know how else to put symbols). It seems the only way to satisfy the boundary is if k1 is imaginary, making oscillatory solutions in Y(y), so that E^k1* y can be negative, in general. Does this mean that the potential can NOT be independant of z, since then 1/Z*d2Z/dz2 = H^2, so that H=(k1^2+k2^2)^0.5, for 1/X*d2X/dx2 = -k2z??
Thanks
Solved the problem!
Of course, the coefficient of the decaying exponential has to have opposite sign as that of growing exponential (sinh), and the argument is altered so that the argument is 0 at y=y_0, so you get 1 + -1 = 0 for Y(y).
1. What is the 2-D Laplace equation in rectangular coordinates?
The 2-D Laplace equation in rectangular coordinates is a partial differential equation that describes the steady-state behavior of a scalar field in two dimensions. It is written as ∇²𝑢 = 0, where 𝑢 is the scalar field and ∇² is the Laplace operator.
2. What are the applications of the 2-D Laplace equation in rectangular coordinates?
The 2-D Laplace equation has many applications in physics and engineering, including heat conduction, electrostatics, fluid flow, and diffusion. It is also used in image processing and computer graphics.
3. How is the 2-D Laplace equation solved in rectangular coordinates?
The 2-D Laplace equation can be solved analytically using separation of variables, or numerically using finite difference or finite element methods. The boundary conditions of the problem must be specified in order to obtain a unique solution.
4. What are the limitations of the 2-D Laplace equation in rectangular coordinates?
The 2-D Laplace equation assumes steady-state behavior and does not account for time-dependent processes. It also assumes that the scalar field is continuous and differentiable, which may not always be the case in real-world systems.
5. How does the 2-D Laplace equation differ from the 2-D Poisson equation?
The 2-D Poisson equation, ∇²𝑢 = 𝑓, includes a source term 𝑓, while the 2-D Laplace equation does not. This means that the Poisson equation can be used to model systems with a source or sink of the scalar field, while the Laplace equation is more suitable for problems with no such sources or sinks.
