Input Power against time graph - Flywheel rest to 300rpm
In summary, the conversation is about calculating the torque, magnitude, direction, and power required for a gearbox and flywheel system to accelerate from rest to 300 revs min-1 in 1 minute. The conversation also includes discussions about the relationship between input torque, RPM, and power, as well as the calculation of angular velocity and acceleration as a function of time. The conversation also touches on the calculation of gearbox torque magnitude and direction, and the efficiency of the gearbox.
Moranovich
Hello,
A gearbox and flywheel are as shown in FIGURE 4. The output shaft
rotates in the opposite direction to the input shaft at 5 times its speed.
The gearbox has an efficiency of 92%.
If the flywheel is solid, has a mass of 50 kg, a diameter of 1.5 m and is to
accelerate from rest to 300 revs min–1 in 1 minute:
(a) Calculate the torque required at input T1.
(b) Calculate the magnitude and direction of the torque required to hold
the gearbox stationary (holding torque Th). Show the direction of the
holding torque applied to the shaft with the aid of a sketch.
(c) Plot a graph of the input power against time when taking the
flywheel from rest to 300 revs min–1.
I am having trouble with (c) not sure how to tackle this part have all the answers for (a) and (b)
No idea please help.
Regards.
What's the relationship between input torque, RPM, and power?
Thanks for your reply.
P=T. angular velocity
I was thinking today I have worked out the input torque and input power required when the output shaft is at 300rpm so do I work out the input power from 60rpm down to 0 I.e at rest. But how can I do this if I only know the rpm eg 50,40,30etc to zero and don't know power or torque?
Where does time come in is it to do with the revolutions per minute?
Your help is much appreciated.
If your input torque is constant, then the power input is obviously going to vary as the RPM versus time. Knowing what your angular acceleration is as a function of time, you should be able to calculate angular velocity as a function of time as well as the power.
Ok so I worked out my constant acceleration from this kinematic equation
final ang speed=initial ang speed + acceleration . time using 60sec as per question for time. Then using the constant acceleration figure I changed the time in the equation to 5sec.10sec etc to work out all the angular speeds.
Now do I multiple these angular speeds against my Torque constant to get the Input power values?
Also seems to be that the equation to find the time is t=angular speed/constant acceleration
Thanks again.
You were doing fine, then you suddenly veered off the rails.
t is not found by dividing ang. vel. by ang. acc. (where did you learn that?)
t is the independent variable. The ang. acc.of the flywheel is the moment of inertia of the flywheel divided by the torque. For a constant torque, the ang. acc. is constant.
The ang. vel. as a function of time is the initial velocity (or 0 since the flywheel starts at rest) plus the ang. acc. times t. Remeber, you are being asked to make a graph of input power v. time while the flywheel accelerates to 300 RPM.
Therefore, for various t values, you need to calculate the current ang.vel. and the resulting power so that you can make this plot.
I had worked out the ang. vel for each 5 sec interval and then was messing around to check it and input ang. vel for 300rpm divided by acceleration to get the time taken. So 10pi/0.167pi = 59.98sec ...
So is how I worked out each ang. vel correct?
i.e final ang vel=initial and vel + acceleration . time
eg 10pi=0 + 0.167pi . 60
or for 20sec ang vel= 0 + 0.167pi . 20
therefore after 20s ang vel=10.49rads^-1
Then just multiple these ang. vel figures against my Input Torque figure?
When I do as you suggested -
This gives me the figure I had worked out for the Output shaft Torque not the Input shaft Torque value!
Think I am tying myself in knots ...
Disregard above I was getting confused.
So dividing my moment of inertia by Output shaft Torque = 1.91rads^-2
So initial vel 0 + 1.91 . 60s =114.6
Hello Steamking,
Thanks very much for your help the penny has finally dropped!
I think I wouldn't have got there if you hadn't of pointed me in the right direction.
Thanks again much appreciated.
Doing the same question now alas, for part B did you calculate the gearbox torque magnitude via the assumption that it dissipates 8% of the initial power?
Or just via the assumption that T(Driver) = T(Acceleration) + T(Frictional) which semi amounts to the same thing.
Moranovich said:
Hello,
Regards.
How did you work out B mate?
1. What is an "Input Power against time graph"?
An "Input Power against time graph" is a graphical representation of the amount of power being input into a system over a period of time. It allows us to visualize and analyze how the input power affects the system's behavior and performance over time.
2. How is the input power measured in this graph?
The input power is typically measured in watts (W) or horsepower (HP) and is represented on the y-axis of the graph. The input time is measured in seconds (s) or minutes (min) and is represented on the x-axis.
3. What does "Flywheel rest to 300rpm" mean in this graph?
In this graph, "Flywheel rest to 300rpm" refers to the initial state of the flywheel being at rest (0 rpm) and then being accelerated to 300 revolutions per minute (rpm) over the given time period.
4. How does the shape of the graph change as the input power increases?
As the input power increases, the slope of the graph becomes steeper, showing an increase in the rate at which the flywheel is being accelerated. The overall shape of the graph may also change, becoming more linear or curved depending on the specific system and its power requirements.
5. What can we learn from an "Input Power against time graph"?
An "Input Power against time graph" can provide valuable information about the performance and efficiency of a system. It can show us how much power is needed to achieve a certain level of acceleration and how long it takes for the system to reach a desired speed. It can also help us identify any inefficiencies or limitations in the system's power input.
