I can't get started can someone help. Kinetic Energy in term of momentum
In summary, for a Ballistic Pendulum experiment, the fractional loss during the collision can be calculated as M/(m+M) by conserving momentum and finding the change in kinetic energy.
Husker70
90
The question is this:
Expressing the kinetic energy in terms of momentum (K=1/2mv2 = p2/2m),
prove using symbols, not numbers, that the fractional loss during the collision is
equal to M/(m+M)
I'm not sure where to even begin as I don't understand it
Thanks,
Kevin
"During the collision"
You have to be more specific, what kind of collision occured?
This question was asked from a lab for a ballistic pendulum experiment
Thanks,
Kevin
Thanks,
Kevin
Hi Kevin..
Thats relatively simple.
This is a case of a Ballistic Pendulum, therefore I take it as a complete;y inelastic collision, i.e. the bullet gets embedded.
Conserve the momentum:
mv=(M+m)(v1)
Let v1 b the velocity of the pendulum when the bullet gets embedded.
v1=mv/(M+m)
now find the change in kinetic energy:
[tex]\frac{1}{2}mv^{2}- \frac{1}{2}\frac{(M+m)m^{2}v^{2}}{(M+m)^{2}}[/tex]
Simplify this to get:
Loss in KE = [tex]\frac{mMv^{2}}{2(M+m)}[/tex]
Divide this by initial Kinetic energy to get the fraction loss:
=M/(M+m)
1. What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is a scalar quantity that depends on the mass and speed of an object.
2. How is kinetic energy related to momentum?
Kinetic energy and momentum are both measures of an object's motion, but they are not directly related. Momentum is a vector quantity that depends on an object's mass and velocity, while kinetic energy depends on an object's mass and speed.
3. Can you explain the formula for kinetic energy in terms of momentum?
The formula for kinetic energy in terms of momentum is K.E. = (p^2)/(2m), where p is momentum and m is mass. This formula relates the kinetic energy of an object to its momentum and mass, showing how they are interconnected.
4. How is kinetic energy measured?
Kinetic energy is measured in joules (J) in the SI system. It can also be measured in other units such as foot-pounds (ft-lb) or calories (cal). The formula for kinetic energy can be used to calculate its value.
5. What are some real-life examples of kinetic energy in terms of momentum?
Some examples of kinetic energy in terms of momentum include a moving car, a spinning top, a bouncing basketball, and a swinging pendulum. In all of these examples, the objects possess both momentum and kinetic energy due to their motion.
