Help & advice need on how fs laser beam propergate in glass
In summary, the conversation revolved around the topic of modeling a femtosecond laser beam profile when focused on a transparent material. Jim shared his observation that the laser profile varies with polarization and wanted to verify it through modeling. The suggested approach was to look into previous research on the subject, including studies on the effect of polarization on femtosecond pulsed laser ablation and ultrashort pulsed laser ablation of thin metal films.
Jim Tan
Hi all,
can someone kindly advice on how to model a femtosecond laser beam profile when it is focus on/into a transparent material.
Regards
Jim
Science news on Phys.org
This problem has been analyzed in excruciating detail. What have you found out so far?
Hi Andy,
i did some experiment & found that the laser machined profile varies with polarziation.
Thus i want to verify my observation with some modelling, but i was unsure what are the equations & approach to this.
any suggestion or recommendation. Tks.
Then the first step is to see what other people have tried:
http://scholar.google.com/scholar?q...arization&hl=en&as_sdt=0&as_vis=1&oi=scholartC. W. Hee, B. K. A. Ngoi, L. E. N. Lim, K. Venkatakrishnan, W. L. Liang, Effect of polarization on femtosecond pulsed laser ablation of surface relief gratings using a novel interferometer, Optics & Laser Technology, Volume 37, Issue 2, March 2005, Pages 93-98, ISSN 0030-3992, DOI: 10.1016/j.optlastec.2004.02.016.
(http://www.sciencedirect.com/science/article/B6V4H-4C76CY9-1/2/845fffb5cc8bb9634c2a3255a965ff05)
The effect of polarization on ultrashort pulsed laser ablation of thin metal films
Venkatakrishnan, K. Tan, B. Stanley, P. Sivakumar, N. R.
This paper appears in: Journal of Applied Physics
Publication Date: Aug 2002
Volume: 92 Issue: 3
On page(s): 1604 - 1607
ISSN: 0021-8979
Digital Object Identifier: 10.1063/1.1487453
Date of Current Version: 18 June 2009
Hello Jim,
Thank you for reaching out for help and advice on modeling a femtosecond laser beam propagating in glass. This is a common question in the field of optics and there are a few key factors to consider.
First, it is important to understand that the propagation of a laser beam in glass depends on the material properties of the glass, such as its refractive index and absorption coefficient. These properties will determine the behavior of the laser beam as it travels through the glass.
To model the beam profile, you can use a variety of simulation software such as Zemax or COMSOL. These programs allow you to input the material properties of the glass and simulate the propagation of the laser beam. You can also adjust parameters such as the beam diameter, wavelength, and focusing conditions to see how they affect the beam profile.
Another important consideration is the nonlinear effects that can occur when using femtosecond laser beams. These effects, such as self-focusing and self-phase modulation, can significantly alter the beam profile and should be taken into account in your model.
I would also recommend consulting with other experts in the field or referring to published research on similar experiments to get a better understanding of the expected beam profile in your specific setup.
I hope this helps and good luck with your research. If you have any further questions, please don't hesitate to reach out.
Best,
1. What is an fs laser beam?
An fs laser beam is a laser beam with a pulse duration in the femtosecond range, meaning it lasts for only a quadrillionth of a second. It is often used in precision cutting, drilling, and imaging applications due to its high intensity and accuracy.
2. How does an fs laser beam propagate in glass?
An fs laser beam propagates in glass by focusing the beam into a small spot on the surface of the glass. The high intensity of the beam causes localized heating and creates a plasma, which then expands and creates a shockwave that removes material from the glass.
3. What factors affect the propagation of an fs laser beam in glass?
Several factors can affect the propagation of an fs laser beam in glass, including the laser pulse energy, pulse duration, and repetition rate. The composition and thickness of the glass, as well as the focusing lens used, can also impact the beam's propagation.
4. What are the potential applications of fs laser beam propagation in glass?
The precise and controlled nature of fs laser beam propagation in glass makes it useful for a variety of applications. These include micromachining, 3D printing, medical procedures, and high-resolution imaging techniques.
5. Are there any safety considerations when working with fs laser beams and glass?
Yes, there are several safety considerations when working with fs laser beams and glass. The high intensity of the beam can cause eye damage, so appropriate eye protection must be worn. The plasma created during propagation can also release harmful gases, so proper ventilation is necessary. Training and precautions should be taken to prevent accidental exposure to the laser beam.
  • Quantum Physics
