Can Fortran 77 still outperform highly optimized C in terms of speed?
  • Fortran
  • Thread starter dimensionless
  • Tags
    Fortran
In summary: C and Unix (and Unix is 30 years old now).In summary, the conversation discussed the speed performance of code written in Fortran 77 and C, with the general consensus that the highly optimized version of the algorithm in C is slightly faster when using g77 and gcc, while the unoptimized Fortran is faster when using MSVC++. The main advantage of Fortran 77 is its lack of pointers, which eliminates the possibility of aliasing and allows for more efficient optimization. However, modern Fortran compilers do support pointers and other extensions, making it comparable to C. The use
dimensionless
462
I have some code in Fortran 77 that executes at pretty good speed. I also have a highly optimized version of the same algorithm in C. When using g77 and gcc, the unoptimized Fortran is just slightly faster that the highly optimized C. When using MSVC++ and g77, than the C is a bit faster. This leads to my question:
If I recode my highly optimized algorithm in Fortran 77 and use a comercial Fortran compiler, will the execution speed be far and above my highly optimized algorithm that was compiled with MSVC++? If speed is an issue, should I try to compile Fortran 95 into desktop applications that are written mostly in C/C++?
Technology news on Phys.org
The question is, does one language have an advantage in translating to machine instructions?
Fortran 77 (don't know about 90/95) does have one advantage--no pointers per se. This eliminates the possibility of what compiler writers call aliasing, where the same memory location can be modified through two separate variables. If aliasing is a possibility, as in C, then the compiler needs to be more conservative to ensure correct machine code.
Put differently, Fortran 77 restricts the programmer to a subset of C that can be more easily optimized. It would seem feasible for a C programmer to restrict oneself to that subset, and have performance that's just as good.
There are methods to tell a C compiler that you are not aliasing (the restrict keyword, compiler flags).
Would you be interested/able to post your codes? I would find that enlightening, as I have never worked much in Fortran, and I've always been a bit curious about the performance differences that people claim to get. I'm also curious about your optimizations.
As for mixed language programming, F77 & C/C++ is no big deal. I've never tried F95 & C/C++, but people I respect strongly dislike it.
Fortran was the first high level language. They had the burden of proof to show that a high-level language could be competitive for preformance with assembly code, and so Fortran was the target of the largest optimization effort ever.
Comparing Fortran 77 against ansi C, I doubt that's the issue. The issue is that Fortran is totally static, the size of all datastructures is known at compile time. Once the program has loaded into memory, the stack size will not change. This allows for absolute addressing (with an offset of course) and that is very fast.
On the other hand C is stack dynamic. This allows for more flexible programming, but wasted memory and slower execution. Try declaring your C variables as static, and see if you can close the performance gap.
Note: Fortran 95 is no longer static, and so it allows for recursion and other non-Fortran nonsense.
No pointers is a big advantage, but aliasing is possible in Fortran through the use of EQUIVALENCE. This was done in the old days to make it possible to load different data structures, used at different points in the program, into the same static memory location to save space. In Fortran 95 the use of Equivalence is deprecated.
Static vs dynamic storage allocation has nothing to do with the speed difference (and for modern compilers, there IS no speed difference worth botherig about).
Professional Fortran compilers have NEVER implemented just the ANSI language standard, so long as I've been using them (about 40 years). There is a de facto set of extensions which every serious compiler supports. If it didn't support them, it would be unmarketable, because most serious existing Fortran programs already use the extensions.
Those extensions have included stack-based and heap-based memory allocation, recursive functions and subroutines, pointers, etc, ever since those things were "popularised" by C and Unix (and Unix is 30 years old now).
If you knew anything about compiler writing, you would know that there is no overhead for stack-based storage allocation compared with static, and no wasted memory either. In fact on modern hardware, stack-based allocation is usually more efficient.
The main historical reason why C got a reputation of being slow compared with Fortran was simply that the early C compilers did no optimisation. In some senses, C was originally designed as a human-readable machine-independent assembler language, that was trivial to compile onto the sort of hardware that was being built in 1970 (when a typical computer had 0.0001 Gbytes of memory, and 0.0001 GHz CPU speed). For example, on the early C compilers it was quite common for a loop written using pointers to run much faster than the same loop written using array subscripts, because the compiler didn't even try to move the repeated address-calculation code out of the loop. With modern compilers (built after compiler-writing had been transformed from a task requiring genius to something teachable to any average system programmer) that is no longer relevant.
Another stimulus to Fortran optimisation was the vector-architecture machines of the 1980s (Cray, CDC, etc). They taught Fortran programmers to build software that could use that architecture efficiently, and the same code can be optimised easily on modern fast scalar machines.
I have quite figured out aliasing and the restrict keyword, but I've seen improvement in both the inefficient Fortran and the efficient C by using the -O3 flag with gcc and g77. The C code is faster, but still not nearly as fast as I would expect. I'll have to do more coding to really do a good comparison.
No aliasing is a compiler optimization switch with Microsoft compilers, allowing "maximum" optimization.
C is closer to machine code than Fortran, so with enough effort, a programmer should be able to generate the same or faster code, but it could end up being an exercise of trial and error to get the compiler to generate the code you want.
I'm not aware of any C compilers that have the extensions / optimizations that some Fortran Compilers have to take advantage of hardware features like vector / parallel / pipeline / out of order processing / register scoreboarding oriented operations on super computers, where IBM and Cray still remain relatively popular at the very high end: http://www.top500.org/lists/2006/11
Regarding a PC, I'm not sure how much "hardware specific" optimizations there are in existing Fortran or C/C++ compilers. A good compiler might auto-generate mult-threaded code, take advatange of out of order intruction handling on CPU's with register scoreboarding, or auto-generate multi-threaded code.
Both GCC and Intel compilers have intrinsic support, including vector instructions like SSE and Altivec. I would be surprised if there were any serious C compiler today that didn't. In fact, failing to have such support would be part of the definition of a non-serious compiler.
Not sure what you mean by "parallel" (in "vector / parallel / pipeline"). Do you mean superscalar issue? That is a hardware feature, not a software feature, beyond not emitting an instruction stream that inhibits multiple issue.
Out of order processing is similar: the compiler/assembly programmer does not do out of order processing. The order that's "out of" is the order in which instructions were laid down by the compiler. It's hardware that decides to execute out of order in order to compensate for unpredictable run time latencies (cache misses). The compiler can't do that, for the obvious reason that cache state is unknown at compile time.
Not sure what you mean by "on super computers", as most supercomputers nowdays are massively parallel assemblies of Opterons, Itaniums, and similar commodity (more or less) chips. All decent C/C++/Fortran compilers pay attention to register allocation, etc. In fact, I suspect that a lot of compilers first generate an abstract representation of the code, and then use that to generate instructions, schedule them, and allocate registers. This has nothing to do with the initial language.
As in massively parallel.
Ones that include more high end oriented vector processing similar to that implemented on the Cray 1 and later machines, including the current ones. As noted in the link below, "vectorizing and parallelizing compilers for Fortran existed", but each machine type had a different version of the compiler.
Massively parallel systems, based on microprocessor chips, have an issue with microsecond or longer latency on communcations between cpu's, just because of the length of the wires. Some problems are solved more quickly with the high end vector oriented type computers.
http://en.wikipedia.org/wiki/Supercomputer
From the link below, Fortran "is the primary language for some of the most intensive supercomputing tasks, such as weather and climate modeling, computational fluid dynamics, computational chemistry, quantum chromodynamics, simulations of long-term solar system dynamics, high-fidelity evolution artificial satellite orbits, and simulation of automobile crash dynamics."
http://en.wikipedia.org/wiki/Fortran
From the same link on Fortran, regarding extensions: "Vendors of high-performance scientific computers (e.g., Burroughs, CDC, Cray, Honeywell, IBM, Texas Instruments, and UNIVAC) added extensions to Fortran to take advantage of special hardware features such as instruction cache, CPU pipelines, and vector arrays." My understanding is that similar extensions are still used on the current high end supercomputers.
Again from the same link on Fortran: a reference to the "out of ordering" done by a compiler from the 1970's (date not mentioned in article): "one of IBM's FORTRAN compilers (H Extended IUP) had a level of optimization which reordered the machine language instructions to keep multiple internal arithmetic units busy simultaneously".
So the main reason "Fortran is so fast", is that speed is one of the goals of Fortran compilers. To this end, the scientific community willingly accepts machine specific extensions to the language.
I was unaware that "high-end" vector machines with vector units as wide as the old Crays were still in widespread use. Can you point to any examples?
Some codes do not scale well to MPP. Various solutions have been pursued, including replacing with algorithms that do scale well, and doing nothing and getting poor performance.
Any data to support that in 2007? I'm sure it was true 20 years ago, not sure it's true today.
As I pointed out, all serious C/C++ compilers have such extensions for their target platforms. Do you really think Fortran compiler writers are the only people who think about these things? I think you may safely assume that any tricks known to Fortran compiler writers just as well known to C compiler writers, whatever the case may have been 30 years ago.
That's different from what is usually understood by "out of order execution" today. In many of today's CPU's, the front end can dynamically reorder the instruction stream to hide memory latencies.There's nothing remotely related to Fortran in that. As to your understanding of the term, there is nothing unique to Fortran in reordering the instruction stream for optimal performance. All decent C compilers in 2007 do that.
I don't believe that. Speed is a goal of compilers for many languages, not just Fortran. The main reason Fortran 77 used had a speed advantage for an average scientific programmer was that the language restricted users to an easily optimized subset of C. To write C code as good, you had to know what you were doing (that may still be true today.)
Can all C/C++ programs be coded in such a way that they are just as fast as Fortran?
Are Fortran 2003, 95, 90 just as fast as 77?
Yes, at least in the trivial sense that you can take the assembly output from the Fortran compiler and inline that in C/C++, and it's a valid C/C++ program.
I haven't seen an example of a Fortran code that could not be done as well in C/C++, given mature compilers for both. I would welcome such an example, of anyone has one.
I think the problem is that there are a lot more ways to hobble performance in C/C++ than Fortran 77: the space of possible programs is significantly larger given OO, templates, the equivalence of arrays and pointers, the lack of built-in multidimensional arrays, etc. You have to know more about what you're doing to avoid those traps.
Really, it's not that hard to have good performance in C++ for numerical codes. Whatever language you're using, it's far more important to understand the target architecture, and how your compiler interacts with your code to produce an instruction stream for that architecture. You have to think about data locality (what fits in cache), getting as many ops per load, branch elimination/prediction, etc.
I don't know about later flavors of Fortran. I've heard Fortran programmers complain about performance of F77 codes degrading as they go to newer F95 compilers. But I don't know anything systematic about it.
Cray X1, X1E, X2. http://en.wikipedia.org/wiki/Cray_X1.
Fortran still in use for ...
It's a current Wiki ariticle. Do a web search for Fortran to find other similar references. Part of this is the time it would take to convert existing code over to C/C++.
nmtim said:
Fortran faster than C ... To this end, the scientific community willingly accepts machine specific extensions to the language.
My point is that it is the extensions that allow Fortran to run faster, not so much something inherent in the language. I've since noted that the C compilers for the Super Computers also have similar extensions (as with the Cray X1 / X2 examples I posted about previously).
The IBM pSeries POWER5 and POWER6 gear are essentially vector machines. Rather than throwing a vector unit on each processor, multiple processors in the system act as the vector unit. One can setup calculations in such away on the POWER5 and POWER6 that when a calculation is completed in foo set of processors, the calculation is checked against what bar set calculated for accuracy.
The advantage of true vector machines is that the operands are available in quckly accessable registers, as opposed to other cpus which involves a longer transfer rate. The CDC Star could do vector math at the rate of the memory bandwidth, but the later Cray machines did this with registers. As previously mentioned, the Intel SSE has parallel floating point register based operations, but they're 32 bit floating points operands, as opposed to the higher precision operands on the high end vector machines.
Is Cray the last "holdout" still making true vector machines?
Jeff Reid said:
...the Intel SSE has parallel floating point register based operations, but they're 32 bit floating points operands...
You are poorly informed. SSE has had support for IEEE 754 double precision vector operations since SSE2; these and similar instructions, like Altivec on Power, are implemented on the major Intel, AMD, & IBM platforms used by the bulk of HPC. And before you drag out your next false explanation, yes, C/C++ compilers give full access via intrinsics to these instructions.
Cray is not the last holdout making true vector machines. No one is, because memory bandwidth is too poor and managing the cache too complex. You're better off spending your transistor budget running more ops on narrower vectors at higher frequency. The newer Crays use Opterons, with 128 bit vector units. Again, your information is out of date.
While I'm up, on the subject of intrinsics (compiler extensions that expose hardware functionality not addressable by the language), you make the claim that Fortran is faster because it has these. But, as I pointed out previously and even you have acknowledged, C compilers have these extensions, too. So if C has the same extensions, how can Fortran be faster than C by virtue of these extensions?
And as I said before, but you seem to not comprehend, ALL decent C++ compilers offer these extensions on their target platforms. And even if they did not (note that they do!), C++ programmers could always inline some assembler while taking advantage of compiler extensions that defer register allocation and instruction scheduling to the optimizer. Compiler extensions are not a differentiating factor in performance.
nmtim said:
SSE 32 bit precision
My mistake, it's 64 bits as you stated. I meant to edit this, but I didn't get back to this thread in time (the edit option was no longer available).
"The Cray X1E supercomputer combines the processor performance of traditional vector systems with the scalability of microprocessor-based architectures."
http://www.cray.com/products/x1e/index.html
I've read that there will be a follow on to this, a Cray X2. The USA govement partially funds this line of supercomputers, so there still must be some need for "traditional vector systems".
It shouldn't be, but I wonder if mathematical algorithms involving exponentiaion implemented as native Fortran operators, versus the same algorithms implemented using the pow...() function calls instead of a language native exponentiation operator in C or C++ would result in identical optimization.
I'm still under the impression that a significant part of scientific programming is still done in Fortran, probably because of a large amount of code already exists and the cost of conversion would be high.
For the Crays, one thing is that their Fortran compiler is simply better than their C compiler (and much better than their C++ compiler); the C compiler often needs a lot of help to recognize how to take advantage of the vector registers.
Just to put in some info. Nearly all of the code I worked on, as well as those in my group, was written in either F77 or F90. This was about 2 years ago at Sandia National Labs. I ended up writing my thesis code in C++ but everything else we did was in F77. Basically it seemd that most people who were doing simultaion experiments(potts/monte carlo) used Fortran. I guess when you're doing quite simple calculations, but billions upon billions of them, and if your code can be 10% faster, that's a day or two off of simulation time.
Our code was written for both single processor computers (sooo slow) or on our clusters. And they still took up to a week. (materials simulation).
Hurkyl mentions that Cray's Fortran compiler is better than it's C compiler. I'm not sure if there's some inherent advantage in Fortran, or Cray simply put more effort into the Fortran compiler because it's what most of it's target audience (programmers) uses.
Is anyone aware of a machine where the C compiler produces faster code than the Fortran compiler (assuming inline assembler isn't used)? Intel might be a good candidate.
Maybe someone could post a list of real differences between C and Fortran. I can only think of these:
Fortran doesn't have to be re-entrant, which should help global optimization.
Fortran has an exponentiation operator, but a C extension could do the same.
I think the only real advantage inherent to Fortran is that it's easier to write a Fortran optimizer, especially for vector optimization. I do get the impression that there has also been less effort. But to be fair, it's only relatively recently that people figured out how to use C++ effectively for high-performance applications.
I'm doubt the example of the older Crays (with the 64 element vector, where the compiler and/or a capable programmer was really crucial) is significant anymore. Looking at Cray in the top 500, there are 4 X1/X1E's in the top 500. The aggregate theoretical peak of the four would come in about #15. Most of the newer or more powerful Crays are XT3/4, running Opterons. For better or worse, x86-64, Power5, and Itanic is where the action is right now.
http://www.top500.org/sublist"
Overall, there are a lot more programmers writing C/C++ than Fortran on x86 (at least serial code), so I would expect Intel in particular to emphasize C++. But if you write a decent C compiler, you will have solved all the problems (I think) on the road to a decent F77 compiler. Converse doesn't hold.
There are niche (from scientific compute perspective) platforms without Fortran compilers. GPUs, Cell. These might become a lot more visible in the next few years--they offer order of magnitude or more greater FP throughput per $ and per W compared to "normal" server/desktop CPUs. If so, Fortran compilers will follow. Right now, they're C domains, but I think I properly extended Fortran compiler would do fine.
Fortran doesn't have to be re-entrant...
Nor does C.
Yet, Cray is making an X2 with government subsidy, so it's important to some. For some problems, classic vector machines are useful.
1. Why is Fortran known for being a fast programming language?
Fortran is known for being a fast programming language primarily because of its efficient and optimized code generation. It is specifically designed for scientific and numerical computing, making it well-suited for complex calculations and data manipulation. Additionally, Fortran has a strict and consistent syntax, which allows for its compiler to optimize the code and produce faster execution times.
2. How does Fortran differ from other programming languages in terms of speed?
Fortran differs from other programming languages in terms of speed due to its optimized code generation and specific focus on scientific computing. Unlike other languages that may prioritize versatility and ease of use, Fortran is designed to prioritize performance, making it a top choice for high-performance computing applications.
3. Can Fortran be used for non-scientific applications and still maintain its speed?
Fortran can be used for non-scientific applications, but it may not necessarily maintain the same level of speed as it would for scientific applications. While Fortran is optimized for scientific computing, it can still be used for other purposes. However, certain features and optimizations may not be applicable for non-scientific applications, which could impact its speed.
4. Are there any drawbacks to using Fortran for speed-critical applications?
While Fortran is known for its speed, it may not be the best choice for all types of speed-critical applications. For example, Fortran may not be as well-suited for applications that require extensive graphics or user interfaces. Additionally, since Fortran is a compiled language, it may have longer development and debugging times compared to interpreted languages.
5. How can I optimize my Fortran code to make it even faster?
To optimize your Fortran code and make it even faster, there are a few key strategies you can employ. These include utilizing compiler options and directives, using efficient algorithms and data structures, and minimizing unnecessary calculations and data transfers. It is also important to regularly test and benchmark your code to identify any potential bottlenecks and areas for improvement.
12K
