Problem with understanding the definition of magnetic flux.
In summary, the conversation discussed the definition of magnetic flux and how it is calculated by multiplying magnetic field strength by the area. The units for magnetic field strength can be represented as lines per square metre or Webers per square metre, with 1 Weber per square metre now known as 1 Tesla. Magnetic flux is also known as flux density and is given in Webers, with the formula being Flux = B x A. The conversation concluded by noting that the units in magnetism can be difficult to understand.
kapitan90
33
Probably a silly question, but I can't figure it out.
Why is magnetic flux defined as magnetic field strength per unit area if it is found by multiplying the strength of magnetic field B by area A rather than dividing by area A?
Thanks for any responses :)
I think you have your terms confused. You know that a magnetic field can be represented by lines of force?
The closer the lines are the stronger the force and therefor a 'sensible' unit for magnetic FIELD STRENGTH would be 'lines per square metre'
Historically 'lines' were called Webers and therefore magnetic field strength can be given as Webers per square metre. 1 Weber per square metre is now called 1 Tesla so magnetic field strength is given in Tesla.
Magnetic field strength is also known as 'magnetic flux density' and the symbol is B.
Magnetic FLUX is flux density x Area and is given in Webers
Flux = B x A
Hope this helps .... The units in magnetism are not very user friendly
I understand now, thanks for help!
1. What is magnetic flux?
Magnetic flux is the measure of the amount of magnetic field passing through a given area. It is represented by the symbol Φ and is measured in units of webers (Wb).
2. How is magnetic flux different from magnetic field?
Magnetic flux and magnetic field are related but different concepts. While magnetic field measures the strength of a magnetic field at a specific point, magnetic flux measures the amount of magnetic field passing through a given area.
3. What causes a problem with understanding the definition of magnetic flux?
One common problem with understanding the definition of magnetic flux is that it is a relatively abstract concept that is not directly observable. Additionally, the mathematical equations used to calculate magnetic flux can be complex and difficult to understand.
4. How is magnetic flux calculated?
Magnetic flux is calculated by multiplying the magnetic field strength (measured in teslas) by the area (measured in square meters) that the magnetic field passes through, and then taking the cosine of the angle between the magnetic field and the surface area.
5. What are the practical applications of magnetic flux?
Magnetic flux has a variety of practical applications, including in the design and operation of electric motors and generators, magnetic storage devices, and magnetic resonance imaging (MRI) machines. It is also used in scientific research and experiments to study magnetic phenomena.
  • Classical Physics
