How do we know it's not some kind of attraction?
  • Thread starter scijeebus
  • Tags
    Attraction
In summary, the conversation discusses the Casimir effect, which is an experiment that measures the force between two closely placed plates and compares it to the expected gravitational and electromagnetic forces. The result is a much larger force, leading to the conclusion that either the Casimir effect is at work, or there is a new, unknown force. The behavior of electromagnetic forces at the nanometer scale is well understood, making it unlikely that this unknown force is related to electromagnetism. However, the conversation also questions the accuracy of current scientific assumptions and theories.
scijeebus
40
I can't remember what the experiment is called, but it was to test for virtual anti-pair particles, and two plates where put together so close that at certain energies of virtual pairs should be excluded, thus creating a difference of pressure as to push the plates closer together. But when you have things that close together, how do we know it's virtual particles and not anything to do with the electro-magnetic force in any way shape or form or perhaps even weak gravitational attraction?
You are talking about the Casimir effect, I think?
We know the masses of the plates, so we can calculate the expected gravitational force between them (very damn small). And likewise we can measure and control the electric charges on the two plates, so we can calculate the expected electromagnetic forces between them (much larger, but still very small). And then we measure the actual force between them, and we find that it's much larger than either and consistent with the predicted Casimir effect.
So we put all of this together, and we conclude that EITHER:
1) We've observed the Casimir effect; OR
2) We've observed some unknown effect. It might be that gravity or electro-magnetic forces behave differently at very small separations so our "expected" forces are wrong, or there might be some new and hitherto unknown force at work here.
We can't ever completely exclude #2, but because we haven't seen any evidence of this hypothetical unknown effect in other experiments, and because what we have is consistent with the Casimir explanation, it's natural to go with #1 unless and until there's evidence to the contrary.
One caveat: the stuff above makes it all sound a lot easier than it really is. The experiments that demonstrate the Casimir effect are hard to do and easy to screw up. Getting to where we're really sure of our results can be a lot of work and take a long time.
Ok, the proximity you would have to bring plates close enough together to exclude something as small a virtual particle is way more than enough for the EM force AND gravity to bring the plates close enough together. We're talking about nano-meters here, less than that even, how wouldn't that be other forces? The EM force that holds electrons to a nucleus is a lot stronger than just 1 nano-meter, even for a single proton.
Yes, we agree that gravitational and/or electromagnetic forces can draw two objects that are very close even closer.
But the point is that we can calculate the strengths of these forces, and we can measure the actual force between the plates. If the measured force is much greater than the calculated forces... Then we know that something other than the gravitational and electromagnetic forces as we understand them today are producing the measured force.
It's worth noting that the behavior of electromagnetic forces as the nanometer scale is pretty well understood. The people who design and build computer chips would definitely have noticed, big time, if gravity or electromagnetism behaved differently at those scales.
You're going to have to fix that last sentence before i'll be able to understand it... I don't understand how a force can be stronger than a nano-meter, which is a distance.
No, I don't think they would notice necessarily, it's a small and virtually immeasurable realm of the strangest properties of the universe. If someone as smart as Newton can be wrong about something as simple as gravity's speed, I'd hate to think how wrong people could be making all these assumptions of the existence of such outlandish things.
I don't really need to fix it that much, maybe I need to add the word "range", but otherwise there's plenty of instances where scientists measure a force as so small they consider it 0. True, Pluto's gravity does reach Earth, but it's so small scientists consider it 0 on Earth. Even with particle probability, eventually a particle's probability becomes so small scientists just treat the range as 0. But, this is does not happen with the EM force of a subatomic particle for at least a few nano-meters.
1. How do we know that what we are feeling is not just physical attraction?
Scientists have conducted numerous studies and experiments to understand the difference between physical and emotional attraction. They have found that physical attraction is primarily based on physical appearance, while emotional attraction involves a deeper connection and understanding of the other person's personality, values, and beliefs. Additionally, physical attraction tends to fade over time, while emotional attraction can grow stronger.
2. Is it possible to mistake infatuation for emotional attraction?
Yes, it is possible to mistake infatuation for emotional attraction. Infatuation is a strong, intense feeling of attraction towards someone, but it is often based on superficial qualities and can fade quickly. Emotional attraction, on the other hand, involves a deeper connection and understanding of the other person, and it can develop over time.
3. Can emotional attraction exist without physical attraction?
Yes, emotional attraction can exist without physical attraction. While physical attraction is often the first thing that draws people together, emotional attraction is what keeps them connected and interested in each other in the long term. Emotional attraction involves a deeper understanding and connection on an emotional and intellectual level, rather than just physical attraction.
4. How do we differentiate between emotional attraction and love?
Emotional attraction and love are often used interchangeably, but they are not the same. Emotional attraction is a strong connection and understanding of someone on an emotional and intellectual level, while love involves deeper feelings of care, commitment, and intimacy. Emotional attraction can lead to love, but it is just one aspect of a loving relationship.
5. Can emotional attraction change over time?
Yes, emotional attraction can change over time. As people change and grow, their emotional needs and desires may also change. This can impact the level of emotional attraction they feel towards someone. Additionally, external factors such as stress, communication issues, and conflicts can also affect emotional attraction. It is important to continuously nurture and cultivate emotional attraction in a relationship to maintain a strong connection with your partner.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
