Strange results using dgesv (lapack) via fortran 90
In summary: OF PROGRAMIn summary, the conversation is about someone trying to learn Fortran 90 by rewriting MATLAB codes into Fortran. They are specifically working on a linear, 1D finite element code for an elliptic equation and are having trouble getting the same solution from the code in Fortran and MATLAB. They have verified that the arrays used in both codes are the same, and another person suggests using LAPACK routines to check for errors. The conversation ends with someone successfully solving the linear matrix equation using DGESV.
cjm2176
Hello all,
I am trying to learn fortran 90 by rewriting some simple MATLAB codes I have in fortran.
I tried to rewrite a linear, 1D finite element code for an elliptic equation and my fortran and MATLAB codes both end up assembling the same system matrixes (K and f), but the solution to the linear system I am getting by calling dgsev in fortran makes no sense.
heres what I get using dgsev
5.84805285111992524E-295
-5.75492768302598656E+018
-2.50280951573243828E-214
2.50555212078780657E-292
-0.0000000000000000
-0.0000000000000000
-9.67185004345343066E+025
-9.67140655691703340E+025
-0.0000000000000000
and from matlab
5.0000000000000000
4.3750000000000000
3.7499999999999991
3.1249999999999991
2.5000000000000000
1.8750000000000000
1.2500000000000000
0.62500000000000000
0.0000000000000000
I am lost on this one, any ideas?
Thanks!
cjm2176
  • FEMelliptic.txt
Technology news on Phys.org
Your code is very difficult to read, at least using Notepad in Windows 7. I have pasted it into [ code] and [ /code] tags (without the leading spaces) below.
Code:
program FEMelliptic
implicit none
!declarations
real(kind = kind(0.0d0)), parameter :: T = 1.0d0, force = 0.0d0, L = 1.0d0, uL = 5.0d0, uR = 0.0d0
integer, parameter :: nnp = 9
integer, parameter :: nel = nnp - 1
integer :: node, I, el, j, info
real(kind = kind(0.0d0)), dimension(nnp,1) :: f, d, n_bc, P, node_x, e_bc, bc
real(kind = kind(0.0d0)), dimension(2,1) :: fe
real(kind = kind(0.0d0)), dimension(2,2) :: ke
real, dimension(nnp-1,2) :: connec
real, dimension(nnp,nnp) :: K
real :: ans
real(kind = kind(0.0d0)), external :: ddot, dscal
integer, dimension(2,1) :: connec_el
integer, dimension(nnp) :: ipiv
!set bcs
bc(1,1) = 2.0d0
e_bc(1,1) = uL
bc(nnp,1) = 2.0d0
e_bc(nnp,1) = uR
!initialize system matrices
K(:,:) = 0.0d0
f(:,1) = 0.0d0
d(:,1) = 0.0d0
!Mesh information
!node coords
do node = 1, nnp
	node_x(node,1) = L*real(node-1)/(nnp-1)
end do
!connectivity
do I = 1, nel
	connec(I,1) = I
	connec(I,2) = I+1
end do
!assemble FE matrixes
do el = 1, nel
	connec_el(1,1) = connec(el,1)
	connec_el(2,1) = connec(el,2)
	call element_matrix(el, ke, fe)
	do j = 1, 2
		do i = 1, 2
			K(connec_el(i,1),connec_el(j,1)) = K(connec_el(i,1),connec_el(j,1)) + ke(i,j)
		end do
	end do
	do j = 1, 2
		f(connec_el(j,1),1) = f(connec_el(j,1),1) + fe(j,1)
	end do
end do
!apply bcs
do i = 1, nnp
	if (bc(I,1) == 2.0d0) then
		f(:,1) = f(:,1) - K(:,i)*e_bc(i,1)
		K(i,:) = 0.0d0
		K(:,i) = 0.0d0
		K(i,i) = 1.0d0
		f(i,1) = e_bc(i,1)
	end if
end do
!solve linear system
call dgesv(nnp, 1, K, nnp, ipiv, f, nnp, info)
write(*,*) f
contains
!compute element matrixes
subroutine element_matrix(el, ke, fe)
implicit none
integer, intent(in) :: el
real(kind = kind(0.0d0)), dimension(2,2), intent(out) :: ke
real(kind = kind(0.0d0)), dimension(2,1), intent(out) :: fe
real(kind = kind(0.0d0)), dimension(2,1) :: w, gp, xe
real(kind = kind(0.0d0)), dimension(1,2) :: B, N, ff
real(kind = kind(0.0d0)), dimension(2,2) :: c
real(kind = kind(0.0d0)) :: he, Jac, alpha
integer :: i, j
ke(1:2,1:2) = 0.0d0
fe(1:2,1) = 0.0d0
xe(1,1) = node_x(connec_el(1,1),1)
xe(2,1) = node_x(connec_el(2,1),1)
he = abs(xe(1,1)-xe(2,1))
Jac = he/2
w(1,1) = 1.0d0
w(2,1) = 1.0d0
gp(1,1) = -0.577350269189626d0
gp(2,1) = 0.577350269189626d0
do i = 1, 2
	call Nmatrix_lin (gp(i,1), N)
	call Bmatrix_lin (he, B)
	alpha = w(i,1)*T*Jac
	c = w(i,1)*T*Jac*matmul(transpose(B),B)
	ke = ke + c
	alpha = w(i,1)*force*Jac
	do j = 1, 2
		ff(1,j) = N(1,j)*alpha
	end do
	fe = fe + transpose(ff)
end do
end subroutine element_matrix
!shape functions
subroutine Nmatrix_lin (psi, N)
implicit none
real(kind = kind(0.0d0)), intent(in) :: psi
real(kind = kind(0.0d0)), dimension(1,2), intent(out) :: N
N(1,1) = .5d0*(1.0d0-psi)
N(1,2) = .5d0*(1.0d0+psi)
end subroutine Nmatrix_lin
!derivatives of shape functions
subroutine Bmatrix_lin (he, B)
implicit none
real(kind = kind(0.0d0)), intent(in) :: he
real(kind = kind(0.0d0)), dimension(1,2), intent(out) :: B
B(1,1) = -1.0d0/he
B(1,2) = 1.0d0/he
end subroutine Bmatrix_lin
end program FEMelliptic
You are solving a linear matrix equation Ax=b. Have you verified that A and b have the same values in both cases?
Yes they are the same, would it help if I posted these arrays?
Sure, I have LAPACK routines and could check it. Tab or space delimited text file would be great.
the arrays are attached
  • K.txt
  • f.txt
Looks pretty straightforward (K is tri-diagonal). Just for kicks I used Excel matrix functions and got the expected answer. I'll try it tonight w/ LAPACK.
DGESV worked perfectly for me. There must be some error in your program.
Code:
PROGRAM PF
IMPLICIT NONE
INTEGER          NIN, NOUT, NMAX, LDA, I, IFAIL, INFO, J, N
PARAMETER        (NIN=5,NOUT=6, NMAX=10)
PARAMETER        (LDA=NMAX)
INTEGER          IPIV(NMAX)
REAL (KIND=8)    A(LDA,NMAX), B(NMAX)
OPEN (NIN,file='PF.TXT',STATUS='OLD')
OPEN (NOUT,file='OUT.TXT',STATUS='OLD')
READ (NIN,*) N
READ (NIN,*) ((A(I,J),J=1,N),I=1,N)
READ (NIN,*) (B(I),I=1,N)
WRITE (NOUT,*) 'MATRIX A'
DO I=1,N
WRITE (NOUT,*) (A(I,J),J=1,N)
END DO
WRITE (NOUT,*) 'VECTOR B'
WRITE (NOUT,*) (B(I),I=1,N)
CALL DGESV(N,1,A,LDA,IPIV,B,N,INFO)
WRITE (NOUT,*) 'RESULT'
CLOSE (UNIT=NOUT)
CLOSE (UNIT=NIN)
!N =  9
!MATRIX A
!1. 0. 0. 0. 0. 0. 0. 0. 0.
!0. 16. -8. 0. 0. 0. 0. 0. 0.
!0. -8. 16. -8. 0. 0. 0. 0. 0.
!0. 0. -8. 16. -8. 0. 0. 0. 0.
!0. 0. 0. -8. 16. -8. 0. 0. 0.
!0. 0. 0. 0. -8. 16. -8. 0. 0.
!0. 0. 0. 0. 0. -8. 16. -8. 0.
!0. 0. 0. 0. 0. 0. -8. 16. 0.
!0. 0. 0. 0. 0. 0. 0. 0. 1.
!VECTOR B
!5. 40. 0. 0. 0. 0. 0. 0. 0.
!RESULT
!5. 4.375 3.7499999999999996 3.124999999999999 2.5 1.875 1.25 0.625 0.
END
1. Why am I getting strange results when using dgesv (lapack) with Fortran 90?
There could be a few reasons for this. One possibility is that there are errors in your code, such as incorrect indexing or data types. Another possibility is that your input data is not properly formatted or contains errors. Additionally, there may be issues with the accuracy or precision of the dgesv function itself.
2. How can I troubleshoot and fix the strange results I am getting?
First, double check your code for any errors or mistakes. Next, carefully review your input data to ensure it is correctly formatted and does not contain any errors. You may also want to try using different input values to see if the results change. If the problem persists, you may need to adjust the parameters or settings of the dgesv function or consider using a different algorithm or approach.
3. Can the issue be caused by compiler or platform differences?
Yes, it is possible that the strange results could be caused by differences between compilers or platforms. Make sure you are using a reliable and up-to-date compiler and that your code is compatible with the platform you are using.
4. Are there any common mistakes or pitfalls when using dgesv with Fortran 90?
Some common mistakes when using dgesv include not properly initializing variables, using incorrect data types, or not accounting for data indexing. Another potential pitfall is not checking for errors or warnings returned by the dgesv function, which could indicate issues with the input data or the function itself.
5. Is there any additional documentation or resources available for troubleshooting dgesv in Fortran 90?
Yes, there are many resources available for troubleshooting issues with dgesv in Fortran 90. You can consult the official documentation for the function, as well as online forums and communities where other users may have encountered similar issues. Additionally, reaching out to experts or colleagues who are familiar with Fortran and lapack may also be helpful in finding a solution.
10K
