Mass gets cancelled out on downhill slope
In summary, the concept of mass cancelling out in a downhill skiing problem is based on the equal acceleration of objects in a gravitational field and the equivalence of inertial and gravitational mass. This can be seen through the equations of force, acceleration, and normal vector, and can also be understood intuitively by imagining two skiers of equal mass holding hands while skiing. The math behind this concept is derived from these simple, intuitive ideas.
e-zero
58
I'm looking at a general problem in which a skier is going downhill. I understand 'mathematically' how the mass will cancel out of the final equation when calculating the acceleration, but I don't understand this 'conceptually'. Can anyone describe?
Start by reading through https://www.physicsforums.com/showthread.php?t=511172 from the "General Physics" forum, see if that helps. If not, come back and ask again :smile:
I would not say that mass cancels out in the 'final equation' I would say that it cancels out right at the beginning: The gravitational force is [itex]F=-GmM/R^2[/itex] while acceleration satisfies a= F/m so that a= -GM/R^2. That includes the mass of the Earth but not the skier's mass.
If we were to include friction, that might not be true. What equations are you talking about?
The conceptual idea is that all masses accelerate the same in a gravitational field, which is a consequence of the equivalence of inertial mass and gravitational mass.
The whole thing is much more intuitive and elegant in general relativity, where inertial motion is replaced by geodesic motion through a curved background geometry.
Ok, I might as well post the question: A skier has begun descending a 30deg slope. Assuming the coefficient of kinetic friction is 0.10, calculate the skier's acceleration.
The diagram shows that the 30deg angle is at the bottom of the slope where the slope meets the ground.
Forumlas for force of gravity on skier:
Fgx = mg sinθ
Fgy = -mg cosθ
Normal vector gets calculated to:
Fn = mg cosθ
Net Force equations are:
mg sinθ - μk Fn = m ax
Fn - mg cosθ = m ay = 0
(ax and ay are the x and y components of acceleration)
Therefore we can solve for 'm ax':
mg sinθ - μk(mg cosθ) = m ax
(This is the step where 'm' (mass) cancels out)
So I get how this is done mathematically, but I wanted a conceptual understanding of why the mass cancels out in this example. Any input?
What was wrong with the answers so far?
Actually after looking at the examples again, I kinda of get it and I realize the ideas and formulas in the examples is what I will be learning more of in the following chapters.
That's likely - though you've already met F=mg close to the Earth's surface.
All that's happened here is that all the forces are proportional to m.
But imagine the skier is towing a toboggan by a long rope, and the rope is looped around a tree uphill so when the skier travels a distance x downhill, the toboggan goes a distance x uphill. The skier mass is M and the toboggan mass is m < M. Now do the math.
Note:
on your specific problem description - you did well, but you should specify the x and y directions as well.
i.e. "+x is downhill along the slope"
HallsofIvy and HomogenousCow have given the answer, but it is so important I want to tell you to read their posts carefully. Imagine what would happen in HallsofIvy's equations if the "m" in the law of universal gravitation were different from the "m" in the second law of motion. The former is what HomogenousCow calls "gravitational mass" and the latter is the "inertial mass". The equality of inertial and gravitational mass is called the "weak equivalence principle".
The one qualification to make is that for the cancelling out, we assume that one of the masses is very much less than the other, so that to excellent approximation the small mass can be thought of as "falling freely" in the gravitational field of the larger mass, but the larger mass is not affected by the gravitational field of the small mass. So things will be more complicated if the two masses are more equal.
All the responses here seem to rely on the math, but the concept here is really simple even if you don't know the equations that govern this system. In fact, the equations come from simple intuitive intuitive concepts, rather than the other way around.
To explain, if you have two skiers the same mass on the same skis skiing next to each other, of course they go the same speed down the slope. Then imagine they hold hands. You can now think of them as one skier with twice the mass — and they're going the same speed.
Now you might complain that they're on four skis instead of two. So imagine just one skier again, and imagine she alternates between skiing on both skis and skiing on only one. Now, this doesn't work perfectly (because the pressure actually changes the coefficient of friction by changing the heat transfer and the way the skis alter the crystals in the snow), but the basic idea is that there's *half* the surface area to slow the skier down, but there's *twice* the normal force. So those cancel out.
So put it together, and have two skiers, each on one ski, holding hands, and their speed is the same as for one skier twice the weight on two skis, or each individual skier on two skis, or each individual skier on one ski.
tl;dr: Imagine two skiers holding hands.
@AlyssaSkier: excellent debut post - welcome to PF.
It is easy to get caught up in the math when you live in the physics world - you can neglect other forms of communication.
The picture you provide shows that it "aught to be" intuitive that the acceleration does not depend on the mass of the skier, but does not show the concept behind how that comes to be the case nor does it necessarily lead the the "m"'s cancelling out in the algebra in the manner asked about in post #1. I suspect that is why everyone opted for "inertial mass is the same as gravitational mass" as the statement of underlying concept.
It's also common in beginning students that they will accept two equal-mass skiers with the same acceleration side by side and even holding hands, but, should one skier jump into the other's arms, their intuition says, the acceleration should be different. Being wrapped in each others arms is different from just holding hands - ask anybody ;)
But at least it shows how to get there without having the result fall out in the algebra.
Yes, that's a great way of saying it.
In jargony terms, it's called "universality of free fall", and is a form of the "weak equivalence principle".
It's the observation that heavy and light objects dropped from the same height reach the ground at the same time (assuming air resistance can be ignored, and as long as both falling masses are much smaller than the Earth's mass).
The equivalence of inertial and gravitational mass has been verified to great accuracy via experiment. See e.g. the famous Eotvos experiment. I have yet to see a first principles proof of it, be it conceptual or mathematical. Conceptual arguments that pertain to certain Earth bound situations can certainly be helpful in understanding those particular situations but they do not prove the equivalence in full generality.
I thought it was empirical?
That's my understanding as well, which is why I was saying conceptual arguments of the above sort are great for specific cases but they don't do much to prove to a person why gravitational and inertial mass are equivalent. If someone wanted a justification for it they would have to turn to experiment.
If it is, fundamentally, a synthetic statement, then it cannot be proved.
Anyone looking for a proof is going to be disappointed aren't they?
Besides, I'm not sure that OP was actually asking for a proof... doesn't post #1 specifically ask for a conceptual understanding?
I guess I don't understand the point you are making: could you clarify please?
I was talking about post #10 (specifically the first paragraph of post #10) in relation to posts #4 and #3 and saying that while post #10 provides a conceptual argument for the specific physical situation it deals with, it does not explain why inertial and gravitational mass are equivalent in general. This is something that must be accepted by virtue of experiment. Perhaps I should have quoted what I was referring to so as to have not creating any ambiguity.
Ah - gotcha... I had noticed that too.
Of course, it doesn't have to.
Yeh - it wasn't clear if you were saying that you thought that the truth of the equivalence principle could be known a-priori ... which, if so, would end a long-standing philosophical argument.
Many students seem to think that everything should be provable from first principles: the post would have worked with a short sentence to the effect that
this is something that must be accepted by virtue of experiment
To be fair - post #10 is higher than the usual calibre of debut posts.
Oh heavens no. In fact the Eotvos experiment is probably one of the coolest experiments ever! What's the fun if we know things a-priori :tongue:
Oh for sure, post #10 was nothing short of great. I was just saying that something along the lines of post #9 in particular would suffice in explaining, in general, why mass doesn't matter for free fall in a gravitational field.
1. What does it mean when "mass gets cancelled out" on a downhill slope?
When we say that mass gets cancelled out on a downhill slope, it means that the mass of an object becomes irrelevant in determining its acceleration. This is because the force of gravity acting on the object is directly proportional to its mass, so as the mass increases, the acceleration decreases. However, on a downhill slope, the force of gravity is countered by the force of the slope, so the mass no longer affects the acceleration.
2. How does the slope of the hill affect the cancellation of mass?
The steeper the slope of the hill, the greater the force of the slope will be to counteract the force of gravity. This means that the mass of an object will become even more irrelevant in determining its acceleration on a steeper downhill slope.
3. Why is it important to understand the concept of mass cancellation on a downhill slope?
Understanding mass cancellation on a downhill slope is important in many real-world applications, such as designing roller coasters or calculating the trajectory of objects rolling down a hill. It allows us to accurately predict the motion of objects and ensure their safety.
4. Does the shape or size of the object affect the cancellation of mass on a downhill slope?
No, the shape or size of the object does not affect the cancellation of mass on a downhill slope. As long as the object has mass and is rolling down a slope, its acceleration will not be affected by its mass.
5. Are there any other factors that can cancel out the effect of mass on a downhill slope?
Yes, other factors such as air resistance or friction can also cancel out the effect of mass on a downhill slope. These forces can counteract the force of gravity and affect an object's acceleration, making its mass less significant.
  • Classical Physics
  • Classical Physics
  • Classical Physics
