Fraction of vapor present in an ideal solution
In summary, the conversation discusses the application of Raoult's law to determine the partial vapor pressures and total vapor pressure of an ideal solution of two substances, A and B. It is explained that the colligative properties of the mixture depend on the number of molecules of each substance, and Raoult's law can be used to calculate the partial pressures of A and B. The example of water and ethanol is given to demonstrate how mixing two substances can change their properties and vapor pressure.
zaboda42
32
Suppose A and B form an ideal solution under a piston. The vapor pressure of pure A is 300 mmHg and that of pure B is 800 mmHg (at the same temperature). If the piston maintains 700 mmHg, what fraction of vapor is present in a 40 mole% A and 60 mole% B mixture.
The answer is "there is no vapor present," but I'm having trouble understanding why. Wouldn't the B substance boil, and thus be released as vapor?
I think you should look at Raoult's law for ideal mixtures of liquids.
You need to find the total vapor pressure of the mixture, and see if it is larger or lower than the pressure in the piston. When the gasses mix, they gain colligative properties, which depend on the number of molecules of each substance.
You do this with Raoult's law, where you find the partial vapor pressures of A and B, then you simply add them. You can use Raoult's law, because they form an ideal solution.
So if the piston was at 300 mmHg, there would be some vapor?
Using Raoult's law, what would be the partial pressures of A and B above a solution containing 40% A and 60 % B if both liquid and vapor were present? What total pressure would this imply? This is the only pressure that would be consistent with a 40/60 solution of A and B at the temperature at which the equilibrium vapor pressure of A is 300 mm and the equilibrium vapor pressure of B is 800 mm (given that both vapor and liquid are present).
Chet
If you have trouble understanding it, you can always try to look at an example. As you may know, water gets its high boiling point due to hydrogen bonds.
If you mix water and say ethanol, which form an ideal mixture, you gain a new collective boiling point for the entire mixture. Also the density will change. This is due to new hydrogen bonds between water and ethanol. The amount of these bindings, depend on the mixing ratio. So even if it is just a small amount of either it substance, it will change many properties a little bit as well.
You can always Google this along with Raoults law to find out, how this effects the vapor pressure, and how you calculate it.
Of course not many liquids form ideal mixtures, as you probably know. Oil and water for instance do not mix, so they would not experience those physical changes.
1. What is the definition of fraction of vapor present in an ideal solution?
The fraction of vapor present in an ideal solution refers to the ratio of the number of moles of vapor to the total number of moles (vapor + liquid) in a solution at a given temperature and pressure. It is a measure of the amount of vapor that is present in a solution.
2. How is the fraction of vapor present in an ideal solution calculated?
The fraction of vapor present in an ideal solution is calculated using the mole fraction of the solvent and the mole fraction of the solute. It can be calculated using the following formula:
Xvap = (Xsolute * Pvap0) / (Xsolute * Pvap0 + Xsolvent * Pvap0)
Where Xvap is the fraction of vapor present, Xsolute is the mole fraction of the solute, Xsolvent is the mole fraction of the solvent, and Pvap0 is the vapor pressure of the pure solvent at the given temperature.
3. What is an ideal solution?
An ideal solution is a solution in which the interactions between the solute and solvent particles are the same as the interactions between the solvent particles themselves. This means that there is no energy change when the solute is added to the solvent, and the solute particles are evenly dispersed throughout the solvent.
4. How does temperature and pressure affect the fraction of vapor present in an ideal solution?
Increasing the temperature or decreasing the pressure will increase the fraction of vapor present in an ideal solution. This is because higher temperatures and lower pressures increase the kinetic energy of the solvent particles, making it easier for them to escape into the vapor phase.
5. Can the fraction of vapor present in an ideal solution be greater than 1?
No, the fraction of vapor present in an ideal solution cannot be greater than 1. The fraction of vapor present is a ratio and therefore cannot have a value greater than the total number of moles in the solution. It is possible for the fraction of vapor present to approach 1 as the temperature and pressure increase, but it can never actually reach or exceed 1.
  • Materials and Chemical Engineering
  • Biology and Medical
22K
10K
