Why Dielectric Constant is Constant ?
In summary, when we double the electrical field passing through the insulator, the opposite electrical field caused by the insulator is also doubled. This happens because the polarized molecules in the insulator stretch, increasing the distance between the charged particles and weakening the applied field. However, this weakening is always a fraction of the applied field. The dielectric strength and permittivity of the insulator can also vary with temperature, which affects its index of refraction. The dipoles in the insulator initially have random orientations, but the applied field rotates them to align in a way that counters the applied field. Some materials may not have a linear relationship between permittivity and applied field.
onurbeyaz
What I meant to ask is; When we double the electrical field passing through the insulator, the opposite electrical field that caused by the insulator is doubled too. How can this happen, what happens to the molecules in that time to increase the opposite electrical field?
In my opinion, the polarized molecules have to strech (Distance between + and - charged particles in the molecules have to increase) But it doesn't make sense, because this means the generated electrical field have to decrease.
When we place a dielectric in an electric field, the field is reduced. This is because it loses energy that is stored by polarizing the dielectric. In the dielectric, a dipole moment is induced whose strength is proportional to the applied field and the permittivity of the dielectric. This dipole moment produces a secondary field that weakens the applied field. So if we increase the applied field, we increase the polarization field which weakens the applied field. However, this weakening is always a fraction of the applied field.
Likes 1 person
Please note that the dielectric strength is not quite a constant; it varies with temperature, and will change slowly with increased voltage ... slowly, that is, until the dielectric breakdown limit is reached! This limit varies by material, and how the material is made.
For optical materials the index of refraction depends upon the dielectric constant; changes in temperature can be readily measured via the changes in the index of refraction.
Here is nice description of the origin of the temperature dependence: http://www.doitpoms.ac.uk/tlplib/dielectrics/temperature.php
http://www.doitpoms.ac.uk/tlplib/dielectrics/dielectric_constant.php
Likes 1 person
Many materials are not linear. Their permittivity depends upon the actual field applied.
Likes 1 person
onurbeyaz said:
In my opinion, the polarized molecules have to stretch (Distance between + and - charged particles in the molecules have to increase)
The dipoles that give rise to the polarization field are initially randomly arranged and the applied field rotates them so more of them have components that counter the applied field.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/dielec.html
Likes 1 person
1. Why is the dielectric constant considered a constant value?
The dielectric constant, also known as the relative permittivity, is a material property that describes how well a material can store electrical energy in an electric field. It is considered a constant value because it is a characteristic of the material itself and is not affected by the external electric field. In other words, the dielectric constant remains the same regardless of the strength of the applied electric field.
2. How is the dielectric constant determined for a material?
The dielectric constant is determined by comparing the capacitance of a parallel-plate capacitor filled with the material to the capacitance of the same capacitor with air or vacuum between the plates. The ratio of these two values is the dielectric constant of the material.
3. Why do some materials have a higher dielectric constant than others?
The dielectric constant of a material depends on its molecular structure and the way its molecules respond to an external electric field. Materials with higher dielectric constants have molecules that are more easily polarized, meaning they can be more easily rearranged in response to an electric field.
4. Is the dielectric constant affected by temperature and frequency?
Yes, the dielectric constant of a material can change with temperature and frequency. This is because the molecular structure and polarization of the material can be affected by these factors. However, the dielectric constant is still considered a constant value for a specific material at a given temperature and frequency.
5. How does the dielectric constant affect the behavior of materials in an electric field?
The dielectric constant plays a crucial role in determining the amount of electric charge that can be stored in a material, as well as the strength of the electric field within the material. Materials with higher dielectric constants are able to store more electric charge and can withstand stronger electric fields before breaking down.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
