Maximum flow rates through water turbines given power and head.
In summary, the maximum flow rates through the Francis and the Samson turbines can be calculated using the equation "Flow rate = Power / (turbine efficiency * density of water * acceleration due to gravity * head)". The efficiency should be given as a percentage, not a fraction. For the Francis turbine, at full power the flow rate is 0.064m^3/s and at half power it is 0.046m^3/s. It is important to note that the radius of the wheel may need to be added to the head.
PhysicsStudy
Calculate the maximum flow rates through the Francis and the Samson turbines under the conditions specified:
Table 1 Characteristics of some American water turbines, 1849–97, on the basis of 30-inch (760 mm) wheel and 12-inch (300 mm) head
Type | Maximum power output | Efficiency (%)
Francis | 0.15 kW / 0.20 horsepower| 79.7 at full power / 55.0 at half power
‘Samson’ | 1.38 kW / 1.85 horsepower | 82.0 at full power / 75.6 at half power
Power = turbine efficiency * density of water * acceleration due to gravity * head * flow rate
so
Does anyone know if the efficiency in this equation should be given as a percentage or fraction? i.e. 79.7% or 0.797
Francis example...
Density of water = 1000kg/m^3
Acc due to gravity = 9.81 m/s^2
At full power:
Flow rate = 150/(0.797*1000*9.81*0.3)=0.064m^3/s
At half power:
Flow rate= (150/2)/(0.55*1000*9.81*0.3)=0.046m^3/s
However I have a feeling I'm missing a step. I'd be grateful for anyone who could take a look. :) Thanks.
I think your method and arithmetic is OK.
Check if you should add the radius of the wheel to the head.
looks ok to me
Ah that's a good suggestion. Looking at the context and previous questions of the textbook though I don't think I need to. Thanks. :)
Your approach to the problem is correct. However, you are correct in thinking that there may be a missing step.
In the given table, the maximum power output is given in kilowatts and horsepower. However, the equation you are using to calculate the flow rate requires the power to be in watts. So, you will need to convert the given power values to watts before plugging them into the equation.
1 kilowatt = 1000 watts
1 horsepower = 745.7 watts
So for the Francis turbine at full power:
Power = 0.15 kW = 0.15 * 1000 = 150 watts
Similarly, for the Francis turbine at half power:
Power = 0.20 horsepower = 0.20 * 745.7 = 149.14 watts
Once you have the power values in watts, you can use your equation to calculate the flow rates at full and half power for both the Francis and the Samson turbines. Make sure to use the correct efficiency values for each case (79.7% for full power and 55.0% for half power for the Francis turbine, and 82.0% for full power and 75.6% for half power for the Samson turbine).
I hope this helps!
What is the definition of maximum flow rate?
Maximum flow rate refers to the maximum amount of water that can pass through a water turbine, typically measured in cubic meters per second (m3/s).
How is maximum flow rate determined?
The maximum flow rate through a water turbine is determined by the size and design of the turbine, as well as the amount of power and head (vertical distance between the water source and the turbine) available.
What is the relationship between power, head, and maximum flow rate?
Power and head are directly related to maximum flow rate, as they determine the amount of energy available to turn the turbine and thus the amount of water that can pass through it.
Can maximum flow rate change over time?
Yes, maximum flow rate can change based on external factors such as changes in water levels or maintenance of the turbine. It can also be adjusted by changing the design of the turbine or the amount of power and head available.
Are there any limitations to maximum flow rate?
Yes, there are limitations to maximum flow rate based on the design and size of the turbine. Additionally, there may be environmental factors such as water quality or sediment that can affect the maximum flow rate through a water turbine.
  • Mechanical Engineering
