Need some help on air pressure through a manifold and optimal leak/pressure rate
In summary, the conversation discusses the building of a small manifold for a pump system used in an aquarium. The total volume of the manifold and tubing is 2.9828 cu inches. The pump has specific specs such as inflation time, air flow, max pressure, leakage, and pump time. The manifold includes a 3/16" x 12" tube and a small cylindrical manifold with two air rails, and the total volume should be 2.9828 cubic inches. The individual is seeking assistance in determining the optimal orifice size for each rail to maintain constant positive pressure during the pump's on and off phases. The conversation ends with the individual mentioning the possibility of experimenting with different orifice sizes if a mathematical solution cannot be
pityocamptes
I have a small pump system for an aquarium, and have decided to build a small manifold. The total volume of the manifold and the tubing is 2.9828 cu inches. Here is my pump specs:
Inflation time < 8s (from 0-200 mmHg in a 100cc tank)
Air flow > 70mL/min
Max pressure > 360mmHg
Leakage max 36mmHg/15sec from 300mmHg at 70cc tank
Pump time - 7sec on / 7sec off
From the pump is a 3/16" x 12" tube (volume = .3311 cubic inches) which attaches to a small cylindrical manifold (1"x3" - volume = 2.3571 cubic inches) that has two air rails (each air rail (1/4" x 3" -volume = .2946 cubic inches). Total volume should be 2.9828 cubic inches.
I was hoping to see if someone could figure out how big of an orifice I would need on each rail for maximum pressure, within the 7 seconds on, 7 seconds off (basically optimal orifice pressure and size where manifold drops stays at a constant positive pressure at the end of the 7 second off phase wherein the 7 seconds on phase starts to pump and build pressure. Any help on this would be appreciated. Thanks.
Anyone? Bump...
No one? Thats odd. I guess than, I will just have to experiment with different orifice sizes to get the best result, was trying to avoid this and wanted to see if a mathematical solution existed for this problem.
Based on the information provided, it seems that the main concern is achieving optimal pressure and minimizing leaks in the system. To determine the optimal orifice size for the air rails on the manifold, a few factors need to be considered.
First, the maximum pressure that the pump can achieve is 360mmHg, and the leakage rate is 36mmHg/15sec. This means that the maximum pressure that can be maintained in the system is 360mmHg - 36mmHg = 324mmHg. Therefore, the orifice size should be small enough to maintain a pressure of 324mmHg during the 7 seconds off phase.
Second, the total volume of the manifold and tubing is 2.9828 cu inches. This means that during the 7 seconds on phase, the pump needs to be able to fill this volume with air. Since the pump has an air flow of 70mL/min, it can fill 2.9828 cu inches in (2.9828 cu inches * 16.387 mL/cu inch) / (70 mL/min) = 0.68 minutes, or 41 seconds. However, the pump only runs for 7 seconds on, so the orifice size should be large enough to fill the manifold in 7 seconds.
Based on these considerations, the optimal orifice size would be one that can maintain a pressure of 324mmHg during the 7 seconds off phase and can fill the manifold in 7 seconds during the on phase. This will likely require some trial and error, as the optimal orifice size will depend on the specific characteristics of the pump and the manifold.
Additionally, to minimize leaks, it may be helpful to use high-quality tubing and ensure that all connections are secure and airtight. Regular maintenance and checking for any leaks can also help to maintain optimal pressure in the system.
1. What is air pressure and why is it important?
Air pressure is the force exerted by the weight of air molecules in the Earth's atmosphere. It is important because it affects weather patterns, helps to regulate the Earth's temperature, and is necessary for many industrial and scientific processes.
2. What is a manifold and how does it relate to air pressure?
A manifold is a device that connects multiple outlets or inputs to a single source. In the context of air pressure, a manifold is used to distribute or regulate the flow of air to different components or systems. It plays a crucial role in maintaining consistent air pressure for optimal functioning.
3. What is an optimal leak/pressure rate and how is it determined?
An optimal leak/pressure rate is the ideal amount of air leakage or pressure loss that ensures the most efficient and effective performance of a system. The rate is determined through various calculations and testing, taking into consideration factors such as the type of system, desired pressure, and potential sources of leaks.
4. What are the consequences of incorrect air pressure through a manifold?
Incorrect air pressure through a manifold can lead to a variety of issues, including decreased efficiency and performance of the system, potential damage to components, and safety hazards. It is important to regularly monitor and maintain proper air pressure to avoid these consequences.
5. How can I troubleshoot and optimize air pressure through a manifold?
If you are experiencing issues with air pressure through a manifold, it is best to consult a professional or refer to the manufacturer's guidelines. Troubleshooting may involve checking for leaks, adjusting valves or regulators, and ensuring proper maintenance of the manifold. Optimizing air pressure may require adjusting the flow rate or pressure settings to meet the specific needs of your system.
  • Mechanical Engineering
  • DIY Projects
  • General Engineering
  • Classical Physics
13K
