I don't understand the ''definition/law'' aspect of Newton's laws
In summary, the conversation discusses the concepts of Newton's laws, force, and inertial reference frames. It is mentioned that force can be defined as the influence of one object on the motion of another, and that the first law defines the concept of an inertial frame of reference. The second and third laws are seen as physical theories rather than purely definitional. It is also noted that Newtonian mechanics is still used because it is accurate within a certain range of conditions.
Coffee_
259
Hello everyone, it's been a while since I've been introduced to Newton's laws for the first time. Yesterday I've been reading the Feynman lectures vol 1, where Feynman makes a remark about Newton's laws not really containing any physics. This got me thinking and I'm really confused right now. English is not my first language so I'll do my best to get my confusion along to you. I'm talking about the first two laws only:
The problem arises when I start looking at Newtons first law without any pre conceived idea of what a force is. I have read that this is one way of approaching them. So let me look at the following statement:
''In inertial reference frames, the velocity vector of an object remains constant only and only if no force is acting on it.''
Two new concepts introduced: A) Inertial reference frames B) Force. To counter pre conceived notions sneaking into my reasoning I'll rename the things as A) Special frame B) Wobble.
So basically I have ''In special frames, the velocity vector of an object remains constant if there is no Wobble''
As you see this doesn't make sense. Let's say I'm looking at an object A moving with a constant velocity vector. If I knew that I was in a special frame I could conclude that there was no Wobble. However, I can't know if I'm in a special frame or not because they were not defined before this moment. Other way, if I knew that there was no Wobble I could say that I'm in a special frame, but again I can't know if there is a Wobble or not.
So the first law doesn't introduce anything, even not a definition. It could be viewed as:
1) The definition of a special frame in function of this other unknown thing 'Wobble'
2) The definition of a Wobble, using another unknown thing ''special frame''.
Your basic point is correct, namely that it's impossible to use the first law to define both inertial frames and force. But force can be given a definition independent of the first law. Roughly speaking, force is the influence of one object on the motion of another. It's not really a precise definition, and there's certainly some room for ambiguity, but we're dealing with science, not mathematics.
So now that we're equipped with a definition for the term 'force', we can use Newton's first law to define inertial reference frames.
That makes no sense. Force and inertial frames are defined by all three axioms.
So basically, the way to know that there is no force on an object, is to put it away from any possible influences. Once I know that there is no force I have an unambiguous statement how to find if I'm in an inertial frame or not. If I find myself to be in an inertial frame, I make another definition:
''F=dp/dt in inertial frames.'' This one strengthens the earlier vague definition of what a force was right?
Am I correct to say that Newtons second laws introduces no ideas but really is a definition. It was the first law that introduced the new idea of ''no acceleration iff no force'' for inertial reference frames. The second law defines a quantitative relationship.
Yes, and an inertial frame is one where all the forces on a body can be attributed to the influence off other bodies. So, for example, in a rotating frame there are centrifugal forces, but these cannot be attributed convincingly to the influence of other objects.
I think I see, basically my reasoning mistake here was to try and understand Newton's laws without a pre conceived idea of what a force means right?
The modern view of Newton's laws is that the first law of motion is definitional, that it defines the concept of an inertial frame of reference.
The second and third laws to me truly are "laws" (better: physical theories) rather than merely definitional. The second law addresses the linear relation between net force, mass, and acceleration. Note: F=ma is the modern view of Newton's second law. Newton used a lot of circumlocution to avoid using his calculus in his Principia. And even if he had used calculus (and vectors, which are 200 years post-Newton), he would have written his second law as F=kma, where k is some constant of proportionality. He and others before him (most notably Galileo) tested for the linearity. It is not definitional. The third law also is a testable physical theory.Both the second and third law don't hold up in light of Maxwell's equations, relativity, and quantum mechanics. They are falsifiable statement (what else could you ask of science) and indeed have been falsified. So why do we still use them? Popper's theory of falsification itself is falsifiable, and it too has falsified. We still use Newtonian mechanics because it is correct to within measurement errors in a limited regime where velocities and masses are small and distances are large. ("Small" velocities means small compared to the speed of light. "Small" masses means compared to, for example, the black hole at the center of our galaxy. "Large" distances means compared to the distances between atoms in a crystal or to the Schwarzschild radius of some object). That limited regime is the regime of our everyday experiences.There are two things missing here:
- What are forces?
- What's this net force business in the second law versus the individual forces in the third?
Newton addresses the second item in his corollaries to his laws of motion. The modern view of those corollaries is that forces are subject to the superposition principle, i.e., that forces are vectorial. Newton's proofs of those corollaries are a bit lacking to me. He appears to be begging the question in those proofs, assuming what he is trying to prove. In fact, the modern view is to make those corollaries axiomatic by telling students that forces are vectors.
But what are forces? Newton addressed mass, momentum, distance, time, and force up front, before he stated his laws. They're undefined terms. There's nothing wrong per se with undefined terms. After all, Euclid never defined what a point, a line, or a plane are. Those three things are the undefined terms in Euclidean geometry. Mass, momentum, distance, time, and force are essentially the undefined terms in Newtonian mechanics.
Don't we just need to come to terms that any of these quantities are merely constructs of our minds / culture that allow us to make predictions and justify / explain / rationalise our observations? The question "what is" is just as suspect as the familiar "why" question.
Force is a concept we apply in mechanical situations. It works for me and for you. It was not used in ancient history but they still managed to make their things work. One day, humans may look back on Force in the same amused way that we look upon Miasma or 'Nature abhors a vacuum'
To me all three laws are definitional.
The modern view (and most likely also the original intention) of Newton's second law is F=dp/dt. Going from m·a to dp/dt makes no sense because the former is easy to understand whereas differential equations where unknown that time except for Newton himself. But his formulation makes sense if he started from conservation of momentum and didn't made the step from dp/dt to m·a. Today we know that this step would have make the axioms invalid in modern physics.
I do not see a chance to test them.
D H said:
- What are forces?
This is answered by Newton's laws of motion:
Lex 1: Forces are the cause of acceleration.
Lex 2: Forces are proportional (in modern view equal) to the change of motion.
Lex 3: Forces cancel each other pairwise out.
Of course it would have been sufficient to define that the net force need to be zero. But pairwise forces that cancel each other out are sometimes easier to handle.
Momentum is defined in Definition 2. Force is defined by the the laws of motion. Quantity of matter (we better do not mix the term "mass" with Newton because he wasn't aware of the modern convention regarding its use) is defined by Definition 1 but this definition is not useful. Fortunately Definition 2, Lex 2, Lex 3, isotropy (mentioned in the introduction of the Principia) and the transformation between inertial systems provide an implicit definition of this property. Distance and time seem to be assumed as known.
For what it's worth, here's my perspective on these things:
As I mentioned earlier, before we discuss Newton's laws we need a qualitative definition of the word 'force'; specifically, we'll define force as the influence of one object on another's motion. If you're happy with this definition, then we can move on.
The first law states that there exists a frame of reference such that all force-free objects move with constant velocity. Such reference frames are called 'inertial reference frames'. Note that while the first law defines inertial reference frames, it is not merely definitional because it is a highly non-trivial claim that such reference frames exist in the first place.
The second law is a bit trickier. It is usually stated as "in an inertial reference frame, [itex]\mathbf{F}=m\mathbf{a}[/itex] ." But all this is is a mathematical definition of force, and it's not clear how a mere definition can be the bedrock of classical physics.
What's left unstated in the usual formulation of Newton's second law is that this definition of force leads to simple formulas. More precisely, any other conceivable definition for force will in general yield more complicated equations. For example, the force between two charged objects is [itex]\propto q_1 q_2 / r^2[/itex] using this definition of force. If you used some other definition, the formula for Coulomb force would be much more involved. This, then, is the physical content of the second law: in a general dynamical system, the value of [itex]m\mathbf{a}[/itex] for any given particle will take on a surprisingly simple form, making it the natural definition for the force on that particle.
I would also include the superposition principle in the second law. Indeed, the fact that force as defined by Newton obeys the superposition principle is another demonstration of the appropriateness of his definition.
I think the third law is fairly self-explanatory.
Yes, Newtons laws by themselves have almost no content. They only bloom when laws of forces are added to the mix such as the law of gravity for instance.
Sure they do. Newton's third law (weak form) leads to conservation of momentum. The strong form adds conservation of angular momentum. Conservation of energy results when forces can be expressed the gradient of a scalar function of position.
Another way to look at it: Lagrangian and Hamiltonian physics are just Newtonian mechanics recast in a more elegant form.
Newton's laws as he stated them are not definitions, but positive statements about the world. People often think some of them are definitional because they use the term "Newton's laws" for completely different statements from modern mechanics, which were unknown to Newton. These new statements, using concepts of inertial mass, inertial frame, acceleration, vectors or other anachronisms resemble Newton's laws but are not the same thing. We should make clear what we are talking about when we are talking about Newton's three laws.
The original statement of Newton's three laws:
LAW I.
Every body perseveres in its state of rest, or of uniform motion in a right line, unless it is compelled to change that state by forces impressed thereon.
LAW II.
The alteration of motion is ever proportional to the motive force impressed; and is made in the direction of the right line in which that force is impressed.
LAW III.
To every action there is always opposed an equal reaction : or the mutual actions of two bodies upon each other are always equal, and directed to contrary parts.
It should be clear that these statements are not mere definitions.
One modern set of statements resembling/related to Newton's three laws:
I.
There exist inertial reference frames.
II.
Force acting on a body is a vector quantity defined by ##m\mathbf a## where ##m## is mass of that body and ##\mathbf a## is its acceleration.
III.
Any force acting on a body due to another body is accompanied by force on the second body due to first body of the same magnitude but opposite direction.
Of these statements, II. is clearly a definition. But it should be clear that first two statements are very different from first two statements of Newton's laws.
There are many other similar triples of statements related to Newton's three laws, with number of definitional statements anywhere from 0 to 3.
Neither Newton's laws nor their reformulations of the above kind are sufficient for understanding the laws of mechanics. Other information is necessary, either in the form of definitions or other laws.
I don't understand the ''definition/law'' aspect of Newton's laws.
Newton's ( and anyone else's) 'Laws' are only, ever, enough to make reasonable predictions. They are not, in themselves, 'definitions' but they all hang on definitions that are, somewhere back along the line, based on assumptions and gut feelings.
Those pesky Philosophers do their best to regularise this situation but they end up applying logic, which is not necessarily a part of the Physical world. Their stuff is not falsifiable in the way that Science tries to be.
Why? I can always say that if the object undergoes only translational motion that I set my origin of my reference frame in the mass center of the object. Whatever the motion of an object is I can always figure out what reference frame where v=0, even if this means to let my frame accelerate with the object. This conclusion uses only more or less math reasoning and no assumptions about the physical world.
Such reference frame is not always inertial, because test particles around the object will not move rectilinearly in its reference frame.
I think of Newton's laws as more of a framework for physics than a particular theory of physics. If you don't know what forces are at work in a particular situation, you can't apply [itex]F = ma[/itex] in a way that has any predictive value (you could calculate F by measuring m and a, but that doesn't allow you to predict [itex]a[/itex]). On the other hand, if you supplement Newton's laws with specific hypotheses as to the types of forces at work, then Newton's laws plus force laws together make a predictive theory. If you assume that a spring stretches when a force is applied according to Hooke's law: [itex]F = -k \delta x[/itex], then forces become measurable independently of accelerations, and then [itex]F = ma[/itex] is a testable claim.
Without making some kind of assumption about the forces at work in a particular situation, I don't see how you can get anywhere using Newton's laws of motion. Newton's third law sounds like it is falsifiable, because you can check to see if the acceleration of one object is accompanied by equal and opposite changes of momenta of other objects. But if you don't know what forces are at work, then you don't know how far away to look for these other objects.
Another problem with Newton's laws is mass. We have no way of measuring the mass of something other than checking how it moves under the application of a known force.
In practice, science is not as clean as the naive interpretation of Karl Popper's falsifiability standard would imply. You have to make certain auxiliary assumptions about mass, forces, etc., in order even to make sense of your measurements. Only then can you use measurements to test your theories about forces and masses. So it's really an iterative process: You make some initial assumptions. You make measurements based on those assumptions. You use the measurements to test your assumptions. Then you may need to make new assumptions based on those tests, which may require revising your measurements. Hopefully, the process converges.
You can always find a reference frame such that one force-free object moves with constant velocity, no matter what the laws of physics are. But for all we know, there could be another force-free object moving in circles in this reference frame. What's non-trivial is that all force-free objects move with constant velocity.
Why? All three statements together provide a qualitative and quantitative definition of force:
The first law is a qualitative definition (force is the cause for alteration of motion).
The second law is a quantitative definition (force is proportional to the alteration of momentum).
The third law distinguishes forces from fictitious forces (forces have corresponding counterforces).
The definition of inertial systems is just a side-effect effect: Inertial systems are characterized by the absence of fictitious forces.
That's what they are intended for. In Newton's Principia the laws of motion are the basis for the law of gravitation. The laws of motion define what force is and how it affects the motion of bodies and the law of gravitation describes how force depends on mass and distance of the bodies. The laws of motion would be useless without the law of gravitation and other empirical laws describing (and predicting) forces under specific conditions and these empirical laws would be meaningless without the laws of motion.
Most scales measure the mass of bodies at rest. Using inertia to measure the mass is a rather exotic method.
A scale only measures mass under the assumption that gravitational force is proportional to mass.
As I said in my post, Newton's physics (or Lagrange's or Hamilton's) are frameworks. They aren't theories in themselves. You plug in a particular hypothesis for the force laws and you get a real theory.
It is true that the third law has a tiny amount of empirical content, but not enough to actually be falsifiable. If you see an object accelerating, then you know by the third law that some object somewhere is accelerating in the opposite direction. But if you have no constraints as to where that object might be, that's not really empirically testable.
I really don't consider the second law to be a definition of force. For one thing, in actual physics problems involving Newton's laws, we add forces together: An object might be acted on by the force of gravity, the force of friction, etc. There might be no accelerations involved at all, if all the forces balance. In a case where the forces balance, there are forces, but no accelerations, so I don't see how it makes sense to say that force is defined in terms of acceleration.
Apparently, there is disagreement about this. I don't think that the second law is a definition of force. If you have a rock sitting on a desk, there is no acceleration, but there are forces: there's an upward force due to the desk. There is a downward force due to gravity. But neither one is accelerating anything.
No, they measure mass under the assumption that equal masses result in equal gravitational forces. If you measure mass by inertia you need a similar assumption.
That means m·a=F=0. That's just a special case of the second law.
In the case of balancing forces, the TOTAL force is zero. But gravity still exerts a downward force, and the desk still exerts an upward force. There are still forces, but there are no accelerations. So force is not defined in terms of accelerations. The force of gravity doesn't go to zero just because it is canceled by the normal force of the desk.
I think that the first law of Newton except the definition of an inertial frame of reference also defines what is force: Force is the ONLY thing that can cause the change of the velocity of a body.
Very good point. Use of mechanics for reliable building of bridges, buildings etc. relies on the concept of force, which has nothing to do with acceleration. It is an independent notion characterizing mutual interaction of bodies. This interaction does not have to manifest through acceleration. Presence of force manifests in other ways too, for example through deformation of the bodies.
This is probably abit offtopic but isn't deformation caused by uneven distribution of acceleration across the points of a body?
When you put many heavy books on a plastic table, you will see that the table deforms. There is force between the table and the books, but no acceleration.
  • #31
yes but the deformation happened because some of the points of the plastic table (the points under the books where the deformation happened) were accelerated abit and then they stop abit lower.
  • #32
Well, the forces present NOW shouldn't depend on what happened in the past. Right now, there are no accelerations. So if force is defined in terms of acceleration, then it would seem to imply that there are no forces right now.
I think that logically it makes more sense to let "force" be primitive, and to view "force cause accelerations" as a property of forces.
  • #33
According to the second law there are corresponding changes of momentum that are balanced too.
Acceleration is involved in the qualitative definition of force only.
  • #34
Well, those component accelerations are not observable. If the point of defining F as ma is to define forces as things that are observable, then having unobservable accelerations defeats the purpose, I would think.
I suppose you could define force counterfactually as something that would cause mass [itex]m[/itex] to accelerate at rate [itex]a[/itex], if there were no other forces at work.
1. What are Newton's laws of motion?
Newton's laws of motion are three fundamental principles that describe the behavior of objects in motion. They were developed by Sir Isaac Newton in the 17th century and are considered the foundation of classical mechanics.
2. What is the first law of motion?
The first law of motion, also known as the law of inertia, states that an object will remain at rest or in uniform motion in a straight line unless acted upon by an external force.
3. What is the second law of motion?
The second law of motion states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In other words, the greater the force applied to an object, the greater its acceleration will be, and the more massive the object, the less it will accelerate.
4. What is the third law of motion?
The third law of motion, also known as the law of action and reaction, states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
5. How do Newton's laws apply to everyday life?
Newton's laws of motion have numerous applications in everyday life, from the movement of vehicles to the behavior of objects in sports. For example, the first law explains why a person will continue to slide on ice after they stop pushing off, and the second law helps us understand how much force is needed to throw a ball a certain distance.
  • Mechanics
  • Mechanics
15K
  • Mechanics
