Can we predict the color that will be perceived by the eye?
  • Thread starter penguin007
  • Tags
    Color Eye
In summary, the conversation discusses the prediction of color perception in the eye when illuminated by different monochromatic lights. It is mentioned that it is not possible to predict the subjective experience of a wavelength, but it is possible to perceive similar colors when illuminated by similar wavelengths. The experiment of using three different colored lights to illuminate a grid of colored squares is described. It is also mentioned that LCD computer screens use three monochromatic lights in each pixel, but the color space accessible to these screens is smaller than the total color space accessible to our eyes. The conversation also touches on the use of RGB and HSB color modes in computer graphics, as well as the relationship between these modes and the chromacity diagram. The conversation concludes with a question about
penguin007
77
Hi,my question is the following:
Supposing that we light up the same surface of an optical system (the eye) by two different monochromatic lights (each one characterized by a wavelength and intensity): Can we predict the color that will be perceived by the eye?
Thanks for your help.
Are you referring to qualia? Whether we can predict the subjective experience of a wavelength?
If so then the answer is no we can't. Although if you have already experienced some monochromatic light source and you then illuminate your eye with another source of similar wavelength then we can say that we will perceive a similar colour, say a different shade of red for example.
Yet, we know that if we light up the eye with two monochromatic lights (let's say blue and red) both of the same intensity, then the color perceived will be purple; if the intensity of blue is more important than the one of red, then the color will be perceived as "dark purple"...
Is it possible to predict the color we see (by telling "x% of blue(435nm) + y% of red (700nm) is equivalent to a light of z nm")?
CONE CELL makes colorful image in blazing light!
Sometimes, but not always. For example, how does one generate pastel hues from monochromatic sources? Or brown?
The answer to this question is also dependant on what else is withing your field of view.
Here's an experiment we did in physics class:
Have a room that can be completely darkened.
Have 3 light sources of variable intensity, one red, one green, one blue.
Have a 6' by 6' grid of 36 different colored squares on a wall.
Have a photometer to measure the light reflected off individual squares.
Now view the grid with an equal intensity of light from the 3 light sources shinning on it. You should see it in it's natural color. Measure that reflected light with the meter and note the measurement, for one of the squares.
If you now cover all but that one square, and adjust the 3 source lights until the color of the 1 square appears different, then remove the covering so that your eyes can compare it to it's neighbouring square it will return in appearance to it's natural color.
You can now measure the light reflecting off that 1 square and confirm that it's peak wavelength differs from when it was under even lighting from the 3 sources.
So, you can in fact see the same color in the 2 cases, when seeing different wavelengths of light.
Don't LCD computer screens use 3 monochromatic lights in each pixel?
Yes, but the color space accessible by LCD/triphosphor displays is a much smaller subset of the total color space accessible to our eyes.
I find this so interesting. Shine red light and green light into the eye simultaneously, the red light stimulates the red cones, the green light stimuates the green cones, and then the brain's interpretation is "I see yellow." Shine only yellow light into the eyes, it stimulates both the red cones and the green cones, and the the brain's interpretation is "I see yellow." The same sensation in both cases. To find out whether the light is yellow, or whether it's a mixture of red and green, you can't tell by looking at it, although you could tell by directing the light through a prism to see what colors come out the other side. The prism would separate red and green. If it's yellow, it comes out without any change.
penguin007 said:
This link can also be interesting:http://hyperphysics.phy-astr.gsu.edu/hbase/vision/cie.html#c2";
However; I can't understand what do the numbers in the table represent (eg.Red=191(red),27(green),75(blue)).If anyone has an idea...
In computer graphics, colors are specified with 3 numbers ranging from 0 to 255 with using RGB mode. Those numbers represents the intensity of the colors red, green and blue with three 0s meaning no intensity, hence black. Three 255s would be max intensity for each hence white.
And what's the link between these numbers and the chromacity diagram?
There's 2 ways you can specify a color, with a computer display.
1) RGB = red, green, blue
2) HSB = hue, saturation, brightness (alternately HSL or HSV)
http://en.wikipedia.org/wiki/HSL_and_HSV
The wiki entry explains how to convert between the 2.
It's called a color space, it defines the coordinates of the R,G,B points on the color triangle and so the range of colors that you can show
- as well as the mapping of RGB->perceived color.
There are two main ones, aRGB (adobe) and sRGB (everyone else) see http://en.wikipedia.org/wiki/SRGB
Thanks a lot for your help that has been very useful to me!
I've one more question:
Is it possible to define the saturation and the hue of a source of light such as a torch or a monochromatic source?
A monochromatic source would have a single hue and a sat/value depending on the power.
A black body source (light bulb) is usually defined by color temperature http://en.wikipedia.org/wiki/Color_temperature
It's interesting that lots of stuff that was only of interest to a very small set of optics engineers is now displayed on the back of everyones digital camera.
I've one last question:
Suppose we have two monochromatic light's sources respectively of intensity I1 and I2. Let's say we make the lights of these sources partially reflected by a surface of glass and that x% of the light 1 and y% of the light 2 are reflected:can we say that the intensity of the reflected light is I=x*I1+y*I2?
Yes, this is what I found interesting too. As far as I know, you could have more than 3 different light sources of different monochromatic light. In fact, the more light sources you have, the closer you can get to a full spectrum. But what I find very interesting, is that means there should be an almost infinite number of different spectrums that, when we observed them, they should all appear the same (ie: produce the same experience of color in the brain).
1. What factors affect the perception of color by the eye?
The perception of color by the eye can be affected by various factors such as the wavelength of light, the intensity of light, and the contrast between colors. The color receptors in our eyes, called cones, are responsible for detecting the different wavelengths of light and sending signals to the brain, which then interprets the color we see.
2. Can we accurately predict the color that will be perceived by the eye?
While we can make educated guesses based on the physical properties of light and the sensitivity of our color receptors, accurately predicting the exact color that will be perceived by the eye is not always possible. This is because factors such as lighting conditions, individual differences in color perception, and even cultural influences can all play a role in how we perceive color.
3. How do colorblindness and other vision impairments affect color perception?
Colorblindness and other vision impairments can greatly affect the perception of color by the eye. For example, individuals with red-green color blindness have a reduced ability to distinguish between these two colors, which can impact their overall perception of the color spectrum. Other vision impairments, such as cataracts or macular degeneration, can also affect color perception and may require medical treatment.
4. Can technology accurately predict how humans will perceive color?
Technology has advanced to the point where it is possible to measure and quantify the physical properties of light, such as wavelength and intensity, and use this information to predict how humans will perceive color. However, as mentioned before, there are still many factors that can impact color perception, so while technology can give us a good estimate, it may not always be 100% accurate.
5. How does the brain play a role in color perception?
The brain plays a crucial role in color perception by interpreting the signals sent from the color receptors in our eyes. Our brain is responsible for processing and organizing the information it receives from the eyes, which ultimately determines how we perceive color. It also helps us to make sense of the various hues, shades, and tints that we see, allowing us to distinguish between different colors and their subtle variations.
  • Classical Physics
  • Other Physics Topics
