New Reply
What causes metals to cold weld in a vacuum?
Share Thread Thread Tools
Aug7-12, 07:27 PM   #1
I read that some metals, if sufficiently smooth, will become become cold welded upon contact in a vacuum. What process causes this?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Aug7-12, 10:52 PM   #2
K^2
Recognitions:
If surfaces are perfectly smooth and clean, then the atoms will form metallic bonds, resulting in lattices getting fused together. It's the same force that holds metal together in the first place. Realistically, no surface is ever that smooth or that clean. That's where diffusion comes in. Diffusion can allow atoms on the surface to move somewhat, resulting in impurities moving out of the way, surface imperfections getting shifted, etc. If given time, almost any two materials will fuse together due to diffusion. For two clean metal surfaces in a vacuum, that time can be relatively short.
New Reply
Thread Tools
Similar Threads for: What causes metals to cold weld in a vacuum?
Thread Forum Replies
Is there a word for the Group with metals, metalloids and non-metals Introductory Physics Homework 7
sacrificial metals and displacement of metals Chemistry 1
I am looking into calculating the weld bead strength. I am unsure of Engineering Systems & Design 1
Interesting Chemistry Question (Metals And Non Metals) Biology, Chemistry & Other Homework 2
do cold blooded animals do best in cold weather? or hotblooded? General Discussion 13
