Tension in a rope on frictionless pulley
In summary, the tension in the string is equal to the weight multiplied by the coefficient of friction.
simon360
A 4kg object is palced on a table with a coefficient of friction of 0.2, and attached to a rope. This rope is run through a frictionless pulley, and attached to an 8kg weight. What is the tension in the rope?
F=ma
F of friction = (coefficient of friction)(Force normal)
Force normal of weight = 8(9.8) = 78.4
Force normal of object = 4(9.8) = 39.2
Force of friction on object = 0.2(39.2)
I don't know where to go from here, and I have an exam tomorrow. Help would be greatly appreciated, obviously :P
Thanks, I hear you guys are the best for quick physics help ;)
Apply Newton's 2nd law to each mass, then combine the two equations.
So add both forces from F=ma together?
Not sure what you mean. What I mean is: Apply F=ma to each mass separately. You'll end up with two equations that you will solve together.
What forces act on each mass?
Well, the weight is pulling the object because it is hanging off the table, through the pulley...
What pulls on the object is the tension in the string. (Of course that tension also pulls up on the weight.)
Ahh, I think I get it (but physics has confused me from the start, so bear with me). The tension is essentially a net force?
No. "Net force" just means the total force on an object. The tension is just one of several forces.
Alright, I'll be honest, I still don't get it :(
This was a quick question I came up with to demonstrate what I need to know. What would be the tension? Then I could figure out how to actually get it.
Start by applying Newton's 2nd law to the hanging mass. What forces act on it?
Gravity times its own weight, and the object on the table (which I presume can act as friction). Anything I'm missing?
The object on the table is also prone to friction, and the weight that is hanging pulls back on it.
Stick to the forces acting on the hanging mass. Yes, its weight is one force. What's the other? (Forget about the object on the table for the moment. We'll analyze that one next.)
I can't think of any, unless you mean the rope/tension itself.
Of course I mean the rope tension!
There are two forces acting on the hanging mass: The rope tension, which acts up; the weight, which acts down.
Now apply Newton's 2nd law.
Haha, thought that would be too easy :P
The force down = 8(9.8) = 78.4 N
Not sure how to deal with the rope tension, tbh...
The rope tension is unknown, so just call it T. (You'll end up solving for it.)
Oh, ok.
So the net force is F down - T
The net force on the hanging mass is [itex]T - m_2 g[/itex], where [itex]m_2[/itex] equals 8 kg.
Alright, so essentially just the reverse: T - 78.4.
OK, now apply Newton's 2nd law.
I thought I already did...
Would I be right to say that it's 7.84 = T - 78.4?
Just because the coefficient of friction is 0.2, force normal on the object is 39.2, and thus friction is 7.84.
Apply Newton's 2nd law to the hanging mass only. Friction has nothing to do with it. Call the acceleration "a".
Well, mass * a = 8 * 9.8 = 78.4. I really don't understand what you want me to do after that...
The acceleration is not 9.8 m/s^2. That's the acceleration of a freely falling object, not something attached to a string. Call the acceleration "a".
I truly and honestly don't know what to do.
Newton's 2nd law:
[tex]F_{net} = m a[/tex]
[tex]T - m_2 g = m_2(-a) = -m_2a[/tex]
I called the magnitude of the acceleration "a". Since it accelerates downward, the acceleration = -a. (Up is positive, down is negative.)
See if you can apply Newton's 2nd law in a similar manner to the other mass.
I guess the * things mean multiply, so you wrote mg=ma... but the net force isn't mg, it's mg-T I think
Ahh, that makes more sense...
I think this is the only thing I will have trouble with on the exam, and I really have to go to bed since it's 11:40 here. Thanks for your help, but I think sleep is more important than the few potential marks I'll lose here...
wait, might as well tell you the answer first...
first equation, m1g-T=m1a
second equation= T-um2g=m2a
by u I mean coefficient of frictions, um2g is just the Ff=uFn equation
notice that the acceleration is the same for both things so solve for acceleration in one equation and substitute that into the a in the other equation
  • #31
get it? if you wanted the acceleration instead of the tension, you would just solve for T in one equation, and substitute that for T in the other equation... that will give you all you need to find the acceleration
  • #32
Thanks, very much appreciated guys. It makes near complete sense now!
Wish me luck on my exam, and now that I know about you guys, I imagine I'll be seeing you in the new year! ;)
  • #33
gl =)
1. What is tension in a rope on a frictionless pulley?
Tension in a rope on a frictionless pulley refers to the force exerted by the rope on the pulley, which is equal to the force exerted by the pulley on the rope. This force is always directed away from the pulley and is responsible for keeping the rope taut.
2. How is tension affected by a frictionless pulley?
In a frictionless pulley system, the tension in the rope remains constant throughout the entire length of the rope. This is because there is no friction to reduce the tension as the rope passes through the pulley.
3. Can the tension in a rope on a frictionless pulley be greater than the weight of an object?
Yes, the tension in a rope on a frictionless pulley can be greater than the weight of an object. This is because the tension in the rope is equal to the weight of the object plus any additional force applied to the rope, such as by a person pulling on the other end of the rope.
4. How does the angle of the rope affect the tension in a frictionless pulley system?
The angle of the rope does not affect the tension in a frictionless pulley system. As long as the pulley is frictionless, the tension in the rope will remain constant regardless of the angle at which the rope is pulled.
5. What happens to the tension in a rope on a frictionless pulley if the pulley is not perfectly aligned?
If the pulley is not perfectly aligned, the tension in the rope may be slightly reduced due to the introduction of a small amount of friction. However, this reduction in tension is typically negligible and does not significantly affect the overall tension in the rope.
