Where is Water Stored in the Body & Its Effects on Athletes
In summary, water is stored in cells throughout the body, and sweat is mainly composed of water and salts. Sweating is necessary to maintain homeostasis, and drinking plain water is sufficient to maintain hydration.
noagname
144
ok,
this is a couple of questions in one
where is water stored in your body?
i know some is stored in your blood stream, but then does it ever get emptied out
and if it does then why are some athletes not allowed to drink a lot of water
i heard that they will get to much water in there blood
how do you sweat and while you are sick does it help to sweat?
Biology news on Phys.org
Cells, every single cell contains water. Without water in cells...well, you can guess what happens.
Athletes should not drink large volumes of water during intense exercise or right after exercise mainly for one reason:
You are sweating profusely and you are losing salts. By having a large intake of water, it dilutes your blood even further and you get hyponatremia. Then you get water poisoning
then you die.
Hence gatorade.
The salt and potassium and other things dissolved in the water in your body actually give that water an electrical charge. Some of the dissolved substances give it a positive charge and some give it a negative charge and the positive and negative charges must be kept in balance. This is what's called electrolyte balance.
If you drink too much pure water (not just while you're exercising - any time), which is more electrically neutral, it causes the charged water and substances to move around inside your body in a way that completely screws up the function of many of your bodily systems. It can actually http://www.metafilter.com/57753/Water-Intoxication-Death".
ok i never thought you could die like.
Yeah, a fair number of people die because they don't realize this.
Just how much water is too much?
My expectation would be that it would be different based upon body mass, but I'm not sure. http://www.theglobeandmail.com/servlet/story/RTGAM.20070114.wwater0114/BNStory/International/home" in Canada involved a woman drinking more than 40oz. but they didn't know the exact amount.
We've had some threads in the past on water intoxication. You might want to search in the biology forum for them...they would have predated the existence of the medical sciences forum. I know I've dug up some clinical studies on it and posted in those threads, so you might want to take a look at them to understand it better if you're curious about it.
well my only other question is would something like Gatorade hurt you
I don't know the answer to the Gatorade question. But even if someone here knew how much Gatorade you would have to drink to hurt you, they probably wouldn't put it in writing because it would make it look like PF was libeling Gatorade.
My suggestion would be to follow Moonbear's advice and track down older water intoxication threads. It's probably safe to say that you should not drink an amount of Gatorade equivalent to the amount of water that would kill you.
noagname said:
ok,
Your kidneys control the overall amount of water and salt in your body (homeostasis). Typically, our bodily fluids are at around 320 mOsm, but there is a huge difference between the solution inside a cell (120 mOsm potassium, 5 mOsm sodium) and outside a cell (120 mOsm sodium, 5 mOsm potassium). This difference is used by every cell to "do" things: muscle contraction, nerve impulses, etc. etc. There's another ~50 mOsm of cloride, ~30 mOsm of bicarbonate, ~5 mOsm of calcium (extracellular), and so on.
Sweat is mostly Na, Cl and water. During normal perspiration, the salt is re-absorbed by the epithelial layer, with the overall result of slow loss of water- drinking plain water is sufficient to maintain homeostasis. During extreme perspiration, there is both loss of salt and water, requiring replacement of salt as well. That is, simply drinking salty water is best for heatstroke and the like.
Gatorade and the like do more than simply replace salt and water. "sports drinks" are a combination of salt, water, and glucose. The glucose is there (in theory) to replenish depleted energy stores within muscles which occurs during excersise. The gut and renal epithelia couples glucose and salt uptake for a couple of reasons. Drinking salty sugar water will allow faster absorption of the sugar than drinking plain sugar water.
It's possible to overdose on distilled water (never drink deionized water!) by washing out the osmotic gradient present in the kidney, required for urine concentration (countercurrent hypothesis). It's possible to overdose on anything! Drinking sufficient quantities of gatorade, fast enough, will also result in damage- I'm not sure what the mechanism is, but all that stuff has to go somewhere.
Sweating is part of the excretion mechanism and relates to maintenance of core body temperature. I don't think "sweating out a cold" works because of any immunological benefit- what is excreted is salty water, not bacteria or viruses. Cystic Fibrosis patients have a higher osmotic concentration in their sweat than normal.
Wow Andy, thanks for all the detail. I was hoping someone would come along with this much knowledge.
Why is it bad to drink deionized water? Not that I plan to. Is that something you can even get in stores? Does it bond to something inside your body?
I think i should also say thanks. You answered all of my questions and i really like the sweat part of it. Now i can show my parents that.
It's a question of osmolarity. Water comes in a lot of 'flavors' here- deionized, double-distilled, endotoxin-free, autoclaved, and in combination with each other. Mostly they are the same thing, only the method of preparation is different. DI water has been run through a revere-osmosis device, while dd water has been run through a 'still'. The mice here are fed on dd-autoclaved water. I think the endotoxin-free stuff is used for DNA preps...
Drinking straight hypo-osmotic water puts a lot of stress on the kidneys, and can lead to lysing the epithelial tissue. I'm not sure what the 'safe dose' is...
I just got our osmometer up and running again, I'm curious what the osmolarity of tap water, bottled water, etc. is... but I'm sure they have a higher osmolarity than DI or dd water.
The other thing is that DI/dd water is highly corrosive to metals, as well as slightly acidic.
Thanks for the warning. Do you think that the jugs that are specifically labeled “distilled water” as opposed to “spring water” (I'm in the U.S.) might have a high enough osmolarity to avoid?
I just ran some samples of dd and tap water on our vapor pressure osmometer: there is no substantial difference between the two- tap water came out as 28 mOsm, dd came out as 24 mOsm. It's not clear if 3 mOsm is statistically significant.
So- there should no biological difference between drinking dd, DI, or tap water based on the osmolarity. Tap water has trace elements that are removed by distillation, so there may be an issue if one only drinks and uses distilled water.
Urban myth debunked!
Just to make sure I'm understanding you properly - DI is the deionized water, right? So are you saying your test shows that there oughtn't be any problems from drinking deionized water, at least in the short term? At least as compared to tap water?
(Slight attempt at humor in science)
You may also want to consider beer if you are afraid of the tap water and need long term micronutrient additions to your diet. Example Silicon as a nutrient:
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6T6P-4P4NPM4-2&_user=10&_coverDate=01%2F31%2F2008&_rdoc=6&_fmt=summary&_orig=browse&_srch=doc-info(%23toc%235036%232008%23999539998%23676678%23FLA%23display%23Volume)&_cdi=5036&_sort=d&_docanchor=&_ct=48&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=8c09c5a55b5475bc0572525888c364ed
This is because most beers are made from filtered ground or surface water because a major component of beer flavor is related to micronutrients and other things in the water.
Bottled water (if it actually comes from a natural source) is also a source dietary of Si.
Si decreases absorption of Aluminum which is also present in natural-sourced water and in leavening agents like baking powder.
Ok. fun time over. :smile: Similar results for :yuk: drinking water, silicon and aluminum uptake:
Gillette-Guyonnet et al., 2005 S. Gillette-Guyonnet, S. Andrieu, F. Nourhashemi, V. de La Gueronniere, H. Grandjean and B. Vellas, Cognitive impairment and composition of drinking water in women: finding of the EPIDOS study, Am. J. Clin. Nutr. 81 (4) (2005), pp. 897–902
1. Where is water stored in the body?
Water is stored in various locations throughout the body, including within cells (intracellular space), in the spaces between cells (interstitial space), and in the bloodstream (intravascular space). The largest reservoir of water in the body is found within cells, accounting for approximately two-thirds of total body water.
2. How does water intake affect athletic performance?
Water intake plays a crucial role in athletic performance. Dehydration, even at mild levels, can lead to a decrease in physical and mental performance, as well as an increase in fatigue and risk of injury. On the other hand, proper hydration can improve endurance, strength, and overall athletic performance.
3. What are the effects of dehydration on athletes?
Dehydration can have significant negative effects on athletes, including decreased endurance, strength, and speed, as well as increased risk of heat injury, cramping, and fatigue. It can also impair cognitive function, leading to poor decision-making and coordination.
4. How do athletes lose water during exercise?
Athletes lose water through sweat during exercise, as well as through breathing and urination. The amount of water lost depends on factors such as exercise intensity, duration, and environmental conditions (e.g. temperature, humidity).
5. How much water should athletes drink before, during, and after exercise?
The amount of water an athlete should drink depends on individual factors such as body size, sweat rate, and exercise intensity. However, a general rule of thumb is to drink 17-20 ounces of water 2-3 hours before exercise, 7-10 ounces every 10-20 minutes during exercise, and 16-24 ounces for every pound lost after exercise. It is important to listen to your body and drink enough to stay hydrated, but not to the point of feeling uncomfortably full.
  • Biology and Medical
  • Other Physics Topics
13K
