Integration of exponential and trigonometric forms
In summary, the conversation discusses the integration of cos(e^x)*e^x and the confusion about why integration by parts cannot be used in this case. The experts clarify that substitution is the most appropriate method to use and explain the reasoning behind it. They also provide a helpful link for further information on integration by parts. Finally, they provide a simple solution using substitution and conclude that using integration by parts would only overcomplicate the problem.
AceAcke
http://d.imagehost.org/view/0659/Capture
Link to wolfram alfa:http://www.wolframalpha.com/input/?i=integrate%28cos%28e^x%29*e^x
What i don't understand is why whey do it like this and why i can't integrate by parts in this case?
Thanks for any replies!
show us your steps for integration by parts. that way we can see if you may have made a mistake somewhere.
They use ordinary substitution because it is the most obvious method to try. Instead of asking why you can't use integration by parts, the question really should be "Why would I want to use integration by parts if there is a much simpler method I can use?"
It's possible that integration by parts will work here, but there aren't that many possible choices for u and dv. The thing about integration by parts is you want to choose dv so that it's not too simple (which eliminates dv = dx), but is still possible to integrate.
http://d.imagehost.org/view/0589/Capture2
The reson i did like that is because integration by parts is the chain rule in reverse right? so if I'm going to derive cos(e^x)*e^x then i would use the chain rule, and therefore i used integration by parts here
Integration by substitution is actually the chain rule in reverse. Integration by parts comes from the product rule of differentiation. So u-substitution is the way to go for this problem, although integration by parts might work.
ops that my bad, but still Cos(e^x)*e^x is in the form g(x)*f(x) which implies that integration by parts are in order?
Well it should work, but cos(e^x) doesn't have an elementary antiderivative (I'm pretty sure), so when you tried to use integration by parts, you chose a dv which doesn't have an elementary antiderivative.
AceAcke said:
Okay, i have found the solution on wikipedia thanks to your replies.
The solution is to use substitution before using the integration by part method.
I'm not sure exactly what you mean here. If you are saying that in this problem you should use substitution and then integration by parts, that is incorrect. The problem can be done using substitution alone. Integration by parts is completely unnecessary in this problem.
If you are saying that substitution is the preferred method here, then I agree.
AceAcke said:
here is the link to wiki if anyone would come across the same problem.
http://en.wikipedia.org/wiki/Integration_by_parts#Integrals_with_powers_of_x_or_ex"
I was to hasty in my previous post. no integration by parts is necessary!
http://d.imagehost.org/view/0054/Capture4
I think i need to go back to the basics to get my facts straight!
It funny how this expression cos(e^x)*e^x is easier to integrate than cos(e^x).
using parts is way over complicating things.Use substitution. u=ex du=exdx
whoops should have read the whole thread
1. What is the purpose of integrating exponential and trigonometric forms?
The purpose of integrating exponential and trigonometric forms is to solve complex mathematical problems involving both exponential and trigonometric functions. This integration allows for the simplification of equations and the determination of precise values for these functions.
2. How do you integrate exponential and trigonometric forms?
The integration process for exponential and trigonometric forms involves using substitution techniques, trigonometric identities, and integration by parts. It is important to understand the properties and rules of both exponential and trigonometric functions in order to properly integrate them.
3. What are the benefits of integrating exponential and trigonometric forms?
Integrating exponential and trigonometric forms allows for the solving of complex problems in fields such as physics, engineering, and economics. It also allows for a deeper understanding of the relationships between these two types of functions and how they can be used together in various applications.
4. What are some common applications of integrating exponential and trigonometric forms?
Some common applications of integrating exponential and trigonometric forms include calculating the area under a curve, determining the value of a definite integral, and solving differential equations. These concepts are used extensively in fields such as physics, engineering, and finance.
5. How can I improve my skills in integrating exponential and trigonometric forms?
To improve your skills in integrating exponential and trigonometric forms, it is important to practice regularly and familiarize yourself with various techniques and formulas. You can also seek out resources such as textbooks, online tutorials, and practice problems to further enhance your understanding and abilities.
