Reformulation of Loop gravity in progress, comment?
In summary, the May 2012 "discrete symmetries" paper arXiv 1205.0733 signals a reformulation getting under way, I think. I'm curious to know how other people read this.
  • #106
There's a direction I'd like to see, but that doesn't seem represented: what is the relationship between the two "visions" of classical general relativity emerging from LQG? The most definite sign is that the large j and small immirzi limit seems to give the Regge action. This is still dangerous because we know that depending on how the Regge action is "interpreted", results could be terrible (DT) or promising (CDT). The question is what interpretation does EPRL imply?
Dittrich is using tensor-network tools to try to coarse grain and get classical GR. Intuitively, that is more sensible. However, that does seem to ignore the clues from the large j limit - is she thinking that's a red herring, or is she secretly keeping that in mind?
  • #107
atyy said:
... The most definite sign is that the large j and small immirzi limit seems to give the Regge action. This is still dangerous because we know that depending on how the Regge action is "interpreted", results could be terrible (DT) or promising (CDT). The question is what interpretation does EPRL imply?
As you know both DT and CDT deal with only a severely limited space of geometries which are constructed by sticking identical blocks together, either all the same shape and size or of two different types. This does not recover the full Regge theory. The Triangulation people HOPE that this limited space of geometries is somehow representative of the full range found in nature.
In assembling identical block they have found that problems can develop---on the one hand feathery structures form, not compact enough, and on the other hand structures that are too compact can form: a kind of dog-pile with too many blocklets adjacent to each other.
The full Regge calculus does not use identical blocklets. It uses what amounts to a lattice of variable length rods. The dynamics involves the lengths of the rods. I never heard of Regges type of GR having the pathologies of DT, and don't see how it even could have (though of course I might be wrong.)
Anyway, Atyy, I do not consider DT and CDT as being alternate "interpretations" of Regge. So of course I did not understand your post. I do not think that Loop faces a fork in the road between two "interpretations": a terrible (DT) and a promising (CDT).
However if you think it does face such a fateful fork in the road, perhaps you should write an email and tell one of the experts about it. Dittrich, Rovelli, Thiemann. Surely if there is some "danger" which they have overlooked they should be warned about it.
My view is that the community is a substantial body of highly intelligent people who are alert to just about every potential problem connected to the approaches they are working on. I've watched the Loop approach evolve for almost 10 years now and they have repeatedly broken down roadblocks and surmounted obstacles, or found a way around them. There are certainly a lot of open problems---as Ashtekar recently said there are enough problems to keep the young researchers happily occupied for years to come. I think the community is always on the lookout for problems, and habitually goes after them vigorously. So it's exciting to watch. I don't expect Loop to stay vintage 2010 EPRL, I think it's already changing. But I do not know what the new shape will be and so am in suspense.
Convergence is probably a central problem that several of the developments I listed are addressing. Certainly the "tetrad-handedness" work is aimed at that. But also "dust" because everything is much simpler when you have time and a real Hamiltonian. And I vaguely suspect that Dittrich group's "holonomy spin foam" enterprise is going to take a swipe at the convergence problem, or at least the classical limit via coarse-graining. I'm not clear about this, it's just my two-bit hunch. You may have some ideas about the holonomy spinfoam business.
  • #108
Revised list of categories, with one omitted, look back to see definitions and links to sample research.
PhenoCosmo Observable effects of the Loop cosmology bounce and of bounce-triggered inflation.
Holonomy Spin Foam Models Spinfoam labels can be group elements. Finite groups. Kinship with lattice gauge theory. http://arxiv.org/abs/1208.3388 and references therein. New paper this week: http://arxiv.org/abs/1209.4539 .
Algebraic generalizations: tensorGFT and twistorLQG
FreeImmirzi and Geometric Operator Spectra
Tetrad-handedness
Relativity and Thermodynamics/Statistical Mechanics GR could be the equation of state and LQG the "molecules" (microscopic degrees of freedom).
Dust various means to recover time-evolution and real physical Hamiltonian.
Progress on any of these fronts could show up in the program at Loops 2013 and Warsaw GR20:
http://www.perimeterinstitute.ca/en/Events/Loops_13/Loops_13/
http://gr20-amaldi10.edu.pl
Perhaps the most notable development in this connection this week was the appearance of a new Holonomy Spin Foam paper by Dittrich et al. Ill get the link.
Holonomy Spin Foam Models: Boundary Hilbert spaces and Time Evolution Operators
Bianca Dittrich, Frank Hellmann, Wojciech Kaminski
(Submitted on 20 Sep 2012)
In this and the companion paper a novel holonomy formulation of so called Spin Foam models of lattice gauge gravity are explored. After giving a natural basis for the space of simplicity constraints we define a universal boundary Hilbert space, on which the imposition of different forms of the simplicity constraints can be studied. We detail under which conditions this Hilbert space can be mapped to a Hilbert space of projected spin networks or an ordinary spin network space.
These considerations allow to derive the general form of the transfer operators which generates discrete time evolution. We will describe the transfer operators for some current models on the different boundary Hilbert spaces and highlight the role of the simplicity constraints determining the concrete form of the time evolution operators.
51 pages, 18 figures
The companion paper referred to here appeared last month:
Holonomy Spin Foam Models: Definition and Coarse Graining
Benjamin Bahr, Bianca Dittrich, Frank Hellmann, Wojciech Kaminski
(Submitted on 16 Aug 2012)
We propose a new holonomy formulation for spin foams, which naturally extends the theory space of lattice gauge theories. This allows current spin foam models to be defined on arbitrary two-complexes as well as to generalize current spin foam models to arbitrary, in particular finite groups. The similarity with standard lattice gauge theories allows to apply standard coarse graining methods, which for finite groups can now be easily considered numerically. We will summarize other holonomy and spin network formulations of spin foams and group field theories and explain how the different representations arise through variable transformations in the partition function. A companion paper will provide a description of boundary Hilbert spaces as well as a canonical dynamic encoded in transfer operators.
36 pages, 12 figures.
  • #109
They are well aware of it. http://arxiv.org/abs/1204.5394
(I corrected the link.)
  • #110
==quote Atyy post #106==
==endquote==
==quote me, post #107==
==endquote==
==quote Atyy, post#109 ===
They are well aware of it. http://arxiv.org/abs/1207.4596
==endquote==
The Construction of Spin Foam Vertex Amplitudes
Eugenio Bianchi, Frank Hellmann
(Submitted on 19 Jul 2012 (v1), last revised 21 Jul 2012 (this version, v2))
Spin foam vertex amplitudes are the key ingredient of spin foam models for quantum gravity. They fall into the realm of discretized path integral, and can be seen as generalized lattice gauge theories. They can be seen as an attempt at a 4 dimensional generalization of the Ponzano-Regge model for 3d quantum gravity. We motivate and review the construction of the vertex amplitudes of recent spin foam models, giving two different and complementary perspectives of this construction. The first proceeds by extracting geometric configurations from a topological theory of the BF type, and can be seen to be in the tradition of the work of Barrett and Crane and Freidel and Krasnov. The second keeps closer contact to the structure of Loop Quantum Gravity and tries to identify an appropriate set of constraints to define a Lorentz-invariant interaction of its quanta of space. This approach is in the tradition of the work of Smolin, Markopoulous, Engle, Pereira, Rovelli and Livine.
22 Pages. 1 Figure. I
==endquote==
Discrete Gravity Models and Loop Quantum Gravity: a Short Review
Maite Dupuis, James P. Ryan, Simone Speziale
(Submitted on 24 Apr 2012 (v1), last revised 13 Aug 2012 (this version, v2))
We review the relation between Loop Quantum Gravity on a fixed graph and discrete models of gravity. We compare Regge and twisted geometries, and discuss discrete actions based on twisted geometries and on the discretization of the Plebanski action. We discuss the role of discrete geometries in the spin foam formalism, with particular attention to the definition of the simplicity constraints.
31 pages.
  • #111
I've listed 7 or so lines of development that bear watching but if I had to focus on one to see where it is going over the next 10 months, I believe I would pick Holonomy Spin Foam models. My hunch is it will produce the most by way of unexpected new stuff. I'm talking about the short term: results that will show up in the talks at Loops 2013 and Warsaw GR20:
A good brief introduction to HSF models is contained in the first part of this online seminar talk by Frank Hellmann:
http://relativity.phys.lsu.edu/ilqgs/hellmann090412.pdf
http://relativity.phys.lsu.edu/ilqgs/hellmann090412.wav
Holonomy Spin Foam Models: Asymptotic Dynamics
And here are the papers I was discussing a few posts back:
Incidentally here is a YouTube in which one of the authors is singing the young theoretical physicist song:
A point to make is that Lattice Gauge Theory is a large well-developed and established body of mathematical methods, and they are extending LGT in a way that the lattice geometry can vary so as to include gravity.
And moreover it looks like their generalized or extended LGT is able to contain many of the spinfoam models which have been defined by Quantum Relativists, including EPRL, as special cases within a single group-labeled 2-complex format.
This is somehow the way that mathematical evolution ought to go. From having several comparatively ad hoc and partially successful theories, evolution moves towards a single less ad hoc more comprehensive theory that contains them---also evolution is towards more structural assumptions and fewer adjustable parameters (which incidentally makes a theory more firmly testable). This feels right as a direction to move in. And also it feels right to connect up with an already well-developed body of method like LGT. And that means having the 2-complexes be labeled by GROUP elements, rather than with spin or representation labels. I think. If they can make all this work then it seems (to my dim eyes) like the way to go.
For additional light on this, I think we should also check the 2011 (and perhaps earlier) posts by longtime PF member "f-h" in case there is anything relevant to the present situation. My impression is the posts are informative, coolly objective, and to the point regarding the QG research picture.
https://www.physicsforums.com/search.php?searchid=3391085
Francesca sometimes takes part in the same threads and gives a valuable second perspective.
  • #112
A Dittrich Ryan paper just went on arxiv that will probably turn out to be quite important.
I wouldn't be surprised if Bianca Dittrich gives a seminar talk about it at Perimeter or discusses it when she has her ILQGS talk on 27 November. The title of that November seminar talk is still TBA.
This paper could have consequences, or so it seems to me. I'd like to hear others' comments. Here's the abstract:
http://arxiv.org/abs/1209.4892
On the role of the Barbero-Immirzi parameter in discrete quantum gravity
Bianca Dittrich, James P. Ryan
(Submitted on 21 Sep 2012)
The 1-parameter family of transformations identified by Barbero and Immirzi plays a significant role in non-perturbative approaches to quantum gravity, among them Loop Quantum Gravity and Spin Foams. It facilitates the loop quantization programme and subsequently the Barbero-Immirzi parameter (gamma) arises in both the spectra of geometrical operators and in the dynamics provided by Spin Foams. However, the debate continues as to whether quantum physics should be Barbero-Immirzi parameter dependent. Starting from a discrete SO(4)-BF theory phase space, we find two possible reductions with respect to a discrete form of the simplicity constraints. The first reduces to a phase space with gamma-dependent symplectic structure and more generally in agreement with the phase space underlying Loop Quantum Gravity restricted to a single graph - a.k.a. Twisted Geometries. The second, fuller reduction leads to a gamma-independent symplectic structure on the phase space of piecewise-flat-linear geometries - a.k.a. Regge geometries. Thus, the gamma-dependence of physical predictions is related to the choice of phase space underlying the quantization.
16 + 12 pages
  • #113
Anyone following the research of Dittrich and her co-authors probably has already watched or might wish to watch this February 2012 Perimeter video lecture.
http://pirsa.org/12020142/
Coarse graining spin nets with tensor networks
The first slide gives motivation:
Spin foam models--candidates for quantum gravity--give (very) small scale physics.
Most important question: what do they describe at large scales?
Spin foams can be understood as lattice systems:
--Use coarse graining to construct effective models for larger scales.
--Problem: spin foam models for gravity have amazingly complicated amplitudes. No coarse graining methods available. Simplify models drastically, keep "spin foam construction principle", develop and test coarse graining methods.
A "spin net" is analogous to a spin foam but dimensionally reduced. Edges take the place of 2D plaquettes.
This is part of the drastic simplification used in this exploratory research. Subsequently, as we have seen, they work back up to "holonomy spin foam" models. Which are spin foams where the labels are elements g of a group G instead of spins and the like.
refers to http://arxiv.org/abs/1109.4927
http://arxiv.org/abs/1111.0967 (shorter version)
==quote page 3 of 1109.4927==
Spin foams are a particular class of lattice gauge models (see e.g. [63] for a recent review and [11] for a review emphasizing the relation to lattice gauge and statistical physics models). Such models are specified by variables, taking values in some group G, associated to the edges of a lattice (or more generally an oriented 2–complex) and weights associated to the plaquettes. They can thus also be termed plaquette models.
A related class of models, which will be introduced below, are so called edge or spin net models [11]. Here group variables are associated to the vertices of a lattice (or more generically an oriented graph or 1–complex) and weights to the edges. This class includes the well–known Ising models, based on the group Z2. Indeed it will turn out that the structures involved in a spin net model are very similar to those involved in spin foam models – just that where, for instance, weights are associated to 2D plaquettes for spin foams, weights are associated to 1D edges in spin nets, similarly for the group variables and so on. In this sense spin nets are a simpler or dimensionally reduced form of spin foams...
==endquote==
  • #114
Narrowing down the areas we are watching will require taking some good and important work off the list, but I want to focus on just a few fronts where I think the development occurring could significantly change LQG in the near term. With some exceptions I will, for brevity, mention only one or two key papers in each category. Others could have been cited and were mentioned earlier in the thread.
http://www-library.desy.de/cgi-bin/spifaacce/find/hep/www?rawcmd=FIND+%28DK+LOOP+SPACE+AND+%28QUANTUM+GRAVITY+OR+QUANTUM+COSMOLOGY%29+%29+AND+%28GRAVITATIONAL+RADIATION+OR+PRIMORDIAL+OR+inflation+or+POWER+SPECTRUM+OR+COSMIC+BACKGROUND+RADIATION%29+AND+DATE%3E2008&FORMAT=www&SEQUENCE=citecount%28d%29
Ashtekar, Agullo, Nelson http://arxiv.org/abs/1209.1609 (A Quantum Gravity Extension of the Inflationary Scenario)
Ashtekar, Agullo, Nelson http://arxiv.org/abs/1204.1288 (Perturbations in loop quantum cosmology)
Artymowski, Dapor, Pawlowski http://arxiv.org/abs/1207.4353 (Inflation from non-minimally coupled scalar field in loop quantum cosmology)
Many more papers identifying observable effects, by various author: Barrau, Grain, Cailleteau, Vidotto, Mielczarek, and others.
Group-labeled Spinfoams Spinfoam labels can be group elements. Finite groups are introduced. This could change the way LQG is formulated.
Bahr, Dittrich,Hellmann, Kaminski http://arxiv.org/abs/1208.3388 (Holonomy Spin Foam Models: Definition and Coarse Graining)
Same authors http://arxiv.org/abs/1209.4539 (Holonomy Spin Foam Models: Boundary Hilbert spaces and canonical dynamics) .
Hellmann, Kaminski (Holonomy Spin Foam Models: Asymptotic dynamics of EPRL type models, in prep) .
For background, e.g. the transfer operator concept in spinfoam context:
Bahr, Dittrich, Ryan http://arxiv.org/abs/1103.6264 (Spin foam models with finite groups)
Immirzi Issues
Bianchi http://arxiv.org/abs/1204.5122 (Entropy of Non-Extremal Black Holes from Loop Gravity)
Dittrich, Ryan http://arxiv.org/abs/1209.4892 (On the role of the Barbero-Immirzi parameter in discrete quantum gravity)
Relativistic Thermodynamics/Statistical Mechanics of Geometry
Rovelli has a new paper out.
http://arxiv.org/abs/1209.0065
General relativistic statistical mechanics
(Submitted on 1 Sep 2012)
Understanding thermodynamics and statistical mechanics in the full general relativistic context is an open problem. I give tentative definitions of equilibrium state, mean values, mean geometry, entropy and temperature, which reduce to the conventional ones in the non-relativistic limit, but remain valid for a general covariant theory. The formalism extends to quantum theory. The construction builds on the idea of thermal time, on a notion of locality for this time, and on the distinction between global and local temperature. The last is the temperature measured by a local thermometer, and is given by kT = hbar dτ/ds, with k the Boltzmann constant, hbar the Planck constant, ds proper time and d tau the equilibrium thermal time.
9 pages. A tentative second step in the thermal time direction, 10 years after the paper with Connes. The aim is the full thermodynamics of gravity. The language of the paper is a bit technical: look at the Appendix first
Observer Space
Gielen, Wise http://arxiv.org/abs/1206.0658 (Linking Covariant and Canonical General Relativity via Local Observers)
See Derek Wise's ILQGS talk Tuesday 2 October:
"Lifting General Relativity to Observer Space".
  • #115
marcus said:
Observer Space
The June 2012 paper was published in General Relativity and Gravitation.
Derek Wise has a new way to do canonical LQG and link it with Spinfoam QG. Anyone who wants to read up on this before Wise's talk on Tuesday can get additional intuition and more explanation of the notation from this slightly longer 2011 paper also by Gielen and Wise:
http://arxiv.org/abs/1111.7195
Spontaneously broken Lorentz symmetry for Hamiltonian gravity
Steffen Gielen, Derek K. Wise
In Ashtekar's Hamiltonian formulation of general relativity, and in loop quantum gravity, Lorentz covariance is a subtle issue that has been strongly debated. Maintaining manifest Lorentz covariance seems to require introducing either complex-valued fields, presenting a significant obstacle to quantization, or additional (usually second class) constraints whose solution renders the resulting phase space variables harder to interpret in a spacetime picture. After reviewing the sources of difficulty, we present a Lorentz covariant, real formulation in which second class constraints never arise. Rather than a foliation of spacetime, we use a gauge field y, interpreted as a field of observers, to break the SO(3,1) symmetry down to a subgroup SO(3)_y. This symmetry breaking plays a role analogous to that in MacDowell-Mansouri gravity, which is based on Cartan geometry, leading us to a picture of gravity as 'Cartan geometrodynamics.' We study both Lorentz gauge transformations and transformations of the observer field to show that the apparent breaking of SO(3,1) to SO(3) is not in conflict with Lorentz covariance.
10 pages. Published in Physical Review D.
I also found this 2009 solo paper by Wise helpful:
http://arxiv.org/abs/0904.1738
Symmetric Space Cartan Connections and Gravity in Three and Four Dimensions
Derek K. Wise
Einstein gravity in both 3 and 4 dimensions, as well as some interesting generalizations, can be written as gauge theories in which the connection is a Cartan connection for geometry modeled on a symmetric space. The relevant models in 3 dimensions include Einstein gravity in Chern-Simons form, as well as a new formulation of topologically massive gravity, with arbitrary cosmological constant, as a single constrained Chern-Simons action. In 4 dimensions the main model of interest is MacDowell-Mansouri gravity, generalized to include the Immirzi parameter in a natural way. I formulate these theories in Cartan geometric language, emphasizing also the role played by the symmetric space structure of the model. I also explain how, from the perspective of these Cartan-geometric formulations, both the topological mass in 3d and the Immirzi parameter in 4d are the result of non-simplicity of the Lorentz Lie algebra so(3,1) and its relatives. Finally, I suggest how the language of Cartan geometry provides a guiding principle for elegantly reformulating any 'gauge theory of geometry'.
Incidentally this was written for a special issue of the journal SIGMA which was dedicated to Élie Cartan.
  • #116
I completely overlooked an important paper! It feeds into a potential near term reformulation of LQG. It is by Carrozza, Oriti, and Rivasseau about Tensorial GFT.
I should have had this paper on the 3rd quarter MIP poll (it came out in July) and somehow missed it.
Anyway, herewith another strand of current development, one of the halfdozen important lines of investigation that are part of the picture which I'm watching and trying to keep track of.
http://arxiv.org/abs/arXiv:1207.6734
http://inspirehep.net/record/1124138
Renormalization of Tensorial Group Field Theories: Abelian U(1) Models in Four Dimensions.
Sylvain Carrozza, Daniele Oriti, Vincent Rivasseau.
(Submitted on 28 Jul 2012)
We tackle the issue of renormalizability for Tensorial Group Field Theories (TGFT) including gauge invariance conditions, with the rigorous tool of multi-scale analysis, to prepare the ground for applications to quantum gravity models. In the process, we define the appropriate generalization of some key QFT notions, including: connectedness, locality and contraction of (high) subgraphs. We also define a new notion of Wick ordering, corresponding to the subtraction of (maximal) melonic tadpoles. We then consider the simplest examples of dynamical 4-dimensional TGFT with gauge invariance conditions for the Abelian U(1) case. We prove that they are super-renormalizable for any polynomial interaction.
33 pages, 8 figures.
If anyone wants to register a vote for this COR paper on the MIP poll just let me know--I will tally up those votes along with the rest.
This paper has only been out a couple of days more than 2 months and it already has 5 cites.
Carrozza will be giving an ILQGS online seminar on it soon, so if anybody is interested in Tensor QFT they can listen and get the audio+slides version, with the other participants asking questions. The talk is scheduled for Tuesday 30 October.
  • #117
November conference on Experimental Search for QG. The scheduled list of talks is out:
http://www.perimeterinstitute.ca/en/Events/Experimental_Search_for_QG/Experimental_Search_for_Quantum_Gravity%3A_the_hard_facts/
http://www.perimeterinstitute.ca/Events/Experimental_Search_for_QG/Schedule/
Revised update on some lines of investigation I think we should be keeping track of. For brevity only a few key papers are mentioned in each category. Others were mentioned earlier in the thread. Several of the themes here are covered in online seminar talks, e.g. ILQGS at http://relativity.phys.lsu.edu/ilqgs/
http://www-library.desy.de/cgi-bin/spiface/find/hep/www?rawcmd=FIND+%28DK+LOOP+SPACE+AND+%28QUANTUM+GRAVITY+OR+QUANTUM+COSMOLOGY%29+%29+AND+%28GRAVITATIONAL+RADIATION+OR+PRIMORDIAL+OR+inflation+or+POWER+SPECTRUM+OR+COSMIC+BACKGROUND+RADIATION%29+AND+DATE%3E2008&FORMAT=www&SEQUENCE=citecount%28d%29 (the link gave 64 papers today, won't always work though)
Many more papers identifying observable effects, by various author: Barrau, Grain, Cailleteau, Vidotto, Mielczarek, and others. Claus Kiefer's recent paper should be mentioned http://arxiv.org/abs/1210.0418 (Interpretation of the
Triad Orientations in Loop Quantum Cosmology) though being concerned with basic concepts rather than observable effects it does not fit in with these phenomenology papErs.
Group-labeled Spinfoams Spinfoam labels can be group elements. Finite groups are introduced. This could change the way LQG is formulated. Check out Hellmann's recent ILQGS talk 2 September.
Running G and gamma: black hole issues Bianchi's online ILQGS talk will be 16 October. I think his result helped set things up for yesterday's Ghosh and Perez paper.
Ghosh, Perez http://arxiv.org/abs/1210.2252 (The scaling of black hole entropy in loop quantum gravity)
They have G and the Immirzi γ run--going to G* and γ* in the UV limit. In the IR limit G=GNewton
We discuss some general properties of black hole entropy in loop quantum gravity from the perspective of local stationary observers at distance £ from the horizon. The present status of the theory indicates that black hole entropy differs from the low energy (IR) expected value A/(4G) (in natural units) in the deep Planckian regime (UV). The partition function is well defined if the number of non-geometric degrees of freedom gM(encoding the degeneracy of the area ap eigenvalue at a puncture p) satisfy the holographic bound gM < exp(ap/(4G)). Our framework provides a natural renormalization mechanism such that SUV ---> SIR=A/(4GNewton) as the scale £ flows.
For the scale they use a lowercase script L, which I can't type, so I use £ here.
Rovelli http://arxiv.org/abs/1209.0065 (General relativistic statistical mechanics)
Understanding thermodynamics and statistical mechanics in the full general relativistic context is an open problem. I give tentative definitions of equilibrium state, mean values, mean geometry, entropy and temperature, which reduce to the conventional ones in the non-relativistic limit, but remain valid for a general covariant theory. The formalism extends to quantum theory. The construction builds on the idea of thermal time, on a notion of locality for this time, and on the distinction between global and local temperature. The last is the temperature measured by a local thermometer, and is given by kT = hbar dτ/ds, with k the Boltzmann constant, hbar the Planck constant, ds proper time and d tau the equilibrium thermal time.​
Tensorial GFT Carroza will give an online talk on this at ILQGS on 30 October. Numerous others involved--I won't try to list.
Carrozza, Oriti, Rivasseau.http://arxiv.org/abs/arXiv:1207.6734 (Renormalization of Tensorial Group Field Theories: Abelian U(1) Models in Four Dimensions.)
We tackle the issue of renormalizability for Tensorial Group Field Theories (TGFT) including gauge invariance conditions, with the rigorous tool of multi-scale analysis, to prepare the ground for applications to quantum gravity models. In the process, we define the appropriate generalization of some key QFT notions, including: connectedness, locality and contraction of (high) subgraphs. We also define a new notion of Wick ordering, corresponding to the subtraction of (maximal) melonic tadpoles. We then consider the simplest examples of dynamical 4-dimensional TGFT with gauge invariance conditions for the Abelian U(1) case. We prove that they are super-renormalizable for any polynomial interaction.​
Dittrich's ILQGS talk set for 27 November is still "TBA". It could be on Group-valued Spinfoam models or might be concerned with understanding the Immirzi parameter (Dittrich and Ryan have a recent paper on that.)
  • #118
I'm trying to keep the list at no more than 5 topics. The last one should read (not simply "Tensorial GFT" but) Twistor LQG and Tensor GFT.
Twistor LQG and Tensor GFT Speziale will give an online ILQGS talk 13 November on a major Twistorial LQG paper he wrote with Wieland. I'll get the abstract in a moment. Carroza will talk about Tensorial GFT renormalization at ILQGS on 30 October. Several other researchers are involved on these two fronts--I won't try to list them.
Speziale, Wieland http://arxiv.org/abs/1207.6348 (The twistorial structure of loop-gravity transition amplitudes)
The spin foam formalism provides transition amplitudes for loop quantum gravity. Important aspects of the dynamics are understood, but many open questions are pressing on. In this paper we address some of them using a twistorial description, which brings new light on both classical and quantum aspects of the theory. At the classical level, we clarify the covariant properties of the discrete geometries involved, and the role of the simplicity constraints in leading to SU(2) Ashtekar-Barbero variables. We identify areas and Lorentzian dihedral angles in twistor space, and show that they form a canonical pair. The primary simplicity constraints are solved by simple twistors, parametrized by SU(2) spinors and the dihedral angles. We construct an SU(2) holonomy and prove it to correspond to the (lattice version of the) Ashtekar-Barbero connection. We argue that the role of secondary constraints is to provide a non trivial embedding of the cotangent bundle of SU(2) in the space of simple twistors. At the quantum level, a Schroedinger representation leads to a spinorial version of simple projected spin networks, where the argument of the wave functions is a spinor instead of a group element. We rewrite the Liouville measure on the cotangent bundle of SL(2,C) as an integral in twistor space. Using these tools, we show that the Engle-Pereira-Rovelli-Livine transition amplitudes can be derived from a path integral in twistor space. We construct a curvature tensor, show that it carries torsion off-shell, and that its Riemann part is of Petrov type D. Finally, we make contact between the semiclassical asymptotic behaviour of the model and our construction, clarifying the relation of the Regge geometries with the original phase space.​
Carrozza, Oriti, Rivasseau http://arxiv.org/abs/1207.6734 (Renormalization of Tensorial Group Field Theories: Abelian U(1) Models in Four Dimensions.)
  • #119
Pardon my ignorance, but, how does this work under lorentzian transforms? I have no idea, but, would appreciate help.
  • #120
Chronos said:
...how does this work under lorentzian transforms?...
The basic references are 2010 papers by Rovelli Speziale and by Wieland:
http://arxiv.org/abs/1012.1739
Lorentz covariance of loop quantum gravity
Carlo Rovelli, Simone Speziale
(Submitted on 8 Dec 2010)
The kinematics of loop gravity can be given a manifestly Lorentz-covariant formulation: the conventional SU(2)-spin-network Hilbert space can be mapped to a space K of SL(2,C) functions, where Lorentz covariance is manifest. ...
... As shown by Wolfgang Wieland in a related paper, this manifestly Lorentz-covariant formulation can also be directly obtained from canonical quantization. We show that the spinfoam dynamics of loop quantum gravity is locally SL(2,C)-invariant in the bulk, and yields states that are preciseley in K on the boundary. This clarifies how the SL(2,C) spinfoam formalism yields an SU(2) theory on the boundary. These structures define a tidy Lorentz-covariant formalism for loop gravity.
6 pages, 1 figure.
http://arxiv.org/abs/1012.1738
Complex Ashtekar variables and reality conditions for Holst's action
Wolfgang Wieland
From the Holst action in terms of complex valued Ashtekar variables additional reality conditions mimicking the linear simplicity constraints of spin foam gravity are found... The resulting kinematical Hilbert space matches the original one of loop quantum gravity, that is for real valued Ashtekar connection. Our result perfectly fit with recent developments of Rovelli and Speziale concerning Lorentz covariance within spin-form gravity.
24 pages, 2 pictures
  • #121
I guess everybody who follows Loop gravity research knows the most recent definitive formulation was http://arxiv.org/abs/1102.3660 (the Zakopane lectures) and that was a fairly complete presentation of the theory as of 2010 which was what the papers that I just referenced, by Rovelli Speziale and by Wieland, were talking about.
what we are talking about in this thread is a prospective REFORMULATION which might or might not happen before the next Loops conference (July 2013). The Loops conference is held approximately every two years and the field is active enough so that the theory can change substantially---it can be interesting to watch.
One possible reformulation seems to be taking shape in the TWISTOR LQG paper by Speziale and Wieland. You will find the abstract to that if you look back 3 or 4 posts in this thread.
If there is a reformulation before July 2013, and a new standard version of the theory, and if it is the "twistorial" version proposed by Speziale and Wieland (for instance) then we can AGAIN ask about Lorentz covariance.
My guess is that the new version (if there is one) will be just as Lorentz covariant as the 2010 version. But of course that is in the future and we cannot know the future.
Right now I am keenly interested in identifying and focusing on the handful of new developments that could contribute to a nearterm reformulation of the theory. These are the things I expect to figure significantly in the Loops 2013 conference at Perimeter. Here is a checklist of short names--to help us (or at least me) keep them all in mind. All five bear watching:
  • PhenoCosmo
  • Group-tagged foam
  • Black holes where G and gamma run
  • Rel-istic Stat Mech and Thermo
  • Twistor Loop Tensor Group
These are abbreviated names so you and I can review the checklist in our minds without stumbling over a lot of of extra syllables. what they refer to is spelled out in more detail a few posts back in this thread, and links to sample research papers are given. For instance look back to post #117
  • #122
Gene Bianchi gives an important seminar talk tomorrow 16 October. It will be online.
BTW He was recently awarded a Banting fellowship at Perimeter, which made the Perimeter website front page :-D
Tomorrow's talk is Horizon entropy from loop gravity
My personal hunch is that this frees the Immirzi to run with scale, as in the topic "Black holes where G and gamma run" on the mnemonic checklist given earlier. As I see it (others may differ) Bianchi's result leads into work by Ghosh Perez reported in their October paper, wherre both G and gamma run with scale.
What I'm aiming to do with that checklist is to keep 5 different topics or research fronts in mind---corresponding to investigation which I expect to play a role in the run-up to Loops 2013. Research themes that might figure in a near-term reformulation of the theory. I want the mnemonic topic names to be short and memorable so when I'm away from the computer, e.g. out taking a walk in the hills, or for some reason have a free moment, I can review the list and say over to myself the main features of what's going on in Loop research. Holonomy spinfoams just means you label the foam with GROUP elements instead of spins or group representation symbols. So it is no longer a spin-labeled foam, it is a group-labeled foam. So traveling thru the foam, different rotations and stuff happen to you corresponding to the group element living along the edge you are traversing. Bianca Dittrich's group is working on "holonomy spinfoam models" and to say that quickly as a short mnemonic I just call it group-tagged-foam.
Gene Bianchi's 16 October talk relates to the third topic on the list.
  • PhenoCosmo
  • Group-tagged foam
  • Relistic Stat Mech and Thermo
Stat Mech and Thermodynamics have NOT YET been give a fully General Relativistic treatment. So the fourth research thrust listed here is important. "Tensor Group" is short for "Tensorial Group Field Theory". 9 syllables instead of 3. And my personal guess is that the most promising nearterm reformulation of LQG is coming from "Twistorial Loop Quantum Gravity" (10 syllables instead of 3) as per work of Speziale Wieland.
To make it clearer to anyone new, I'll give a sample recent paper in each topic:
  • #124
Sample of recent Perimeter talks ( http://pirsa.org ) relevant to the current QG directions, now online:
Understanding black hole entropy through the renormalization group
Speaker(s): Alejandro Satz
Abstract: It is known that the entanglement entropy of quantum fields on the black hole background contributes to the Bekenstein-Hawking entropy,and that its divergences can be absorbed into the renormalization of gravitational couplings. By introducing a Wilsonian cutoff scale and the concepts of ... read more
Date: 18/10/2012 - 2:30 pm
Series: Quantum Gravity
URL: http://pirsa.org/12100053/
Matter-wave clocks
Speaker(s): Holger Mueller
Abstract:
Date: 22/10/2012 - 9:15 am
Collection: Experimental Search for Quantum Gravity
URL: http://pirsa.org/12100124/
The cosmological constant and the emergence of the continuum
Speaker(s): Lorenzo Sindoni
Abstract: Naturalness problems that could be signaling the necessity a completion of an effective field theory with the introduction of an otherwise overlooked ingredient. The cosmological constant problem can be seen as a signal that the EFT for gravity, general relativity, is not correctly including t... read more
Date: 22/10/2012 - 12:00 pm
URL: http://pirsa.org/12100081/
Is there a MesoScale in Quantum Gravity? Is it a Non-Locality Scale?
Speaker(s): Stefano Liberati, Dionigi Benincasa, Laurent Freidel
Abstract:
Date: 22/10/2012 - 2:00 pm
URL: http://pirsa.org/12100082/
The highest-energy particles of the Universe as viewed by the Pierre Auger Observatory
Speaker(s): Markus Risse
Abstract: One century after the seminal balloon flights of Victor Hess, the Pierre Auger Observatory aims at unveiling some of the mysteries of the highest-energy cosmic rays: what are their sources? Is there an end to the spectrum? What kind of particles are they? Are there signatures of new physics or... read more
Date: 23/10/2012 - 9:00 am
URL: http://pirsa.org/12100089/
Is spacetime fundamentally discrete?
Speaker(s): Bianca Dittrich, Daniele Oriti, Tobias Fritz, Seth Major, Roberto Percacci
Abstract: Modelling continuum dynamics on discrete space time
We will discuss perfect discretizations which aim at mirroring exactly continuum physics on a given lattice. Such discretizations avoid typical artifacts like Lorentz violation, energy dissipation, p... read more
Date: 24/10/2012 - 9:00 am
URL: http://pirsa.org/12100100/
Dynamical Dimensional Reduction
Speaker(s): Martin Reuter, Astrid Eichhorn, Dejan Stojkovic
Abstract: Dynamical dimensional reduction and Asymptotic Safety
The effective average action approach to Quantum Einstein Gravity (QEG) is discussed as a natural framework for exploring the scale dependent Riemannian geometry and multifractal micro-structure of ... read more
Date: 24/10/2012 - 11:30 am
URL: http://pirsa.org/12100104/
  • #125
Bee Hossenfelder has a summary of the recent conference (Experimental Search for Quantum Gravity) at her blog.
http://backreaction.blogspot.com/2012/10/esqg-2012-conference-summary.html
Sylvain Carrozza gave his seminar talk at ILQGS today and the slides and audio are available online:
http://relativity.phys.lsu.edu/ilqgs/carrozza103012.pdf
http://relativity.phys.lsu.edu/ilqgs/carrozza103012.wav
Simone Speziale is up next, in one week (6 November)
Twistorial structure of loop quantum gravity transition amplitudes
  • #126
As context to the Carrozza seminar talk today, here is an October 1 post of mine.
Here, again, are the links to Carrozza's seminar talk.
The talk is good and there is extensive questioning and discussion by Joseph Ben Geloun, Lee Smolin, Laurent Freidel, Carlo Rovelli, Abhay Ashtekar, Daniele Oriti and I believe others whose names I didn't catch.
  • #127
If it turns out (as judging from the interest in Carrozza Oriti Rivasseau's paper it conceivably might) that TGFT (tensorial group field theory) serves as basis for a nearterm reformulation of LQG/SF, then those who wish to follow what is going on in the field could find this tutorial by Krajewski useful:
http://arxiv.org/abs/1210.6257
Group field theories
Thomas Krajewski
(Submitted on 23 Oct 2012)
Group field theories are particular quantum field theories defined on D copies of a group which reproduce spin foam amplitudes on a space-time of dimension D. In these lecture notes, we present the general construction of group field theories, merging ideas from tensor models and loop quantum gravity. This lecture is organized as follows. In the first section, we present basic aspects of quantum field theory and matrix models. The second section is devoted to general aspects of tensor models and group field theory and in the last section we examine properties of the group field formulation of BF theory and the EPRL model. We conclude with a few possible research topics, like the construction of a continuum limit based on the double scaling limit or the relation to loop quantum gravity through Schwinger-Dyson equations
58 pages, Lectures given at the "3rd Quantum Gravity and Quantum Geometry School", March 2011, Zakopane
  • #128
For several reasons I think this paper represents a critical development in the emerging reformulation that I'm trying to understand
Interpretation of the triad orientations in loop quantum cosmology
Claus Kiefer, Christian Schell
(Submitted on 1 Oct 2012)
Loop quantum cosmology allows for arbitrary superpositions of the triad variable. We show here how these superpositions can become indistinguishable from a classical mixture by the interaction with fermions. We calculate the reduced density matrix for a locally rotationally symmetric Bianchi I model and show that the purity factor for the triads decreases by decoherence. In this way, the Universe assumes a definite orientation.
12 pages, 1 figure
This is the first paper in which I remember the density matrix and its purity index trace(ρ2) playing a central role in LQC. This is a more general notion of quantum state--the vonNeumann algebra, or C*-algebra approach to QM.
We can see signs of this shift (in how things are formulated) appearing in LQG, in other papers. But this is the first time I'm aware of it's happening in the Cosmology application LQC.
  • #129
As a reminder, here are a half-dozen research areas where this approach to Quantum Gravity is being reshaped. All the ILQGS talks mentioned are now online with the sole exception of Bianca Dittrich's scheduled for 27 November.
twistorLQG (Speziale's ILQGS talk and 1207.6348)
tensorialGFT (Carrozza's ILQGS talk and 1207.6734)
holonomySF (Hellmann's ILQGS talk and 1208.3388)
dust (Wise's ILQGS talk and 1210.0019)
hybrid LQC
An Extension of the Quantum Theory of Cosmological Perturbations to the Planck Era (1211.1354)
The pre-inflationary dynamics of loop quantum cosmology: Confronting quantum gravity with observations (in prep)
GR Thermo and C*-algebra
General relativistic statistical mechanics (1209.0065)
Horizon entanglement entropy and universality of the graviton coupling (Bianchi's ILQGS talk and 1211.0522)
Interpretation of the triad orientations in loop quantum cosmology (1210.0418)
I think the last topic is critical, namely general relativistic thermodynamics (broadly interpreted to include statistical mechanics and the operator algebra formulation).
First it is clear that to be fully successful LQG has to encompass the LQC bounce, with matter and inhomogeneity--we already see that beginning to happen. In encompassing the bounce the model seemingly must include the dissipation or shrinkage of horizons and their vonNeumann entropy, with the emergence of a pure state.
I recently added the Kiefer and Schell paper http://arxiv.org/abs/1210.0418 as an indication of where that is going. Kiefer Schell have the purity/mixedness of quantum states run on a continuum from zero to one. A state is a trace-class operator ρ on the hilbert space, a generalized "density matrix". Pure states are those for which tr(ρ2) = 1, a kind of "purity index". As these gradually decohere, the purity index comes down from 1 to zero. In Kiefer Schell's case the quantum state of geometry does this as it interacts with the matter in the environment. If I'm not mistaken, LQG dynamics will be extended to include states of this density matrix ρ type (as Kiefer and Schell do with LQC) and Rovelli's September paper is a step in this direction. Then the problem will be to understand how the purity index of the state is driven *up* during bounce. Intuitively there is a "release of information" when Planckian density density is approached, and information that had become inaccessible becomes accessible (in the repellent gravity phase of the bounce.) I could of course have this wrong, so I'm looking for other viewpoints.
  • #130
Let's just look at the last 4 of the above LQG initiatives. HSF answers criticism by Alexandrov, so we can disregard the latter.
See Hellmann's comment here:
https://www.physicsforums.com/showthread.php?p=4162474#post4162474
(If anyone is new to the discussion, Frank Hellmann posts here as f-h.)
Dittrich may have some more to say about holonomy spin foam models in her ILQGS talk on 27 November.
The main thing I have to say right now is that in a certain sense all of the last three are working towards the same goal. The point is that a thermal state automatically breaks Lorentz invariance e.g. page 18 of Connes Rovelli gr-qc/9406019. So it is a no-brainer that any thermal state would have its own inherent notion of time. The challenge is to realize this in GR, what is a thermal state in GR which is timeless?
If one can do that, one finesses "dust". Thermal time and dust are reading from the same page of the book.
hybrid LQC
And hybrid LQC (the breakground work of Agullo Ashtekar Nelson) is a way of putting an infinity of DoF into LQG cosmology, around the time of the bounce before conventional inflation begins. This gives a way to grasp the thermal state. So these three things are, I think, aimed at one goal.
  • #131
In two days Dittrich will give an online ILQGS talk, the last one of the fall semester.
Nov. 27 Coarse graining: towards a cylindrically consistent dynamics Bianca Dittrich Perimeter Institute
http://relativity.phys.lsu.edu/ilqgs/ (online audio and slides PDF)
This will probably be an important talk to hear for anyone wishing to follow developments in LQG (or quantum gravity in general). This will presumably be the second Holonomy Spin Foam (HSF) talk at ILQGS this fall and based on
An earlier HSF talk was given Sept. 4 Holonomy Spin Foam Models: Asymptotic Dynamics by Frank Hellmann of Albert Einstein Institute
Other HSF papers which have appeared recently:
http://arxiv.org/abs/1210.5276
Geometric asymptotics for spin foam lattice gauge gravity on arbitrary triangulations
Holonomy spinfoam models are a different kind of spinfoam, similar to lattice connection theories in that they use group element labels living on the 2-complex. Notice that the title of an HSF talk or paper does not necessarily signal that it is HSF by including the word "holonomy". The title of the Hellmann Kaminski paper simply says "spin foam lattice gauge gravity" and you are supposed to understand that it is HSF (a point clearly made in the introduction). I gather from comments made that people working on HSF (coarse graining, asymptotics, dynamics...) have indicated they see the approach as overcoming some obstacles/unresolved questions in the earlier version of spinfoam.
Dittrich is one the main people in charge of organizing next year's Loops conference at PI, and also the senior organizer of the LQG parallel sessions at the GR-20 conference to be held next year in Warsaw.
GR-20 Warsaw (week of 7 July):
http://gr20-amaldi10.edu.pl/index.php?id=18
Loops 2013 Perimeter Institute (week of 21 July):
http://www.perimeterinstitute.ca/conferences/loops-13
__________________
If I had to bet now concerning the future course of LQG development---near future, see where we are in July 2013---I think I would say, as of now, that the two most interesting lines of development are HSF and a nexus of ideas I would call
"GR thermo, C*-algebra, hybrid LQC"
I see these things as coming together and clarifying, among other things, the LQC bounce (which is where the opening to phenomenology seems to be IMHO). Hybrid LQC puts Fock into the bounce picture--lots of particles and geometric fluctuations. (See latest Agullo Ashtekar Nelson.)
The C*-algebra formalism gives a way to do general covariant statistical quantum mechanics. (See new version of http://arxiv.org/abs/1209.0065 that was uploaded 19 November with a new section (Appendix B4) at the end with title something like "GC statistical QM".
  • #132
The slides PDF for Dittrich's talk is already online.
http://relativity.phys.lsu.edu/ilqgs/dittrich112712.pdf
It's about Coarse Graining spinfoam QG and spin net etc. and it is an exceptionally
clear set of slides. Refers to a lot of work in progress (w.i.p.) and recent papers.
Try here http://relativity.phys.lsu.edu/ilqgs/ later in the day to see if audio is online.
You can already learn quite a bit about their approach to coarse graining (and thus the largescale limit) simply by examining the slides. Sample page of computer code. Many diagrams.
EDIT: The audio also is now on line! It's a good talk. Here's the audio.
http://relativity.phys.lsu.edu/ilqgs/dittrich112712.wav
Most of the question time is Dittrich discussing with Ashtekar and Rovelli. Around minute 2, more exactly 2:20, from the end Francesca gets in a question.
Bianca's group is running computer simulations of their coarse-graining strategies. The slide graphics of how the coarsegraining works is well thought out and communicates effectively (when there is the audio explanation along with it).
The type of spinfoam they use is HSF (holonomy sf) and the 2D analog of that is what they call spin net. Both have group element labels rather than some other kind (e.g. spins, twistors). But much of the work involves highly simplified toy models. Not QG. Regular lattices. This does not mean it's trivial or uninteresting! On the contrary, I would say. It looks to me as if an effective method of coarsegraining for 4D spinfoam QG is being developed, and one that can be implemented numerically. If that is the case it will be a substantial advance.
  • #133
I need to elaborate the nexus of ideas mentioned in posts #130 and 131 that seem to be coming to a better understanding of the LQC bounce.
"GR thermo, GC statistical QM, hybrid LQC, pre-inflationary dynamics, matter bounce"
marcus said:
Holonomy spinfoam models are a different kind of spinfoam, similar to lattice connection theories in that they use group element labels living on the 2-complex...
...I gather from comments made that people working on HSF (coarse graining, asymptotics, dynamics...) have indicated they see the approach as overcoming some obstacles/unresolved questions in the earlier version of spinfoam.
Back in post #130 I mentioned the paper Pre-inflationary LQC the PennState people (Agullo Ashtekar Nelson*) have in preparation. Now there's another paper contributing to our understanding of the LQC bounce, this time by Wilson-Ewing (PennState PhD now at Marseille):
The Matter Bounce Scenario in Loop Quantum Cosmology
Edward Wilson-Ewing
(Submitted on 27 Nov 2012)
In the matter bounce scenario, a dust-dominated contracting space-time generates scale-invariant perturbations that, assuming a nonsingular bouncing cosmology, propagate to the expanding branch and set appropriate initial conditions for the radiation-dominated era. Since this scenario depends on the presence of a bounce, it seems appropriate to consider it in the context of loop quantum cosmology where a bouncing universe naturally arises. It turns out that quantum gravity effects play an important role beyond simply providing the bounce. Indeed, quantum gravity corrections to the Mukhanov-Sasaki equations significantly modify some of the results obtained in a purely classical setting: while the predicted spectra of scalar and tensor perturbations are both almost scale-invariant with identical small red tilts in agreement with previous results, the tensor to scalar ratio is now expected to be r≈ 9 x 10-4, which is much smaller than the original classical prediction. Finally, for the predicted amplitude of the scalar perturbations to agree with observations, the critical density in loop quantum cosmology must be of the order ρcrit ~ 10-9 ρPlanck.
8 pages
Francesca's November 2012 review talk at the Stockholm fundamental cosmology conference already discusses the QG corrected Mukhanov-Sasaki equation as per Wilson-Ewing. This Loop matter-bounce paper could have a profound impact. Corrected M-S has the same ρ/ρPl term as the QG corrected Friedmann eqn. Both corrections are "Planck-suppressed", IOW they only take effect as the energy density approaches Planck density. Including the matter-bounce means that the rebound of a collapsing classical phase occurs sooner at much lower density.
*Nelson was at PennState and is now at Nijmegen, he also gave a talk at the Stockholm cosmology conference.
  • #134
Classical/semiclassical corroboration--chaos, volume gap
New work by Hal Haggard--solo and with Eugenio Bianchi--and by Berndt Müller (10,000 lifetime cites, previous work in nuclear theory and hep-phenomenology) reveals classical physics evidence supporting LQG quantized view of space and the volume gap. This is the idea that the LQG volume operator should have a gap between zero and the first positive eigenvalue.
Intuitively that there should be a lowest volume that you can measure. Space geometry discreteness idea.
What does chaos, a property exhibited by classical dynamics in certain cases, have to do with this?
It seems as if the recent work by Haggard, Bianchi, Müller, Coleman-Smith... could be opening up a new line of LQG research--something we need to notice and try to understand if we're following the field. I'll fetch some links.
http://arxiv.org/abs/1211.7311
Pentahedral volume, chaos, and quantum gravity
Hal M. Haggard
(Submitted on 30 Nov 2012)
We show that chaotic classical dynamics associated to the volume of discrete grains of space leads to quantal spectra that are gapped between zero and nonzero volume. This strengthens the connection between spectral discreteness in the quantum geometry of gravity and tame ultraviolet behavior. We complete a detailed analysis of the geometry of a pentahedron, providing new insights into the volume operator and evidence of classical chaos in the dynamics it generates. These results reveal an unexplored realm of application for chaos in quantum gravity.
5 pages, 4 figures
http://lanl.arxiv.org/abs/1212.1930
A "Helium Atom" of Space: Dynamical Instability of the Isochoric Pentahedron
C. E. Coleman-Smith, B. Muller
(Submitted on 9 Dec 2012)
We present an analysis of the dynamics of the equifacial pentahedron on the Kapovich-Millson phase space under a volume preserving Hamiltonian. The classical dynamics of polyhedra under such a Hamiltonian may arise from the classical limit of the node volume operators in loop quantum gravity. The pentahedron is the simplest nontrivial polyhedron for which the dynamics may be chaotic. We consider the distribution of polyhedral configurations throughout the space and find indications that the borders between certain configurations act as separatrices. We examine the local stability of trajectories within this phase space and find that locally unstable regions dominate although extended stable regions are present. Canonical and microcanonical estimates of the Kolmogorov-Sinai entropy suggest that the pentahedron is a strongly chaotic system. The presence of chaos is further suggested by calculations of intermediate time Lyapunov exponents which saturate to non zero values.
20 Pages, 19 Figures
http://arxiv.org/abs/1102.5439
Discreteness of the volume of space from Bohr-Sommerfeld quantization
Eugenio Bianchi, Hal M. Haggard
(Submitted on 26 Feb 2011 (v1), last revised 6 Jun 2011 (this version, v2))
A major challenge for any theory of quantum gravity is to quantize general relativity while retaining some part of its geometrical character. We present new evidence for the idea that this can be achieved by directly quantizing space itself. We compute the Bohr-Sommerfeld volume spectrum of a tetrahedron and show that it reproduces the quantization of a grain of space found in loop gravity.
4 pages, 4 figures; to appear in PRL
http://arxiv.org/abs/1208.2228
Bohr-Sommerfeld Quantization of Space
(Submitted on 10 Aug 2012)
We introduce semiclassical methods into the study of the volume spectrum in loop gravity. The classical system behind a 4-valent spinnetwork node is a Euclidean tetrahedron. We investigate the tetrahedral volume dynamics on phase space and apply Bohr-Sommerfeld quantization to find the volume spectrum. The analysis shows a remarkable quantitative agreement with the volume spectrum computed in loop gravity. Moreover, it provides new geometrical insights into the degeneracy of this spectrum and the maximum and minimum eigenvalues of the volume on intertwiner space.
32 pages, 10 figures
It was surprising how close the semiclassical numbers were to the numbers computed using the full LQG quantum theory. At that point they were using TETRAHEDRON volume dynamics. Notice the gradual ratcheting up of complexity---now to pentahedron---in the newer papers.
In case anyone is interested in Berndt Müller's earlier research interests http://inspirehep.net/author/B.Muller.1/
  • #135
Yesterday's Pirsa talk on chaos and quantum mechanics:
http://pirsa.org/12120036/ (online video)
Quantum Chaos, Information Gain and Quantum Tomography.
Speaker(s): Vaibhav Madhok
Abstract: Quantum chaos is the study of quantum systems whose classical description is chaotic. How does chaos manifest itself in the quantum world? In recent years, attempts have been made to address this question from the perspective of quantum information theory. It is in this spirit that we study the connection between quantum chaos and information gain in the time series of a measurement record used for quantum tomography...
... We make predictions for the information gain using random matrix theory in the fully chaotic regime and show a remarkable agreement between the two.
Date: 11/12/2012 - 3:30 pm
What I highlighted is the general question that the papers by Hal Haggard and by Berndt Müller also seem to be getting at. Particularly http://arxiv.org/abs/1211.7311
and http://arxiv.org/abs/1212.1930
I continue to be impressed by how many active directions of research in LQG there are at present. I listed some of them a few posts back. I suspect the map of LQG is going to be quite different in July when Loops 2013 is held, from what it was at the previous Loops conference held in 2011 at Madrid.
  • #136
Is it possible that Mielczarek is on to something? Can we give meaning to what he says here which seems so incomprehensible the first time I read it?
At Planck scale, or thereabouts, the spacetime causal structure would be numbed as if by a massive shot of novocaine, into non-existence. All lines of communication go dead?
But he is working in a LQG cosmology context here. Wouldn't there be a bounce well before that density is reached?
http://arxiv.org/abs/1212.3527
Asymptotic silence in loop quantum cosmology
Jakub Mielczarek
(Submitted on 14 Dec 2012)
The state of asymptotic silence, characterized by causal disconnection of the space points, emerges from various approaches aiming to describe gravitational phenomena in the limit of large curvatures. In particular, such behavior was anticipated by Belinsky, Khalatnikov and Lifgarbagez (BKL) in their famous conjecture put forward in the early seventies of the last century. While the BKL conjecture is based on purely classical considerations, one can expect that asymptotic silence should have its quantum counterpart at the level of a more fundamental theory of quantum gravity, which is the relevant description of gravitational phenomena in the limit of large energy densities. Here, we summarize some recent results which give support to such a possibility. More precisely, we discuss occurrence of the asymptotic silence due to polymerization of space at the Planck scale, in the framework of loop quantum cosmology. In the discussed model, the state of asymptotic silence is realized at the energy density ρ = ρc/2, where ρc is the maximal allowed energy density, being of the order of the Planck energy density. At energy densities ρ > ρc/2, the universe becomes 4D Euclidean space without causal structure. Therefore, the asymptotic silence appears to be an intermediate state of space between the Lorentzian and Euclidean phases.
4 pages, 3 figures
I would like to dismiss this as too far-out, but don't feel that I can. LQG research is going in a bewildering variety of different directions right now. I don't remember it ever being so multi pronged in past years.
  • #137
I'll recall post #129 at the top of this page, just so we don't get so intrigued by detail that we lose track of the full spectrum of different ways QG is being reshaped in the runup to the main QG conference (Loops 13 July of next year).
==quote post #129==
hybrid LQC
Horizon entanglement entropy and universality of the graviton coupling (Bianchi's ILQGS talk and 1211.0522 and 1212.5183)
I recently added the Kiefer and Schell paper http://arxiv.org/abs/1210.0418 as an indication of where that is going. Kiefer Schell have the purity/mixedness of quantum states run on a continuum from zero to one. A state is a trace-class operator ρ on the hilbert space, a generalized "density matrix". Pure states are those for which tr(ρ2) = 1, a kind of "purity index". As these gradually decohere, the purity index comes down from 1 to zero. In Kiefer Schell's case the quantum state of geometry does this as it interacts with the matter in the environment. If I'm not mistaken, LQG dynamics will be extended to include states of this density matrix ρ type (as Kiefer and Schell do with LQC) and Rovelli's September paper is a step in this direction. ...
==endquote==
Claus Kiefer's recent LQG paper is a step in the direction of the "star algebra" formulation of QG---where the basic mathematical object is (M,ω) an observables algebra M with a state function ρ: M→ℂ which gives the correlations and expectation values.
In the the entanglement entropy part of above post, I added a reference (in red) to a new paper by Bianchi and Myers:
http://arxiv.org/abs/1212.5183
On the Architecture of Spacetime Geometry
Eugenio Bianchi, Robert C. Myers
(Submitted on 20 Dec 2012)
We propose entanglement entropy as a probe of the architecture of spacetime in quantum gravity. We argue that the leading contribution to this entropy satisfies an area law for any sufficiently large region in a smooth spacetime, which, in fact, is given by the Bekenstein-Hawking formula. This conjecture is supported by various lines of evidence from perturbative quantum gravity, simplified models of induced gravity and loop quantum gravity, as well as the AdS/CFT correspondence.
8 pages, 1 figure
  • #138
The idea of this thread is to keep track of the full spectrum of different ways QG is being reshaped in the runup to the main QG conference http://www.perimeterinstitute.ca/conferences/loops-13 (Loops 13 at Perimeter Institute in July 2013).
The Bianchi Myers paper noted in previous post seems remarkably rich in useful ideas--I'm not sure what the right word is, "fertile" maybe? At least to me, it suggests how, if LQG were put in C*-algebra form, one might define 3D REGIONS by subsets of the algebra satisfying an entanglement-area condition. Note the word "architecture" in the title, as indicative of how the authors are thinking.
In any case it adds an exciting motivation to the (M, ω) world format. How can a smooth manifold picture emerge from some instance of (M, ω)? Perhaps one can state a condition in terms of entanglement entropy of certain subsets of the algebra. This is mentioned simply for motivation and I won't speculate further. I will list the various reformulation fronts in a different order.
Loop cosmology is getting into inhomogeneous regimes with multiple degrees of freedom and exploring "pre-inflationary" dynamics in more detail. Provisionally I'm calling that "hybrid loop cosmology" because several recent papers join existing LQC bounce with Fock space in a kind of hybrid. I can't list all the papers developing inhomogeneous LQC, so will just mention a couple.
hybrid LQC
Agullo Ashtekar Nelson—An Extension of the Quantum Theory of Cosmological Perturbations to the Planck Era (http://arxiv.org/abs/1211.1354)
It's hard to know what to call the next development. Perhaps "C*-quantum gravity, T-time, and entanglement entropy".
Work towards general covariant (GC) analysis such as GC-thermo, GC statistical (quantum) mechanics seems to motivate an (M,ω) formulation. This finally solves the time problem because one gets an observer-independent (Tomita) flow on the observables algebra. But how do we recover the regional STRUCTURE of space in the (M,ω) context? I see Bianchi Myers paper in this light. The key word "architecture" in the title is a signal. Also Kiefer Schell paper leans in that direction.
C*-quantum gravity, T-time, entanglement
Rovelli—General relativistic statistical mechanics (http://arxiv.org/abs/1209.0065)
Bianchi—Horizon entanglement entropy and universality of the graviton coupling (ILQGS talk and http://arxiv.org/abs/1211.0522)
Bianchi Myers—On the Architecture of Spacetime Geometry (http://arxiv.org/abs/1212.5183)
Kiefer Schell—Interpretation of the triad orientations in loop quantum cosmology (http://arxiv.org/abs/1210.0418)
Besides the above there are several other clear reformulation initiatives under way.
twistorLQG (Speziale's ILQGS talk and http://arxiv.org/abs/1207.6348)
tensorialGFT (Carrozza's ILQGS talk and http://arxiv.org/abs/1207.6734)
holonomySF (Hellmann's ILQGS talk and http://arxiv.org/abs/1208.3388)
dust (Wise's ILQGS talk and http://arxiv.org/abs/1210.0019)
  • #139
The ILQGS (international LQG seminar) is a good pointer to active areas of QG research---one can see this in the previous post: several of the themes we identified were represented not only by recent papers but also by Fall 2012 semester talks. Jorge Pullin organizes the ILQGS and I think he does a great job.
Part of the Spring 2013 schedule is posted now and we can examine it to help get a clearer picture of current research developments.
Jan 29th Entanglement in loop quantum gravity — Eugenio Bianchi — Perimeter Institute.
Feb 12th Dynamical chaos and the volume gap — Hal Haggard — CPT Marseille
Feb 26th Gravity electroweak unification — Stephon Alexander — Haverford College
Mar 12th .....
Mar 26th Bianchi I LQC — Brajesh Gupt — LSU
The 26 March talk by Gupt exemplifies the current trend in Loop cosmology towards cosmic models which are less uniform: not homogeneous and isotropic. For many years at the beginning LQC deal with uniform models with a correspondingly small number of degrees of freedom. Now they are running models which achieve a bounce (where the singularity used to be) but involve more complex variation. The socalled "Bianchi I" models are only one example.
Others of the talks are on topics that feature in our 4th quarter MIP poll. I have to go---there's more to say about this.
  • #140
As suggested in preceding post, we can get an idea of the active directions in Loop research by seeing what the Spring semester ILQGS talks will be about. For instance, I think the 29 January talk by Bianchi will be important and could be based on his November 2012 paper. This I think is a breakthrough paper, as I will explain.
Eugenio Bianchi
(Submitted on 2 Nov 2012)
We compute the low-energy variation of the horizon entanglement entropy for matter fields and gravitons in Minkowski space. While the entropy is divergent, the variation under a perturbation of the vacuum state is finite and proportional to the energy flux through the Rindler horizon. Due to the universal coupling of gravitons to the energy-momentum tensor, the variation of the entanglement entropy is universal and equal to the change in area of the event horizon divided by 4 times Newton's constant - independently from the number and type of matter fields. The physical mechanism presented provides an explanation of the microscopic origin of the Bekenstein-Hawking entropy in terms of entanglement entropy.
7 pages
This is a breakthrough because a radical simplification. You can calculate the entanglement entropy, in this case, just from the entanglement entropy of the gravitons alone.
You do not have to put matter fields into the calculation because the gravitons FEEL the matter thoroughly and reflect its entanglements.
Eventually, I suspect, the entropy associated with different regions will be algebraically definable in a C* context, based on correlations between observables. The entropy-area relation will facilitate exploring the geometry in a situation where no manifold is given to start with. This will advance the program of recovering geometric relationships in a C* picture of the world, IMHO. So I think this is an outstanding paper with long-range significance. If someone disagrees with this assessment of 1211.0522, please tell me--I'd be interested in hearing a different opinion.
So later this month, as 29 January approaches, some of us will probably decide to take a look at the November paper to prepare for listening to the online seminar titled:
Entanglement in loop quantum gravity by Eugenio Bianchi.
  • Beyond the Standard Models
