Triangle Inequality and the Triangle Law of Vector Addition
In summary, there are two laws that apply to triangles: the triangle inequality, which states that the sum of any two sides of a triangle must be greater than the third side, and the triangle law of vector addition, which states that the third side of a triangle formed by two vectors will be the sum of those vectors. These laws may seem contradictory, but the third vector's length can be calculated using the law of cosines.
Ryuzaki
46
The triangle inequality states that, the sum of any two sides of a triangle must be greater than the third side of the triangle.
But the triangle law of vector addition states that if we can represent two vectors as the two sides of a triangle in one order ,the third side of the triangle taken in the reverse order will be the sum of the two vectors.
However, the above two laws seem to contradict each other; one states that the third side should be less than the sum of the other two sides, while the other law states that it would be equal (considering the magnitudes of the vectors).
So can anyone tell me what I'm missing here? Thanks.
Mathematics news on Phys.org
Hi Ryuzaki
The third vector is the sum of the two first vectors, but its length is not the sum of the lengths of the vectors.
The length of the third vector can be calculated using the law of cosines.
Thank you, oli4 and mathman. Seems like I had a pretty silly misconception there.
I can provide some clarification on the apparent contradiction between the triangle inequality and the triangle law of vector addition. Both of these laws are valid and serve different purposes in mathematics and physics.
The triangle inequality is a fundamental geometric principle that applies to all triangles, regardless of their orientation or shape. It states that the sum of any two sides of a triangle must always be greater than the third side. This is a necessary condition for a triangle to exist and is based on the properties of Euclidean geometry.
On the other hand, the triangle law of vector addition is a specific application of the triangle inequality in vector mathematics. It states that if we represent two vectors as the two sides of a triangle in a specific order, the third side of the triangle taken in the reverse order will be the sum of the two vectors. This law is based on the properties of vector addition and is applicable in physics and engineering.
It is important to note that the triangle law of vector addition only applies to vectors, which have both magnitude and direction. The triangle inequality, on the other hand, applies to all geometric shapes, including triangles, regardless of whether they represent vectors or not.
In summary, the triangle inequality and the triangle law of vector addition are not contradictory, but rather complementary laws that serve different purposes in mathematics and physics. The triangle inequality is a general geometric principle, while the triangle law of vector addition is a specific application of this principle in vector mathematics.
1. What is the Triangle Inequality Theorem?
The Triangle Inequality Theorem states that the sum of any two sides of a triangle must be greater than the third side. In other words, the shortest distance between two points is a straight line.
2. How is the Triangle Inequality Theorem used in vector addition?
The Triangle Inequality Theorem is used in vector addition to determine whether the addition of two vectors is possible. If the sum of the magnitudes of two vectors is greater than the magnitude of the third vector, then the vectors can be added together.
3. What is the Triangle Law of Vector Addition?
The Triangle Law of Vector Addition states that when two vectors are added, the resultant vector is represented by the third side of a triangle formed by the two original vectors.
4. Can the Triangle Inequality Theorem be applied to any triangle?
Yes, the Triangle Inequality Theorem can be applied to any triangle, regardless of its size or shape. This theorem is a fundamental concept in geometry and is used in various mathematical applications.
5. How does the Triangle Inequality Theorem relate to the Triangle Law of Vector Addition?
The Triangle Inequality Theorem is the basis for the Triangle Law of Vector Addition. This theorem ensures that the Triangle Law of Vector Addition is valid and can be used to determine whether vector addition is possible.
  • General Math
  • Linear and Abstract Algebra
  • General Math
