How do atoms with low energy orbitals posses high energy electrons?
In summary, the electron affinity of nitrogen is positive, so energy must be put in to transfer the electron. The energy of the electron transferred will be the energy of the photon minus the ionization energy, which is a fraction of an eV.
MathewsMD
433
In the case of an atom of Cesium ejecting an electron, it would lose one electron from the 6s orbital. The 6s orbital is very high in energy and similarly so would the electron that is ejected from it, right?
So if there was a Nitrogen atom as well, how would it be possible that the Nitrogen accepts this electron of such high energy when its highest ground state sublevel is 2p. I would assume the electron loses energy in the transfer process but how exactly? The electron affinity in terms of enthalpy change for Nitrogen is positive, so I would assume energy is put in, but how can the energy change from a 6s orbital to 2p actually be calculated to determine if the necessary amount of energy was lost in this process?
Also, is it wrong to assume that an electron ejected from a 6s orbital still has high energy? Or does the energy of the electron change completely once it is out of the atom?
Any comments on where the electron's energy went and how an electron from the 6s orbital in Cesium (or higher from other atoms) can be contained in a Nitrogen atom would be greatly appreciated!
Chemistry news on Phys.org
The ejection of an electron requires the expenditure of energy; a photon above the ionization energy could eject an electron. The energy of the electron that has been ejected will be the energy of the photon minus the ionization energy ... it could be a fraction of an eV.
If you use a GeV photon your ejected electron will be a GeV electron minus noise.
Okay. But doesn't the electron also have energy from being in the 6s orbital, like all electrons? Although some energy is expended to eject the electron from Cesium, how could a Nitrogen atom hold such a high energy electron?
The energy of an electron in an orbital is negative compared to the energy of a free electron.
An outer electron of cesium only has a high energy compared to an inner electron of caesium, but it does not have a high energy compared to an outer electron of nitrogen.
Likes 1 person
If you assume that the electron taken from Cs is "accepted" directly by nitrogen, you also assume this is a reaction with ΔH = 0 - neither exo- nor endothermic. How do you think, is it true?
Also - check what the ionization energy of cesium is and compare it to ionization energy of - say - potassium. Are you still sure 6s electrons have so high energy?
1. How do atoms with low energy orbitals possess high energy electrons?
This phenomenon is known as electron excitation. When an atom absorbs energy, such as through heat or light, its electrons can jump to higher energy levels. This results in the atom having high energy electrons in its low energy orbitals.
2. What causes the electrons in low energy orbitals to gain energy?
The electrons gain energy through absorption of energy from an external source. This can be in the form of heat, light, or electrical energy.
3. Can low energy orbitals have high energy electrons without external energy input?
No, low energy orbitals do not naturally possess high energy electrons. External energy input is required for the electrons to gain energy and move to higher energy levels.
4. How does the energy level of an electron affect its behavior?
The energy level of an electron determines its position and movement within an atom. Higher energy electrons in low energy orbitals can participate in chemical reactions and bonding, while lower energy electrons are less reactive.
5. Why do some atoms have high energy electrons in their low energy orbitals while others do not?
This depends on the specific atom and its electron configuration. Some atoms have a greater number of electrons in their outermost energy level, making them more likely to have high energy electrons in their low energy orbitals. Additionally, the amount of external energy present can also affect the electron configuration.
  • Other Physics Topics
  • Quantum Physics
