Three Dimensional Charge Density in Capacitor Plates
In summary, the charge will reside only on the surface of the plate, so the thickness is more or less immaterial when it comes to calculating the charge density.
Conservation
63
Hello everyone,
I was wondering how one would calculate the three-dimensional charge density (per volume) in a capacitor plate with a given thickness. I know how to calculate the charge density on the surface based on the capacitance and voltage, but how would one calculate the comprehensive charge density that also incorporates the charge distribution in the direction of the thickness?
Thanks.
Well, the charge will reside only on the surface of the plate, so the thickness is more or less immaterial. You can model the plate as a two dimensional plate then. You can then use various computational techniques to calculate the charge distribution due to a known voltage. One method is the Method of Moments and the case of the charge on a plate at uniform voltage is solved in Harrington's text, "Method of Moments." Balanis' "Advanced Engineering Electromagnetics" discusses integral methods. While he does not do the plate problem, one can learn enough to knock out a code in Matlab for example.
Likes 1 person
I see. Thanks for a detailed answer for the calculation process.
However, does the charge truly reside only on the surface? I mean, there are still electrons in regions that are not the surface directly in contact with the dielectric which would be attracted to the opposite plate, causing an uneven electron distribution, right?
Electrostatics is concerned with the steady state solution. So if there was any net electric field on the interior of the conducting plate, then it would simply whisk away the charges as a result. The only way that we reach a steady state is having no net electric field on the interior of a conductor. Or in other words, the voltage difference between any two interior points is zero. For this to be true, then there cannot be any net charge in the interior.
So regardless of what configuration of charge we can think of, when we let them move about in response to each other they will always end up with a net charge only on the surface of conductors.
Now electrodynamics can allow for a net charge density to appear in the interior of imperfect conductors, like real world copper. In this case, we would have to model a capacitor that has a time-varying voltage across it and the charges would permeate into the interior based upon the conductivity of the metal and the frequency of the time-varying fields. But to solve that case we have to use a more complicated set of equations, but we can still use the Method of Moments as the solver.
Hello,
Calculating the three-dimensional charge density in a capacitor plate involves taking into account the distribution of charge not only on the surface, but also within the volume of the plate. This can be done by considering the electric field within the plate and using Gauss's law, which states that the electric flux through a closed surface is equal to the charge enclosed by that surface. By applying this law to a small volume element within the plate, you can determine the charge density at that point.
You can also use the concept of capacitance to calculate the three-dimensional charge density. Capacitance is defined as the ratio of the charge on one plate to the potential difference between the plates. By incorporating the thickness of the plate into this equation, you can determine the charge density per volume.
Another approach is to use the concept of electric potential to calculate the three-dimensional charge density. By considering the potential difference between two points within the plate, you can determine the charge density at that location.
In summary, there are various methods that can be used to calculate the three-dimensional charge density in a capacitor plate. These methods involve considering the electric field, capacitance, and electric potential within the plate. I hope this helps clarify the concept for you. Let me know if you have any further questions.
1. What is three dimensional charge density in capacitor plates?
Three dimensional charge density in capacitor plates refers to the distribution of electric charge across the surface of the capacitor plates in three dimensions. It takes into account the charge density not only on the surface of the plates, but also within the volume between the plates.
2. How is three dimensional charge density calculated in capacitor plates?
Three dimensional charge density in capacitor plates can be calculated by dividing the total charge on the plates by the volume between the plates. This takes into account the charge density on the surface of the plates as well as the charge density within the volume between the plates.
3. What factors affect the three dimensional charge density in capacitor plates?
The three dimensional charge density in capacitor plates is affected by the distance between the plates, the surface area of the plates, and the dielectric material between the plates. These factors can influence the distribution and magnitude of the electric charge on the plates.
4. Why is three dimensional charge density important in capacitor plates?
Understanding the three dimensional charge density in capacitor plates is important for predicting the behavior of capacitors in circuits. It can also help determine the capacitance, or ability to store charge, of the capacitor, which is a crucial factor in many electronic applications.
5. How does three dimensional charge density differ from surface charge density in capacitor plates?
Surface charge density refers to the amount of charge per unit area on the surface of the capacitor plates. Three dimensional charge density takes into account the charge density within the volume between the plates as well. This means that three dimensional charge density is a more comprehensive measure of the charge distribution in capacitor plates.
