Calculating Force for Spark Plug Installation
In summary, to tighten a spark plug with a torque of 45.0 N*m, using the given data of L = 0.300 m and θ = 52.6°, you must exert a force of 246.96 N. However, if θ is 0, the torque would also be 0. To find the correct force, you need to use the component of F that is perpendicular to the displacement, which can be found using sine instead of cosine. The correct force needed to tighten the spark plug in this case would be 1.898102N.
dragon18
You are installing a new spark plug in your car, and the manual specifies that it be tightened to a torque that has a magnitude of 45.0 N*m. Using the data in the figure below (L = 0.300 m and ? = 52.6°), determine the magnitude F of the force that you must exert on the wrench.
T = F * d
Attempt
45 = F * cos 52.6º * 0.300m
F = 246.96 N
What if θ was zero? According to your formula, this would give a torque of Fd (because cos(0) = 1). But, if you look at the picture, if θ = 0, shouldn't the torque be 0 as well? You are just pulling straight out; this shouldn't turn the bolt at all.
Hint: is θ really the angle between the force and the displacement?
If θ=0, then the force would be 150N. θ isn't the angle between the force and displacement, but what am I looking for instead of 52.6°?
Basically, you want the component of F that is PERPENDICULAR to the displacement. Personally, I wouldn't use cosine but sine. Draw a right triangle with theta, F, and d, and find an expression for the component of F pointing away from d.
I figured out that the answer is 1.898102N
F=45F*m/(0.300m*sin(52.6°))
1. What is the magnitude of force on a wrench?
The magnitude of force on a wrench refers to the strength or amount of force that is being applied to the wrench in order to turn or loosen a bolt or nut.
2. How is the magnitude of force on a wrench calculated?
The magnitude of force on a wrench can be calculated by multiplying the length of the wrench by the amount of force being applied to the end of the wrench. This calculation is known as torque.
3. What factors can affect the magnitude of force on a wrench?
The magnitude of force on a wrench can be affected by various factors such as the length of the wrench, the amount of force being applied, the angle at which the force is being applied, and the friction between the wrench and the bolt or nut.
4. Is the magnitude of force the same on all wrenches?
No, the magnitude of force on a wrench can vary depending on the size and type of wrench being used, as well as the amount of force being applied. A longer wrench will typically require less force to achieve the same amount of torque compared to a shorter wrench.
5. Why is it important to consider the magnitude of force on a wrench?
Considering the magnitude of force on a wrench is important because it can affect the effectiveness and efficiency of the task at hand. Applying too much force can damage the wrench or the bolt/nut, while applying too little force may not be enough to loosen or tighten the bolt/nut properly.
  • Precalculus Mathematics Homework Help
