Solving Substitution Process Homework Questions
In summary: Good job!In summary, the antiderivative of 4rsqrt(8-r)dr is (8/5)(8-r)^(5/2) - (64/3)(8-r)^(3/2) + c.
rayray19
1) antiderivative of ((t^2)+2)/((t^3)+6t+3) dt
2) antiderivative of r(sqrt((r^2)+2))dr
help please with these
#2 let u = r^2 + 2
du/dr = 2r
du = 2rdr?? i don't knoww!
[tex]\int\frac{t^2 +2}{t^3 +6t +3}dt[/tex]
[tex]\int r\sqrt{r^2+2}dr[/tex]
correct?
yes, that is correct
For the first one, try partial fractions (probably).
For the second, your substitution seems promising. You will have the integral [tex]\int r u^{1/2}\frac{du}{2r}=\int \frac{1}{2}u^{1/2}du[/tex]
well for both, all you do is a u-substitution
1) u-sub of your denominator
2) u-sub of your radican, which you already did
so let's work 2
[tex]u=r^2 +2[/tex]
[tex]du=2rdr \rightarrow \frac{1}{2}du=rdr[/tex]
Rearranging your integral, do you notice that your derivative shows up in your original integrand? by that happening, you can take it out of your integral.
[tex]\int\sqrt{r^2 +1} rdr[/tex]
[tex]\frac{1}{2}\int\sqrt{u}du[/tex]
for my answer to #2 i got (1/3)((r^2)+2)^(3/2) + cis that correct??
is that correct??
correct, now your first one works out the same way, all you have to do is factor our a common term from the derivative of your u-sub.
i factored out a 3 but now I am lost at finishing it up
i got 3 times the antiderivative of du/u dt.. i don't think that's right though
[tex]u=t^3 +6t +3[/tex]
[tex]du=3(t^2 + 1)dt \rightarrow \frac{1}{3}du=(t^2 +1)dt[/tex]
just replace what you have with your u-sub and derivative of your u-sub.
What you have to do is, divide by that 3 so that it becomes the constant for your substituted Integral.
im sorry I am stuck, what do i do after i find the du=3((t^2) +2)) dt
so is the answer (1/3)((t^2)+2) +c ?
Unfortunately, no. Have you learned about the Integral of Ln? (Natural Log)
yea it becomes 1/x doesn't iit
correct, so when we complete all our substitutions, we end up with:
[tex]\frac{1}{3}\int\frac{1}{u}du[/tex]
so now take the Integral of that and just resubstitute.
i think i have it,, (1/3)ln(t^3 + 6t + 3) ?
yes, but with + C
you can always confirm your answer by taking the derivative, gl!
It helps if you post your working at each stage, instead of simply posting what you get as the answer. This not only helps the person checking your work, but also helps you in that you organise your thoughts into a logical progression through the problem.
thank yo u so muchh, I am working on a problem now
so the u is 8-r
and the du is -1dr right
yes, that's correct
now i got up to 4 times antiderivative of (8-u)sqrt(u)) -du
right?
my answer is...
(8/5)(8-r)^(5/2) - (64/3)(8-r)^(3/2) + ccan any1 tell me if this is correct
my answer is...
It is correct.
What is the substitution process in mathematics?
The substitution process in mathematics involves replacing one or more variables in an equation or expression with known values or other variables. This allows for the evaluation of the equation or expression and finding a solution.
Why is substitution important in solving homework questions?
Substitution is important in solving homework questions because it allows for the simplification of complex equations and expressions, making them easier to solve. It also helps in finding the value of unknown variables, which is crucial in many mathematical problems.
What are the steps for solving substitution process homework questions?
The steps for solving substitution process homework questions are:
  1. Identify the variable to be substituted.
  2. Choose a known value or another variable to replace the identified variable with.
  3. Substitute the chosen value or variable into the equation or expression.
  4. Simplify the equation or expression by combining like terms.
  5. Solve for the remaining variable(s) to find the solution.
What are some tips for solving substitution process homework questions?
Some tips for solving substitution process homework questions include:
  • Always double-check your substitution to ensure accuracy.
  • Choose a known value or variable that will make the equation or expression simpler to solve.
  • Be careful when handling negative signs or fractions during the substitution process.
  • Check your final solution by substituting it back into the original equation or expression.
Can substitution be used in all types of mathematical problems?
Yes, substitution can be used in most types of mathematical problems, including equations, inequalities, and systems of equations. However, there are some situations where substitution may not be the most efficient method for solving a problem, and other methods such as elimination or graphing may be more appropriate.
