Is There Any Difference Between A Stretching or Expanding Universe?
In summary: An expanding space with constant c is equivalent to non-expanding space with decreasing c. (from birds perspective)Of course, all observers would get the same constant c, but they will see that distant galaxies are receding, because it takes more and more time for the light to go from there.
awktrc
I have been reading Cosmology related topics for about eighteen-months. The other day I was reading from the following website: http://wmap.gsfc.nasa.gov/site/faq.html
Under Item 2. is this sentence.
"Astronomers see galaxies moving apart from one another: space in the universe is stretching."
In my eighteen-months of reading Cosmology subjects, this is the first time that I have ever read the word stretching. Every other occurrence, as I recall, used the term expanding.
What is the difference, if any, between a stretching or expanding Universe?
Thank you in advance to those that respond.
Space news on Phys.org
Just different words to imperfectly describe the true behavior (which is only properly described mathematically).
streching, expanding, growing, I would all take to mean the same thing: distances between unconnected objects are growing.
... or light speed (from God's eyes view) is decreasing. As frog observers expect it to be constant, they interpret it as 'distances are growing'
Just different words to imperfectly describe the true behavior (which is only properly described mathematically). (c)
Really? But since cosmic expansion only occurs on large scales, does that mean the speed of light is only slower on large scales? I don't believe that. (sorry, I just can't without more explanation).
Cosmic expansion occurs on ANY scale, but small systems (stars, galaxies, clusters) have already 'adapted' to the expansion. However, even such system are affected by the expansion, because H varies in time, and tidal forces change. System, perfectly adapted now will not be perfectly adapted later. But the effect is very tiny.
AFAIK no one knows how to apply 'space expansion' at a local scale (galaxies, stars, planet orbits, atoms,...
"Cosmic expansion occurs on ANY scale,..." (and everything afterwords) is unknown to me.
"...have already 'adapted' to the expansion..." How is it?
There was a really good article about it...
So Earth is very very very slowly falling on Sun. At the same time, Universe is expanding, making the distance larger. The total effect is 0, so Earth orbit is stable.
You should not worry about expansion. What was recedeing in the past will continue to do so in the future. It is the dark energy that you are talking about.
Equilibrium for any system from electron to a galaxy can not be the same with or without DE.
Again:
"Expansion" etc. = Distances increase, everywhere. Nothing more.
On a local scale, "Distance increases" has a name: velocity.
"adapted to expansion" then means: no velocity.
And that's it. Applying the "expansion"-idea to local physics is at least misleading.
Which does not mean that it is wrong. It just provides a totally wrong intuition, causing people to make errors in their reasoning.
Are you saying the speed of light is decreasing universally? I cannot believe this. How have I graduated in physics specialising in cosmology, without hearing of this interpretation?
I fail to understand how that could be gleaned from what Dmitry67 said.
It is quite obvious.
In the baloon analogy, just use polar coordinates. c is decreasing in such coordinates.
So both interpretations are equivalent. But I prefer mine (where c is decreasing) because it does not have a singularity in case of Big Rip.
Any real singularity is independent of your coordinate system.
hm...
Big Rip - infinite tidal forces, infinitely accelerated inflation... singularity.
But in my coordinate system it just means:
birds-eye 'c' -> 0
So light becomes travel infinitely slow and all objects 'appear' infinitely far away from each other.
Dmitry67 said:
hm...
birds-eye 'c' -> 0
Like I said, any real singularity is independent of coordinates. But I don't quite see how the "big rip" is a singularity anyway, as it's not a point of infinite density. It's only a singularity by way of analogy.
The "big rip" only gives you infinitely accelerated inflation after infinite time anyway.
NO!
Big Rip happens in finite time
http://en.wikipedia.org/wiki/Big_Rip
The Big Rip is a cosmological hypothesis first published in 2003, about the ultimate fate of the universe, in which the matter of the universe, from stars and galaxies to atoms and subatomic particles, are progressively torn apart by the expansion of the universe at a certain time in the future. Theoretically, the scale factor of the universe becomes infinite at a finite time in the future.
Dmitry67 said:
NO!
Hmmm, perhaps, but it's still not the same sort of singularity. Things do go infinite, this is true, but all you're presenting are different coordinates, not anything that fundamentally changes the behavior. It makes sense to use different coordinates to describe different physical situations.
WOW! Thanks for all the responses. So, in summary, stretching and expanding basically amount to the same concept. However, the mathematical model(s) more accurately depict the reality of the Universe's expansion.
Since I am obviously not an expert on this subject, I will assume that Hubble's Law (v = H x D) is one of these mathematical models. Are there others?
Also, as I understand it, based on years of observations, the consensus of the scientific community is that the distance between each (non-gravitationally bound) galaxy in the observable Universe is increasing with time. How exactly does this work? That is, can someone please explain this process in (preferably) non-mathematical language? However, if it is convenient to explain this only in mathematical terms, then please do so. Actually, if there is a website that explains this plainly, I would prefer this option.
My real hang-up with this concept is how do these galaxies move in three-dimensional space as opposed to the balloon analogy of two-dimensional space. What forces (if any) are involved and how does the SPACE/DISTANCE between these galaxies increase? In the balloon analogy, I understand that the stretching of the balloon's surface as it inflates causes the dots (which represent the galaxies) to all move away from each other. How does the Universe accomplish this same task?
That's basically it, but we need to use General Relativity to determine precisely what the relationship between 'v' and 'd' is in that equation.
That's basically what the expansion means. All sorts of analogies have been used to explain this. One that we might consider is a rubber sheet: take a large rubber sheet, and draw lots of dots on it. Each dot represent a galaxy. If you stretch the sheet evenly in each direction, all of those dots will get further away.
This is the same basic idea as the expansion.
As minor caveat, though, let me just stress that the expansion is an average effect on large scales: on smaller scales, overdense systems tend to collapse, so there are, locally, many galaxies moving towards one another.
The only force that acts on such large distances is gravity. The basic picture is that the initial conditions were such that they were all moving away from one another to begin with, and gravity modifies how they move apart with time depending upon the contents of our universe. Early-on, the gravitational effect of the matter and radiation caused the expansion to slow. More recently, the matter and radiation have diluted away so much that another form of energy density seems to have taken over and caused an acceleration of the expansion due to how it interacts with gravity (caveat: it may also be because we don't understand how gravity acts on very large distance scales, this is currently under investigation).
1. What is the difference between a stretching and an expanding universe?
The main difference between a stretching and an expanding universe lies in the underlying cause of the observed increase in the distance between galaxies. In a stretching universe, the space between objects is increasing due to the movement of the objects themselves. In an expanding universe, the space itself is expanding, causing the objects to move further apart.
2. How do we know that the universe is expanding?
Scientists have observed the redshift of light from distant objects, indicating that they are moving away from us. This is known as the Doppler effect, and it is consistent with the expansion of the universe. Additionally, the cosmic microwave background radiation, which is a remnant of the Big Bang, shows a consistent pattern of expansion throughout the observable universe.
3. Does the expansion of the universe affect objects within it?
Yes, the expansion of the universe does have an effect on objects within it. However, these effects are only noticeable on a very large scale. Objects within our own galaxy, for example, are held together by gravity and are not affected by the expansion of the universe. It is only at the largest scales, such as between clusters of galaxies, that the expansion is significant.
4. Is the universe expanding at a constant rate?
No, the expansion of the universe is not constant. In fact, it is currently accelerating. This is believed to be due to the presence of dark energy, a mysterious force that is causing the expansion to accelerate. The rate of expansion is also affected by the amount and distribution of matter in the universe.
5. Can the expansion of the universe ever reverse?
It is currently believed that the expansion of the universe will continue indefinitely, and will not reverse. However, this is still an area of active research and there are some theories that suggest the expansion could eventually slow down and reverse. Ultimately, the fate of the universe is still a topic of ongoing scientific exploration and debate.
  • Cosmology
