CMB SLS one instant or over a period of time
In summary, the Cosmic Microwave Background (CMB) was predicted to have been created when the universe cooled to about 3,000K. While there may have been some variation in the "Surface of Last Scattering" due to different areas of the universe reaching that temperature and decoupling at slightly different times, the anisotropies observed in the CMB are not a result of this. Rather, they are caused by other factors such as the CMB dipole, Sachs-Wolfe effect, Rees-Sciama effect, Sunyaev-Zel'dovich effect, Doppler effects, and Sakharov Oscillations. These anisotropies are only one part in 100,000, with
cbd1
123
My question is regarding when the the CMB was created. I understand that it is predicted to have been "when the universe cooled to about 3,000K". However, might it have been possible that different areas of the universe reached that temperature and decoupled a little earlier than others? This would mean there is some variation in the "Surface of Last Scattering" rather than being smooth.
The idea is that this might describe the anisotropies of the relic radiation. The cooler areas would indicate places that cooled and decoupled further in the past (earlier in the universe's time-line) and that the hotter areas would indicate areas that cooled and decoupled a little later.
Space news on Phys.org
If this were true, then there would be strong anisotropies in the CMB. There are not: it's nearly the same in every direction. The anisotropies that we do see are only one part in 100,000 (well, except for the dipole, which is around one part in 10,000, but then the dipole is likely explained by our movement, not anything intrinsic to the CMB).
Edit: As a slight caveat, it is indeed the case that different parts of the CMB cooled at slightly different times. This isn't the cause of the anisotropies, but is instead as a result of them. Parts that were warmer cooled later, while parts that were cooler cooled earlier. But not by much: these temperature differences were minuscule.
Decoupling isn't an instantaneous process. It's reasonable to expect the SLS to have a finite thickness. I'm not sure on what kind of background you have but it's probably worth checking out http://en.wikipedia.org/wiki/Cosmic..._radiation#Microwave_background_observations" on the CMB and some of the links from there.
In particular check out:
1) CMB Dipole
2) Sachs-Wolfe
3) Rees-Sciama
4) Sunyaev-Zel'Dovich
5) Doppler effects
6) Sakharov Oscillations
That should be a good start for some of the ideas. Things can get pretty involved pretty quickly and you also have to consider that you can have anisotropies generated at the time of the formation of the CMB as well as anisotropies created during the travel time of CMB photons (e.g. Gravitational lensing, foreground contaminations, Sunyaev-Zel'dovich and many more).
So are you saying that the anisotropies are or are not due to different areas cooling at different rates over a period of time?
Cooling at different rates? Definitely not. The laws of physics are the same everywhere, and the contents almost exactly the same. There are only tiny differences in density, with the more dense regions being of very slightly higher temperature, and the less dense regions being slightly lower.
1. What is CMB SLS?
CMB SLS stands for Cosmic Microwave Background (CMB) Satellite Launch System, which is a planned mission by NASA to study the earliest light in the universe and gather data on the Big Bang theory.
2. How does the CMB SLS work?
The CMB SLS will use a satellite to observe the cosmic microwave background radiation, which is the leftover radiation from the Big Bang. The satellite will collect data and transmit it back to Earth for analysis.
3. What is the goal of the CMB SLS mission?
The goal of the CMB SLS mission is to gather data and improve our understanding of the early universe, including the formation of galaxies and the evolution of the universe.
4. Why is the CMB SLS mission important?
The CMB SLS mission is important because it will provide valuable insights into the origins and evolution of the universe. The data collected from the mission can help scientists test and refine theories about the Big Bang and the early universe.
5. When is the launch date for the CMB SLS mission?
The CMB SLS mission is currently in the planning and development stage, with a tentative launch date of 2025. However, this date may change as the project progresses.
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
  • Cosmology
