Unclassifiable statement,, Unexpected data declaration statement
  • Thread starter travers
  • Tags
    Data
In summary, the code provided is written in Fortran and contains various errors, such as missing "precision" in some lines and missing parentheses in others. The variables names used are not easily understandable and the code is written with very little spacing, making it difficult to read.
travers
I am new to fortran. when I define something, I got a lot of errors? can anyone help me ? thanks .
double :: leftsvd(istate,nsvd), svdval(nsvd)
Error: Unclassifiable statement at (1)
Reduced_Model_Runtime.F90:192.2:
double :: leftsvd_gi(ngi,nsvd),leftsvd_x_gi(ngi,nsvd),smean_gi(ngi)
Reduced_Model_Runtime.F90:197.3:
double :: precision smean(istate),snapmatrix(istate,nrsnapshots
Reduced_Model_Runtime.F90:214.15:
real :: XCOR
Error: Unexpected data declaration statement at (1)
Reduced_Model_Runtime.F90:215.22:
REAL :: N(NLOC,NGI)
Reduced_Model_Runtime.F90:216.64:
REAL :: RES(NGI),GRADX(NGI),GRADT(NGI),DIFFGI(NGI),THETA(NGI)
Reduced_Model_Runtime.F90:225.48:
type(vector_field), intent(inout) :: delta_u
Reduced_Model_Runtime.F90:226.48:
type(scalar_field), intent(inout) :: delta_p
Reduced_Model_Runtime.F90:227.47:
type(state_type), dimension(:) :: POD_state
Reduced_Model_Runtime.F90:229.50:
type(petsc_csr_matrix), intent(inout) :: big_m
Reduced_Model_Runtime.F90:230.46:
type(block_csr_matrix), intent(in) :: ct_m
Reduced_Model_Runtime.F90:231.45:
type(vector_field), intent(in) :: mom_rhs
Reduced_Model_Runtime.F90:232.44:
type(scalar_field), intent(in) :: ct_rhs
Reduced_Model_Runtime.F90:234.40:
type(vector_field), pointer :: POD_u
Reduced_Model_Runtime.F90:235.40:
type(scalar_field), pointer :: POD_p
Reduced_Model_Runtime.F90:237.101:
inter :: POD_u_scalar ! new added for petro_galerkin
Reduced_Model_Runtime.F90:240.58:
type(vector_field), dimension(:), allocatable :: u_tmp
Reduced_Model_Runtime.F90:241.29:
type(vector_field) :: u_c
Reduced_Model_Runtime.F90:242.32:
type(scalar_field) :: ct_tmp
Reduced_Model_Runtime.F90:243.38:
type(scalar_field) :: comp1, comp2
Reduced_Model_Runtime.F90:245.39:
type(pod_matrix_type) :: pod_matrix
Reduced_Model_Runtime.F90:246.45:
type(pod_rhs_type) :: pod_rhs,pod_rhs_old
Reduced_Model_Runtime.F90:248.64:
integer :: i, j, d1, d2, u_nodes, p_nodes, POD_num, timestep
Reduced_Model_Runtime.F90:249.48:
real, dimension(:,:), allocatable :: pod_tmp
Reduced_Model_Runtime.F90:251.47:
real, dimension(:), allocatable :: pod_coef
Fatal Error: Error count reached limit of 25.
make: *** [Reduced_Model_Runtime.o] Error 1
My coding:
real tol,rk,rkd,t0
INTEGER NGI,NLOC,TOTELE,NONODS,NONODS_CTY,NITS,mxpoi
PARAMETER(NGI=2,NLOC=2,TOTELE=100,NONODS=NLOC*TOTELE)
PARAMETER(NONODS_CTY=TOTELE+1,NITS=5)
parameter ( mxpoi=nonods )
parameter ( tol=1.0e-6, rk=0.1, rkd = 0.0 )
integer ntimemax
parameter (ntimemax = 299)
integer istate
integer nvar
parameter (nvar=1)
parameter ( istate = mxpoi*nvar)
integer nrsnapshots
parameter (nrsnapshots = 100)
integer SnapNdT
! SnapNdT=ntimemax/(nrsnapshots-1)
parameter (SnapNdT=3)
integer iuseobs,iusemean
parameter (iuseobs=0, iusemean=1)
integer :: nsvd,nsnap,isvd,jsvd
parameter (nsvd = 10)
!double, precision :: leftsvd(istate,nsvd), svdval(nsvd)
!double, precision :: leftsvd_gi(ngi,nsvd),leftsvd_x_gi(ngi,nsvd),smean_gi(ngi)
real :: P_STAR_pod,DIFFGI_pod(NGI)
!double :: precision smean(istate),snapmatrix(istate,nrsnapshots)
real :: psi_podbase(nsvd,NONODS)
real :: AMAT_pod(nsvd,nsvd)
real :: KMAT_pod(nsvd,nsvd),KB_pod(nsvd)
real :: b_pod(nsvd)
real :: psi_pod(nsvd)
real :: psi_time(0:ntimemax,nonods),psi_time_pod(0:ntimemax,nonods)
integer iflagobs(0:ntimemax,mxpoi)
real :: varincr(nonods)
REAL :: AMAT_T(NONODS,NONODS),AMAT2(NONODS,NONODS)
real :: B_AMAT(nonods)
REAL :: COURANT
REAL :: DT
INTEGER :: NTIME
PARAMETER(DT=0.001,NTIME=300)
!REAL :: TOTELE
DX=1.0/TOTEL
real :: XCOR
REAL :: N(NLOC,NGI)
Technology news on Phys.org
In fortran the double precision real type is specified by the two words "double precision".
For example
Code:
double precision :: x,y,z
Somehow I find that really annoying, having two words to represent a single token, but anyway that's how it is.
I delete precision, the errors also exist.
uart isn't saying that you should delete "precision" - he's saying that you need both words, as in double precision.
Code:
double :: leftsvd_gi(ngi,nsvd),leftsvd_x_gi(ngi,nsvd),smean_ gi(ngi)
Note that the line just above is missing a right parenthesis.
The first two lines are missing "precision".
The last line has :: between double and precision.
<rant>Your code is written as if it were to be read only by machines. Almost everything in there is packed very tightly, with almost zero spacing.
Many of the variable names are incomprehensible - I have no idea what they are supposed to represent. Maybe they are meaningful to you, but they aren't to me. Here are some examples: NGI,NLOC,TOTELE,NONODS,NONODS_CTY,NITS,mxpoi.
</rant>
print*, "It seems that there are multiple errors in your code. The "unclassifiable" and "unexpected data declaration" statements indicate that there are syntax errors in your code. These errors may be due to a lack of understanding of the Fortran language or a mistake in typing the code. It would be helpful if you could provide more information about your code and the specific errors you are encountering. Additionally, I suggest seeking assistance from a more experienced Fortran programmer to help you identify and correct these errors. Good luck with your coding journey!"
What is an unclassifiable statement?
An unclassifiable statement is a statement that does not fit into any existing classification or category. It may be considered irrelevant or nonsensical in the context of a particular system or study.
What is an unexpected data declaration statement?
An unexpected data declaration statement is a statement that declares a data type or variable that is not anticipated or allowed in a particular program or code. It may result in errors or unexpected outcomes.
Why do unclassifiable statements and unexpected data declaration statements occur?
Unclassifiable statements and unexpected data declaration statements can occur due to human error, programming mistakes, or changes in the system or environment that were not accounted for in the code. They can also occur when dealing with complex or inconsistent data.
How can unclassifiable statements and unexpected data declaration statements be avoided?
To avoid unclassifiable statements and unexpected data declaration statements, it is important for programmers to thoroughly test their code and anticipate potential errors or issues. Proper coding practices and attention to detail can also help prevent these statements from occurring.
What should be done when encountering an unclassifiable statement or unexpected data declaration statement?
When encountering an unclassifiable statement or unexpected data declaration statement, it is important to carefully review the code and identify the source of the issue. This may involve debugging or adjusting the code to properly handle the unexpected statement.
15K
12K
14K
11K
  • Atomic and Condensed Matter
11K
