Instrument amplifier or just operational amplifier?
In summary, the conversation discusses a project to design an ECG system using a DAQ for signal acquisition and MATLAB for signal processing. There is a debate between using an instrument amplifier or operational amplifier, with the supervisor suggesting the use of instrumentation amplifiers for better isolation and protection. The conversation also brings up the importance of safety certifications and precautions, as well as the need for notch filtering, bandpass limiting, and transient protection for the input lines and amplifiers.
mamod
Hi:
i have a project to design ECG system:
read ECG signal by using (DAQ)data aquestion and the Signal processing(bandpass& notch filter) will be done by using MATLAB program.
I was Intended to use instrument amplifier to obtain I,II or III signals
as this figure:
but my supervisor told me:
amplify each lead separately (LA,RA or LL , and RL as reference) and read it by DAQ
then inside MATLAB we can obtain I,II and III signals, mathematically according to these equations:
I=LA-RA,II=LL-RA and III=LL-LA
so,what's your opinion about this method(of my supervisor), can succeed??
should i use instrument amplifier or just operational amplifier?
I'd use instrumentation amplifiers.
You're probably aware of the lessons learned in late 60's by early medical instrument manufacturers, but i'll mention two of them just in caes...
1. If your machine is connected to a patient who is also connected to one of those defibrillators with the high voltage paddles to get a stopped heart going, it's apt to fry your input amplifiers. Provide protection.
2. Isolate all your input leads, even the "common", from the electronic amplifiers by at least a megohm and preferably ten.
Reason is an electrical fault inside your machine must not reach out and touch the patient.
That's the reason hospitals have separate grounds for instuments and , say, vacuum cleaners. You don't want a defective vacuum cleaner to electrocute a patient through your ECG machine.
Analog Devices was a leader in developing isolated op-amps for the medical instrument industry. Their Peter Zicko was at the forefront back around 1973.
Intronics is another name brand, do some searching on "isolated input amplifier"
end of nagging
old jim
thank you "jim hardy"
Tough call.
Whatever the boss is, he's always the boss. It's generally better to gather evidence than argue.
Time allowing, I'd run both methods in parallel. Then, give a short effort towards the op amp method, record some notes regarding it's behavior, and then, if neccesary use your fall back circuit.
If your manager wants to commercialize this circuit, he'll have to deal with UL601 or equivalent. No repectable hospital or clinic will allow your device in without the precious safety agency sticker. They'll require that the connections have a current limiting impedance and be galvanically isolated from other circuits and of course, power.
For simple experiments, an isolated laptop is your best friend. Operating it from the battery with no external connections (i.e. Ethernet line, USB devices, etc...) allows you to have a power source (via USB) and signal processor. It's best to clear it of all possible connections to ensure that no one is tempted to charge it etc...
Please also review UL544 for this project. As mentioned, you will need to get safety approvals if you want to actually attach this to any person. Even if this is a simulation-only project, you need to research the safety considerations (and immunity issues that Jim brings up), in order to write a complete project report.
In addition to what has already been said, I'd like to suggest that you provide substantial notch filtering, bandpass limiting and transient protection to your input lines and amplifiers. Touch the probe of an oscilloscope to see how high an induced power line voltage could be on the input leads. This could easily drive your amps to either rail preventing amplification of the signal.
1. What is an instrument amplifier or operational amplifier?
An instrument amplifier, also known as an operational amplifier or op-amp, is an electronic device that amplifies an input signal from a sensor or instrument. It is typically used in measurement and control systems to accurately amplify small signals for further processing.
2. How does an instrument amplifier work?
An operational amplifier has a high gain, meaning it can amplify even very small signals. It has two inputs, a non-inverting input (+) and an inverting input (-), and one output. The output of the op-amp is the difference between the two inputs, multiplied by the amplifier's gain. This allows for precise amplification of signals.
3. What are the applications of instrument amplifiers?
Instrument amplifiers are used in a variety of applications, including audio equipment, medical devices, and industrial control systems. They are also commonly used in scientific experiments and research to amplify small signals from sensors or instruments.
4. How do I choose the right instrument amplifier for my application?
When choosing an instrument amplifier, consider factors such as the required gain, bandwidth, input impedance, and power supply requirements. It is also important to select an amplifier with low noise and distortion to ensure accurate signal amplification.
5. Can I build my own instrument amplifier?
Yes, it is possible to build your own instrument amplifier using basic electronic components. However, it is important to have knowledge and experience in electronics to ensure proper functionality and safety. Alternatively, ready-made instrument amplifiers are widely available for purchase.
  • Electrical Engineering
  • Biology and Medical
38K
  • STEM Academic Advising
