Register to reply
Running constants
by ChrisVer
Tags: constants, running
Share this thread:
ChrisVer
#1
May7-14, 05:25 PM
P: 739
Well I am having some difficulty in understanding the running constants... I am not sure if this applies to the Standard Model as well, but I saw that in SUSY recently...
If we take the value of the gaugino masses [itex]m_{\bar{g}},m_{\bar{W}},m_{\bar{B}}[/itex] (by bar I mean Gluino,W-ino and B-ino) to be equal at some energy scale (~MGUT) then we can go to lower energy scales (let's say at TeV) to find their ratio:
[itex]m_{\bar{g}}:m_{\bar{W}}:m_{\bar{B}}≈6:2:1[/itex]
I guess this ratio depends on the model.
My problem is that I don't understand how we can do that, in the case the SuSy breakdown occurs at lower energies than M_GUT... While SuSy is unbroken, the gauginos will have to be massless, right? If the breakdown occurs at around 2TeV let's say, then it's meaningless to speak about their masses...
Phys.Org News Partner Physics news on Phys.org
First in-situ images of void collapse in explosives
The first supercomputer simulations of 'spin?orbit' forces between neutrons and protons in an atomic nucleus
Magnets for fusion energy: A revolutionary manufacturing method developed
Orodruin
#2
May7-14, 05:47 PM
P: 207
The same thing happens with fermion masses in the Standard Model. Typically it is just a matter of sloppy wording and what really is running are the Yukawa couplings (at least above EWSB). I am no SUSY expert, but I suspect there is something similar at work here.
kurros
#3
May8-14, 12:28 AM
P: 355
Quote Quote by ChrisVer View Post
In SUSY models where you have some unification of masses etc. at the GUT scale, then it is at the GUT scale where the SUSY breaking is hypothesised to be happening. So no, that sort of unification doesn't make any sense if the SUSY breaking scale is way below the GUT scale.
ChrisVer
#4
May8-14, 06:42 AM
P: 739
Running constants
Quote Quote by Orodruin View Post
yes, the same question I could ask for the Standard Model as well for above the EWSB...
For example do the W and Z bosons we know become massless? I think they do (at least effectively) because you will have energies above the vev energy...
kurros
#5
May8-14, 08:33 AM
P: 355
Yeah actually I'd like to know the details of this too. Does anyone have a good reference? The whole point of the Higgs mechanism is that the fermions have no mass before symmetry breaking, but how literally can this be "undone" in high energy collisions? What is happening? If we calculate say the running top mass in some renormalisation scheme or other, does it go to zero above the symmetry breaking scale? What will happen experimentally to reflect this?
andrien
#6
May8-14, 12:56 PM
P: 1,020
Be careful here, it is possible to have a supersymmetric theory of scalars and fermions which does not have gauge interactions. In this case, a supersymmetric multiplet necessarily have the same mass because supercharges commute with the momentum operator, so a supercharge acting on a state does not alter the eigenvalue of pμpμ.
The equality of masses is a result of presence of auxiliary field which has no kinetic term and eliminating it by EOM yields the constraints on fermion boson masses and coupling constant.
kurros
#7
May11-14, 11:07 PM
P: 355
I can't say that I understand what your point is.
andrien
#8
May12-14, 02:46 AM
P: 1,020
Quote Quote by andrien View Post
It is meaningful to talk about masses of particles in a supersymmetric theory even when the SUSY breaking has not taken place if you don't have requirement of gauge invariance.
kurros
#9
May12-14, 05:10 PM
P: 355
Ahh I see. Interesting.
Register to reply
Related Discussions
Equilibrium constants Ka, Kc, Kx, Kp and rate constants in reversible reactions Materials & Chemical Engineering 7
Are undefined constants valid in trig equations when other constants present? General Math 3
Rate Constants From Equilibrium Constants Biology, Chemistry & Other Homework 6
Running on Ice Introductory Physics Homework 1
Running CC Cosmology 1
