Ladder Question - Force of friction required to prevent ladder from slipping
In summary, The problem involves a 15kg ladder resting on the floor and leaning against a vertical wall at a 25 degree angle. The only force acting on the ladder is gravity, and the minimum amount of friction needed between the ladder and the floor to prevent it from slipping is 34 N. The formula to solve this problem is Ff = 1/2mgtan@, where @ = 25 degrees. The forces involved must sum to zero and the center for computing total torque can be placed at the point of contact with the floor.
avsj
A uniform 15kg ladder whose length is 5.0 m stands on the floor and leans against a vertical wall, making an angle of 25 degrees with the vertical. Assuming that the friction between the ladder and the wall is negligble, what is the minimum amount of friction between the ladder and the floor that will keep the ladder from slipping?
Torque = Fdistance
Fg = mg
And possibly : Ff= 1/2mgtan(x)
also can Fg = 1/2mg because we're delaing with torques? if so why?
I tried making force vectors perpendicular to (torque) and straight down (gravity) and finding horizontal components (bottom of triangle...so friction?) but could not arrive at the correct answer which is 34 N but would really really appreciate it if someone could help me understand this.
Thanks a lot
If you have arrived at a wrong answer it would be really useful for you to post the wrong solution. What are the forces you've determined and how did you combine them to get the wrong answer? The more details you show the more people will jump in and point out errors. As it is, you are not giving us much to go on.
Since you're dealing with torque, you're probably also dealing with rotational motion. Its best then to plot out a radius and center. Since the wall is frictionless with the ladder, gravity is pulling it down and so it is up to the friction on the floor to prevent it from moving. Now, since the ladder is not moving because the friction on the floor is preventing it from doing that, the point in which the ladder touches the floor could be considered constant (not moving), so you can call it the center and the ladder the radius. Now apply what you know about torque.
Fg= 15 x 9.8 = 147 (straight down)
F torque (perpendicular to the ladder) = 147/sin(25)= 346.8... or is it 2.5 x 15 x 9.8 = 367.5?
solving the horizontal of this vertical line (fg) and the hypotenuse (torque) to get 314...
This is in the 'brain busters' section of my book which often asks questions for which we haven't learned something yet, but I believe the next question which is of the same format gives the formula:
Ff = 1/2mgtan@
If we plug in with @=25, m=15 and g=9.8, we get the correct answer of 34. But i don't see where this equation comes from.
Any ideas?
Ff=1/2mgtan@ is the formula for the solution to this particular problem - not a general formula. So figuring out where it comes from is the same as figuring out the problem. You have four forces to deal with gravitational force, normal force and frictional force from the floor and normal force from the wall. All four of those must sum to zero since the ladder is not accelerating. Once you've ensured they sum to zero then you can place the center for computing total torque ANYWHERE. Where ever is convenient. Then set the sum of all of the torques generated by each force equal zero. It is handy to put it at the point of contact with the floor as Gear300 suggests, since then two of the forces have zero torque.
1. How do you calculate the force of friction required to prevent a ladder from slipping?
To calculate the force of friction required to prevent a ladder from slipping, you can use the equation Ff = µN, where Ff is the force of friction, µ is the coefficient of friction, and N is the normal force. The normal force can be calculated by multiplying the mass of the ladder by the gravitational acceleration (9.8 m/s²) and the sine of the angle of inclination of the ladder.
2. What is the coefficient of friction?
The coefficient of friction is a dimensionless constant that represents the amount of friction between two surfaces in contact with each other. It is dependent on the materials in contact and the roughness of the surfaces.
3. How does the angle of inclination affect the force of friction required to prevent the ladder from slipping?
The force of friction required to prevent a ladder from slipping increases as the angle of inclination increases. This is because as the angle increases, the normal force also increases, which in turn increases the force of friction needed to counteract it.
4. What factors can affect the force of friction required to prevent a ladder from slipping?
The force of friction required to prevent a ladder from slipping can be affected by several factors, including the weight of the ladder, the coefficient of friction between the ladder and the ground, the roughness of the ground surface, and the angle of inclination of the ladder.
5. Can the force of friction alone prevent a ladder from slipping?
No, the force of friction alone may not be enough to prevent a ladder from slipping. Other factors such as the weight distribution of the person on the ladder, the stability of the ladder, and the condition of the ground surface also play a role in preventing a ladder from slipping.
14K
