Force between an Infinitely Long Wire and a Square Loop
In summary, the problem involves a square loop of wire with side length a carrying a current I_1 and located a distance d from an infinite wire carrying a current I_2. The magnitude of the net force on the loop can be expressed as F = (a*u_0*I_1*I_2)/(2*pi*d) + (a*u_0*I_1*I_2)/(2*pi*d) and the direction of the forces depends on the direction of the current in relation to the infinite wire. The distance between the loop and the infinite wire affects the magnetic field and thus the force on the loop.
Badger
28
Hello all, I thought I was starting to understand these magnetic field problems but this one is driving me crazy. I've inputted a good 6 or 7 answers and they all failed. Help would be awesome as always.
A square loop of wire with side length a carries a current I_1. The center of the loop is located a distance d from an infinite wire carrying a current I_2. The infinite wire and loop are in the same plane; two sides of the square loop are parallel to the wire and two are perpendicular as shown.
What is the magnitude, F, of the net force on the loop?
Express the force in terms of [tex]I_1, I_2, a, d, mu_0[/tex]
None are given, but my guess is this guy will be involved:
F_parallel_wire = I_x L B_y ; x is one wire, y is another wire
F_p_w = (u_0 * L * I_1 * I_2) / 2(pi)d
Ampere's Law as well:
circle integeral of B * ds = BL = B(2(pi)d = u_0 * I_through
Most recent answer.
just to make this easier, mu_0 = u and pi = p
F = I L B
F = I_1 * [(d+.5a) + (d-.5a)] * [(u * I_2)/(2 * p * a)]
not right.
So anyway, there's 4 sides to the loop so there should be 4 forces.
F_top_loop is equal and opposite to F_bottom_loop so those can be tossed aside.
F_left has the same direction of current as the wire so they attract. Negative sign.
F_right has the opposite direction of current as wire so they repel. Positive sign.
F_left than F_right to the wire so it'll have a stronger force and the direction will go left.
The distance between the closer ones is d - .5a and the distance between the distant ones is d + .5a
B = u_0(I_2)/(2(pi)d)
since the length of the wire isn't provided, I figure d will be the amount in parallel with the part of the loop, in this case a. d = a.
First off... what is the magnetic field due to the I2 current at the left segment of the loop... u0*2pi/distance... what is the distance between the I2 current and the left segment of the loop?
The force acting on the left segment of the loop is I1*L*B. What is L here?
The distance between the i2 current and the left current is (d-(a/2)). (d+(a/2)) for the right current.
I thought L was 'a,' the amount of wire running directly parallel of of l_loop. But that didn't work either.
yes, so B = u0*I2/[2pi(d-0.5a)]
so the force on the left segment is:
-I1*distance*B =
-I1*a*u0*I2/[2pi(d-0.5a)]
same way the force on the right segment is:
I1*a*u0*I2/[2pi(d+0.5a)]
so add these 2 forces.
is this what you did? the question asks for the magnitude... so at the end after getting the net force, leave of the minus sign...
Thanks you helped a lot
But wait if you add those two forces you would end up with zero... or are you suppoed to add the abs of the two values?
Sorry I'm kind of confused.
Note that one of the forces has (d-0.5a) in the denominator while the other has (d+0.5a) due to the different distance from I2, therefore having a different magnetic field.
1. What is the force between an infinitely long wire and a square loop?
The force between an infinitely long wire and a square loop is a type of electromagnetic force known as magnetic force. It arises due to the interaction between the magnetic fields produced by the wire and the loop.
2. How is the force calculated?
The force can be calculated using the formula F = I * L * B, where F is the force, I is the current in the wire, L is the length of the wire, and B is the magnetic field strength.
3. What factors affect the force between the wire and the loop?
The force is affected by the current in the wire, the distance between the wire and the loop, and the orientation of the loop with respect to the wire. It also depends on the strength and direction of the magnetic field.
4. Can the force be attractive or repulsive?
The force between the wire and the loop can be both attractive and repulsive, depending on the direction of the current and the orientation of the loop. If the current is flowing in the same direction, the force is attractive, and if the current is flowing in opposite directions, the force is repulsive.
5. Is this force significant in real-world applications?
Yes, the force between an infinitely long wire and a square loop has many real-world applications. It is used in motors, generators, and other electromechanical devices. It is also used in magnetic levitation and magnetic braking systems.
