Please HELP Don't Understand Simple Concept on Riemann Sums
In summary, Riemann Sums involve dividing the interval of a function into smaller and smaller subintervals, which allows for a more accurate approximation of the area under the curve. As the norm of the partition approaches 0, the number of subintervals must approach infinity in order to cover the entire domain. This concept can be illustrated through the function f(x) = x^2 on the interval [0, 1]. As the number of intervals increases, the Riemann Sum converges to the actual area under the curve, which in this case is 1/3.
BuBbLeS01
602
Please HELP...Don't Understand Simple Concept on Riemann Sums
Can someone please explain this to me...
The number of subintervals in a partition approaches infinity as the norm of the partition approaches 0. That is, ||Triangle|| approaches 0 implies that n approaches infinity.
I thought the the norm (||Triangle||) was just the largest subinterval of a partition, so how does it approach 0??
That is because we make the intervals smaller and smaller (going to zero), which means we have to make the number of intervals go to infinity to cover the entire domain (that is, ||Triangle|| * #{Triangles} = constant). Let me give an example.
Suppose we have a function, f(x) = x^2 on the interval [0, 1] and we want to integrate it. At first, we approximate it by a square of width 1 and height f(1) = 1, which gives 1. This is of course very rough, so we divide the square into two. One rectangle goes from 0 to 1/2 with height f(1/2) = 1/4, and the other one from 1/2 to 1 with height 1. This gives for the area (1/2) * (1/4) + (1/2) * 1 = 1/8 + 1/2 = 5/8.
Now divide it into four parts, all rectangles with width 1/4 and as height the value of the function in the rightmost point of each interval, as in this image. The are will become something like
[tex]\sum_{n = 1}^N \frac{1}{N} \times f(n/N),[/tex]
where the first term is the width of the rectangle and the second term is the height (draw a picture for yourself, I can't do it here).
Now we make N larger and larger, dividing [0, 1] up into more and more intervals. The rectangles get smaller and smaller. The idea is of course that the sum converges to [tex]\int_0^1 x^2 \, dx[/tex].
You can calculate for yourself, that you get
[tex]\frac{1}{N^3} \sum_{n = 1}^N n^2 = \frac{\frac16 N (N + 1) (2 N + 1)}{N^3}[/tex]
which converges to 2/6 = 1/3 as N goes to infinity, which is indeed the surface under the curve.
I hope that made things clearer, even without pictures. Maybe this will help you visualize it.
1. What is a Riemann Sum?
A Riemann Sum is a method for approximating the area under a curve by dividing the region into smaller rectangles and finding the sum of their areas.
2. Why is understanding Riemann Sums important?
Riemann Sums are an essential concept in calculus and are used to find the exact area under a curve, which is crucial in many real-world applications such as physics, economics, and engineering.
3. How do you calculate a Riemann Sum?
To calculate a Riemann Sum, you need to divide the region under the curve into smaller rectangles, find the area of each rectangle, and then add the areas together. The more rectangles you use, the more accurate the approximation will be.
4. What is the difference between a left, right, and midpoint Riemann Sum?
A left Riemann Sum uses the left endpoint of each rectangle to find the height, a right Riemann Sum uses the right endpoint, and a midpoint Riemann Sum uses the midpoint of each rectangle. The choice of endpoints can affect the accuracy of the approximation.
5. Can you use Riemann Sums for any curve?
Riemann Sums can be used for any continuous curve, as long as you can find the area of the rectangles under the curve. However, as the curve becomes more complex, the calculation of the Riemann Sum becomes more challenging.
