If ever auomobile engineering goona change its technology
In summary, the pressure of the piston in the suction stroke should be around 20 inches of vacuum. Increasing this pressure could provide some benefits, but it can also cause harmful pumping losses. This vacuum is created by the restricted air flow caused by partially closed butterfly valves. Turbocharged and supercharged engines have a constant pressure in the manifold, eliminating the vacuum. Diesel engines do not experience vacuum at all. It is unclear what specific technology is being referred to and why it would need to be changed.
prashan
whats the pressure of piston in suction stroke...and if we increase it could we get more benifit
If you mean the vacuum value, then this should be around 20 inches and it's harmful actually and is referred to as pumping losses
nevertheless, there are some auxiliary components that utilize some of this vacuum, but this vacuum could be generated with an external device (e.g pump) therefor eliminating the harmful effects.
the vacuum inside the engine results from the restricted air flow by the butterfly that is partially closed
In a turbocharged/ supercharged engine there will be a constant pressure through the manifold which eliminates the vacuum from it altogether, also note that diesel engines don't experience vacuum at all
However, what "technology" excatly do you refer to and why should it be changed ?
1. What new technologies are being developed for automobiles?
There are several new technologies being developed for automobiles, including electric and autonomous vehicles, as well as advanced driver assistance systems and alternative fuel sources.
2. How will these new technologies impact the automotive industry?
The introduction of new technologies in the automotive industry is expected to have a significant impact, with potential benefits such as increased safety, reduced emissions, and improved efficiency. However, it may also bring about changes in the production process and job roles.
3. Will traditional gasoline-powered vehicles become obsolete?
It is unlikely that traditional gasoline-powered vehicles will become completely obsolete in the near future. However, there is a growing shift towards alternative fuel sources and electric vehicles, which may eventually replace gasoline-powered vehicles.
4. How will the maintenance and repair of vehicles change with new technologies?
The maintenance and repair of vehicles is expected to become more complex with the introduction of new technologies. Traditional mechanics may need to acquire new skills and knowledge to keep up with the changing technology, and specialized technicians may be needed for electric and autonomous vehicles.
5. What are the potential challenges and barriers to implementing new technologies in automobiles?
There are several challenges and barriers that need to be addressed before new technologies can be fully implemented in automobiles. These include cost, infrastructure, regulations, and consumer acceptance. Additionally, there may be technical challenges in integrating different technologies and ensuring their safety and reliability.
  • Mechanical Engineering
18K
