Electrochemical cells: Is gibbs free energy dependent upon concentration?
In summary: How's the view from up there on your high horse? You've only just reiterated what I already said in my second paragraph.
Topher925
1,566
Is the gibbs free energy of some reaction in an electrochemical cell dependent upon reactant concentration? The Nernst equation clearly states that open circuit potential is dependent upon concentration, and basic thermodynamics states that open circuit potential is directly proportional to gibbs free energy, so my intuition says yes. However, some sources (not the most credible) I have found say no. My electrochem text doesn't seem to give a definitive answer.
Approaching the question from another angle, I would think that entropy would be higher with a system with a lower concentration of reactants so given a constant temperature the gibbs free energy should be less via [tex]\Delta[/tex]G = [tex]\Delta[/tex]H - T[tex]\Delta[/tex]S.
Chemistry news on Phys.org
You need to go back to the fundamentals. Entropy tends to increase unless energy is expended to reduce it within a closed system. Therefore, the more concentrated a solution is (be it solid liquid or gas) the less entropy it has. COncentrating and purifying takes enormous energy (heat, financial, & human). Think of it this way - a single crystal silicon, sapphire or diamond has less entropy than a multicrystalline form of the same material. It takes more effort to process these from impure natural materials states into single crystalline form than to make them into multicrystalline form. As they weather, age, or wear in service their entropy is increasing as the 2nd law of thermo holds true.
Please reorient yourself to see the forest through the trees. Take time to review and reflect on the fundamentals. Ask for help. If you are indeed truly overwhelmed, then perhaps you should orient your studies elsewhere. Only you know the answer to that...
looking at this another way. If as you mention delta T = 0 then delta H = 0. Therefore, delta G = (-1)* T * delta S, subsequently if concentration increases delta S is negative. Negative times negative is positive therefore delta G is positive! I hope that simplifies the concept and brings clarity for you. :)
I didn't mention this.
Maybe the 'no' comes from a confusion with 'standard potentials' and 'standard free energy', something like that?
Your intuition is right. E.g. eliminating complicating factors of different materials, imagine a 'concentration cell', so same electrode material both sides, same ions but 2 different concentrations. If the concentrations on both sides are equal there will be no current nor potential, so that answers you question, it must depend on concentration. For an electric current to flow is a way towards equalising the concentrations. So that will happen unless stopped by an opposing potential. Magnitude RT ln (c1/c2). (Ignoring junction potentials.) You worry about the sign! :biggrin: (However in any given setup this will be clear, so this is just about conventions.)
Same damned RT ln c that you get in every damned chemical thermodynamic thing.
I would not completely agree that anyone whose grasp of thermodynamics is shaky, unconfident, unstable should get out of the field because that would be a lot of people, also in any other field at all nearby they will still need the thermodynamics.
epenguin said:
Maybe the 'no' comes from a confusion...
THANK YOU! I knew that I wasn't crazy, even though some fellow colleges and some people of "academic authority" said otherwise. I really needed a sanity check.
I thought it would be a well understood concept given the popular equation RTln(K) = [tex]\Delta[/tex]G, but when everyone tells you "no" you start to question your intuition. That darn equation shows up in all of my electrochem, combustion, and stat thermo books.
1. What is an electrochemical cell?
An electrochemical cell is a device that converts chemical energy into electrical energy by driving an electric current through a chemical reaction. It consists of two electrodes (an anode and a cathode) connected by an electrolyte solution.
2. How does an electrochemical cell work?
An electrochemical cell works by utilizing the chemical reactions between the electrodes and the electrolyte solution to generate an electric current. The anode undergoes oxidation, releasing electrons, while the cathode undergoes reduction, accepting electrons. This flow of electrons generates an electric current.
3. What is the role of concentration in an electrochemical cell?
Concentration plays a crucial role in an electrochemical cell as it affects the Gibbs free energy of the reaction. The concentration of reactants and products determine the driving force of the reaction, and thus, the amount of energy that can be converted into electrical energy.
4. Is Gibbs free energy dependent upon concentration in electrochemical cells?
Yes, the Gibbs free energy is dependent upon concentration in electrochemical cells. The Gibbs free energy is a measure of the energy available to do work, and it is affected by the concentration of reactants and products in the cell. Higher concentrations lead to a larger change in Gibbs free energy, resulting in a stronger driving force for the reaction.
5. How does changing the concentration affect the performance of an electrochemical cell?
Changing the concentration can significantly impact the performance of an electrochemical cell. Increasing the concentration of reactants can increase the rate of the reaction, resulting in a higher current output. Conversely, decreasing the concentration can slow down the reaction and decrease the current output. Therefore, maintaining the right concentration is essential for optimal performance of an electrochemical cell.
  • Chemistry
  • Biology and Chemistry Homework Help
