Find Parametric Equations for Line Parallel to Plane in Space
In summary: Let me know if you have any further questions or if you would like me to clarify anything. Good luck with your studies!In summary, the problem requires finding a line parallel to a given plane and perpendicular to a given line. This can be achieved by finding the direction vector for the parallel line, choosing a point on the given plane, and using the point and direction vector to write the parametric equations for the line. The final equations can be obtained by determining the values of b and c through the dot product with the direction vector of the given line.
michaelwiggin
Find a set of parametric equations for the line passing through the point (1, 0, 1) that is parallel to the plane given by x + y + z = 5, and perpendicular to the line
x = −2 + t, y = 1 + t, z = 2 − t.
The section deals with distances betweens points, lines, and planes in space, so perhaps:
D (distance between a point and a line in space) = ||PQ x u||/||u||, wherein u is the direction vector for the line, and P is a point on the line (so PQ is a vector between P and the Q not on the line).
D (distance between a plane and a point in space) = |PQ dot n|/||n||, wherein n is a vector normal to the plane, and P is a point on the plane, and Q is the point in space.
Well, this problem is number 128 in the textbook section... its the last problem, which in Larson's Calculus (this is the first unit in my MV calc class, btw) usually means that it requires a lot more visualization and logic than the prior ones. So I don't want to look like I didn't try, but all I really have to show for myself is some brainstorming.. I haven't been able to put pen to paper meaningfully. I know that I could use a line parallel to the given line, but I can't figure out how to find that given the perpendicular line provided. If the given plane was perpendicular instead of parallel, it would be easy to find a vector normal to it (which would be parallel to the line I'm trying to find) and work from there. I'm just having a big brain fart, and I don't have time today to grapple with this for an hour like I usually do :\ any tips or suggestions would be very very very appreciated! :) thanks!
-MichaelEdit: P.S., in the equations, |...| is absolute value, and ||...|| is magnitude of the vector.
Dear Michael,
Thank you for your post. This is an interesting problem that requires a combination of visualization and logic. Let's break it down step by step.
First, we need to find the direction vector for the line parallel to the given plane. Since the plane is defined by the equation x + y + z = 5, we can use the coefficients of x, y, and z as the components of our direction vector. So, the direction vector would be u = (1, 1, 1).
Next, we need to find a point that lies on the line we are trying to find. Since the line is parallel to the given plane, we can choose any point on the plane and use it as a point on our line. Let's choose the point (1, 0, 0) since it satisfies the equation x + y + z = 5.
Now, we can use the point and direction vector to write the parametric equations for the line. The parametric equations for a line are x = x0 + at, y = y0 + bt, and z = z0 + ct, where (x0, y0, z0) is a point on the line and (a, b, c) is the direction vector. Plugging in our point and direction vector, we get the following parametric equations for our line: x = 1 + t, y = bt, z = ct.
The only thing left to determine is the value of b and c. We know that our line needs to be perpendicular to the given line x = −2 + t, y = 1 + t, z = 2 − t. This means that the direction vector of our line needs to be perpendicular to the direction vector of the given line. Using the dot product, we can set up the following equation: (1, b, c) ⋅ (-1, 1, -1) = 0. Solving this equation, we get b = -1 and c = 1.
Therefore, the final parametric equations for the line passing through the point (1, 0, 0) that is parallel to the plane x + y + z = 5 and perpendicular to the line x = −2 + t, y = 1 + t, z = 2 − t are: x = 1 + t, y = -t, z = t.
I
What are parametric equations?
Parametric equations are a way of representing mathematical functions using parameters or variables. They are often used to describe the position of a point or a set of points in space or a curve in a 3-dimensional plane.
What does it mean for a line to be parallel to a plane in space?
A line is parallel to a plane in space if it never intersects the plane, meaning that it lies in the same direction as the plane's normal vector. This means that the line will have the same slope as the plane's normal vector and will never cross the plane.
How do I find the parametric equations for a line parallel to a plane in space?
To find the parametric equations for a line parallel to a plane in space, you will first need to determine the normal vector of the plane. Then, choose a point on the line and use the normal vector to calculate the direction of the line. Finally, use this information to write the parametric equations for the line.
Can there be more than one line parallel to a given plane in space?
Yes, there can be an infinite number of lines that are parallel to a given plane in space. This is because there are an infinite number of points that can be used to determine the direction of the line, as long as the line's slope matches that of the plane's normal vector.
Why are parametric equations useful for representing lines parallel to planes in space?
Parametric equations allow us to easily describe the position of points or objects in space using variables, making it easier to manipulate and solve equations involving these points or objects. They are also helpful in visualizing and graphing lines and curves in 3-dimensional space.
