2 identical circuits cascaded/laplace transform and impulse response
In summary, the problem involves cascading two circuits without any loading effect, resulting in a transfer function for the ideal case. To determine the impulse response of each circuit alone, the transfer function is H(s)=+-(2/s+1) and h(t)=+-2e^-t. To determine the output of the second circuit, the Laplace transform of the output is (4/(s*(s+1)^2) and partial fractions are used to find the inverse Laplace transform. The concept of loading effect is explained, and for this problem, it is ignored. The output of the cascaded circuits is evaluated in response to a unit step at the input of the first, with the overall transfer function being Vo(s)=
gethelpelectr
Two identical circuits are cascaded, without the second circuit having any loading effect on the first circuit. If the laplace transform of the impulse response of the cascade is 4/(s+1)^2. a)determine the impulse response of each circuit alone as a function of time.
b)if a signal u(t) is applied to the input of the first circuit, determine the output of the second circuit as a function of time
a) the impulse response of each circuit is either H(s)=+-(2/s+1) so h(t)=+-2e^-t
b)the laplace transform of the output is (4/(s*(s+1)^2) then do partial fractions and u can easily make inverse laplace and get the answer
These are the soulutions to the problem, however I don't get them. What do they mean by the second circuit does not have any loading effect on the first? And why did they multiply laplace of u(t) with laplace of the cascade to get the laplace of the input? I'm not really understanding the concepts.
An individual circuit has an input impedance and an output impedance. When you analyze such a circuit in isolation the assumed source driving its input has zero internal impedance and the circuit's output is an open circuit (infinite impedance). So the resulting transfer function is for the ideal case.
When you cascade two circuits, connecting the output of the first to the input of the next, the first circuit now "sees" the input impedance of the second as a load, while the second circuit "sees" an imperfect source with an impedance. These changed conditions will alter the responses of both circuits.
In practice when designing stages to be cascaded, one generally arranges things so that the input impedance of succeeding stages is much higher than the output impedance of the preceding stages (usually by a factor of 10 or so), so that they are effectively isolating the effects of one from the other and the individual transfer functions are not significantly perturbed.
For this problem you are told to ignore this loading effect, allowing the two transfer functions to stand unaltered.
As for your second question, the problem asks you to evaluate the output of the cascaded circuits in response to a unit step at the input of the first. The overall transfer function is:
##\frac{Vo(s)}{Vi(s)} = H(s)##
so that
##Vo(s) = Vi(s)H(s)##
and Vi(s) is the Laplace Transform of a unit step, which is 1/s.
You have really helped thanks a lot
1. What is the purpose of cascading two identical circuits?
Cascading two identical circuits allows for the combination of their individual transfer functions, resulting in a more complex overall transfer function. This can be useful in designing more complex systems or in achieving specific frequency responses.
2. How do I calculate the overall transfer function for two cascaded circuits?
The overall transfer function can be found by multiplying the individual transfer functions of the two circuits. This can be done using algebraic manipulation or by using the Laplace transform.
3. How does the Laplace transform help with analyzing cascaded circuits?
The Laplace transform allows for the conversion of differential equations into algebraic equations, making it easier to analyze and manipulate the transfer function of cascaded circuits. It also allows for the use of complex numbers, making calculations more efficient.
4. What is the impulse response of a cascaded circuit?
The impulse response of a cascaded circuit is the output response when an impulse input is applied to the circuit. It is a representation of the circuit's behavior and can be used to determine its stability and other characteristics.
5. Can the impulse response of a cascaded circuit be used to determine its frequency response?
Yes, the impulse response can be used to determine the frequency response of a cascaded circuit. By taking the Fourier transform of the impulse response, the frequency response can be obtained. This allows for the analysis of the circuit's behavior at different frequencies.
