Acceleration as a function of velocity - HW problem help
In summary, the particle's velocity decreases as it moves further away from its origin. It reaches a stop at distance s=10m after traveling 10m.
lonsalot
The acceleration of a particle is defined by the relation a = -0.05v^2, where a is expresssed in m/s^2 and v in m/s. The particle starts at s=0 m with a velocity of 5 m/s. Determine (a) the velocity v of the particle after it travels 10m, (b) the distance s the particle will travel before its velocity drops to 2 m/s, (c) the distance s the particle will travel before it comes to rest.
a = v (dv/ds)
http://answerboard.cramster.com/Answer-Board/Image/cramster-equation-20081241357166333677983620400001528.gif
I don't think this is right because when I integrated the right side, it ends up being undefined?
not sure if what I'm thinking is correct but its an idea:
a= dv/dt so we know dv/dt = -.05v^2. We can integrate that to get the velocity function.
once we have the velocity function we can integrate again since v(t) = ds/dt. we have initial conditions. its just an idea.
lonsalot said:
...I don't think this is right because when I integrated the right side, it ends up being undefined?
No it isn't!
[tex]\alpha=-0.05\,v^2 \Rightarrow v\,\frac{d\,v}{d\,s}=-0.05\, v^2\Rightarrow \int_{v_0}^v\frac{d\,v}{v}=-\int_o^s 0.05\,d\,s\Rightarrow \ln v\Big|_{v_0}^v=-0.05\,s\Rightarrow v=v_o\,e^{-0.05\,s}[/tex]
Rainbow Child said:
No it isn't!
How can you just cancel "v" on both sides in second step , where it can take a value zero...
Just to set the record straight on Rainbow child's answer:
No it isn't!
LaTeX Code: \\alpha=-0.05\\,v^2 \\Rightarrow v\\,\\frac{d\\,v}{d\\,s}=-0.05\\, v^2\\Rightarrow \\int_{v_0}^v\\frac{d\\,v}{v}=-\\int_o^s 0.05\\,d\\,s\\Rightarrow \\ln v\\Big|_{v_0}^v=-0.05\\,s\\Rightarrow v=v_o\\,e^{-0.05\\,s}
This slightly wrong, it should be a == d(0.5v2)/ds not d(v2)/ds.
Hi.. just to go one step further, would the distance (with respect to time) equation be :-
[tex]\int{{{v}{}_{0}\over{e^{0.05\,t}}}}\,dt = -{{20\,v{}_{0}}\over{e^{{{t}\over{20}}}\,\log e}}[/tex]
Easy, you just say that the step was valid for all non-zero values of v.
[tex]a=v\frac{dv}{dx}=-kv^2[/tex] (In this case, k=0.05)
From this step to the next, you have two options. Either v is always 0, in which case you have a solution for v, and you are not allowed to divide by v. Or v is different from 0, and you are allowed to divide by it.
suchara, the velocity as a function of time is not what you posted. Note that you used the expression for the velocity as a function of distance and replaced the x with t (A mistake).
[tex]v=\frac{v_0}{1+kv_0 t}[/tex]
1. What is acceleration as a function of velocity?
Acceleration as a function of velocity is a mathematical relationship that describes how an object's velocity changes over time. It is represented by the equation a = dv/dt, where a is acceleration, v is velocity, and t is time.
2. How is acceleration related to velocity?
Acceleration is the rate of change of velocity over time. In other words, it is the measure of how an object's velocity changes in a given time period.
3. How do you calculate acceleration from velocity?
To calculate acceleration from velocity, you can use the equation a = (v2 - v1)/t, where v2 is the final velocity, v1 is the initial velocity, and t is the time interval.
4. What is the unit of measurement for acceleration as a function of velocity?
The unit of measurement for acceleration as a function of velocity is typically meters per second squared (m/s^2) in the SI system.
5. How does acceleration affect an object's motion?
Acceleration affects an object's motion by changing its velocity. If an object experiences a positive acceleration, its velocity will increase over time. On the other hand, if an object experiences a negative acceleration, its velocity will decrease over time.
