New Reply
constant velocity joints vs. universal joint.
Share Thread Thread Tools
Nov15-12, 11:23 AM   #1
i have to design an actuation system which will change the angle with which the power is transmitted through a motor,the range of angle is about,--35 to +35,w.r.t to the vertical,what should i use,a u joint or a velocity joint?there is a predefined load on the shaft(bending + torsional),what should i use?
i have on other option to use a hub motor to deliver power,that will eliminate most of the complexities,but i am not sure whether a hub motor is capable of withstanding minor shocks,and bending stresses.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov15-12, 04:34 PM   #2
Recognitions:
Gold Membership Gold Member
I am not a Mechanical Engineer but I think you would need to specify a few values before you can expect an answer. So far the answer must be "It depends", I think.
Nov16-12, 12:44 AM   #3
Recognitions:
Homework Helper Homework Help
The range of motion for your application is pretty large. Universal joints are best used when the range of motion is only a few degrees; with larger angles, they can freeze up and they will experience higher wear and shorter life than a comparable CV joint.
New Reply
Thread Tools
Similar Threads for: constant velocity joints vs. universal joint.
Thread Forum Replies
Gruebler's Equation on 3 Universal joints 3 prismatic joints dof calculated 0 ? Mechanical Engineering 0
Universal Gas constant R Biology, Chemistry & Other Homework 1
Universal joint/ball bearing.... controlled rotating arm for a furniture fitting Mechanical Engineering 6
Is there really a universal constant? General Discussion 20
A universal constant? Chemistry 9
