| New Reply |
Power loss due to ionisation of air from magnetic fields |
Share Thread |
| Feb4-13, 07:39 AM | #1 |
Hi,
A current carrying wire creates a magnetic field around it, as shown here: http://courses.ae.utexas.edu/ase463q...et/3_sour8.gif As far as I am aware this usually doesn’t cause a power loss. Even if there is a flux on a nearby conductor there will be no power loss along the wire unless that flux is changing, in which case a emf will be induced on that conductor, meaning there has to be a power loss on the first wire. Correct? However, if a wire has a current that causes a magnetic field so strong it ionises the air around it, surely this will cause a power loss? as work has been done ionising the atoms. Also, if a different magnet is put into the magnetic field caused by the wire, it will feel a force on it, and accelerate in the direction of the force, so work is being done here as well. What I'm basically trying to ask is that if there is a current carrying wire with zero resistance, will it still have loss's due to the fact that it creates a magnetic field? Thanks |
| Feb4-13, 10:02 AM | #2 |
It is the Electric Filed (high voltage) that typically ionizes the air, and this does yield some looses in high voltage systems. I have not heard of a magnetic field causing ionization.
In high voltage systems this un-wanted ionization is called corona - and leads to a lot of problems, so the mechanical design of the systems tries to minimize the development of the corona. |
| New Reply |
| Tags |
| carrying, current, loss's, magnetic, wire |
Similar Threads for: Power loss due to ionisation of air from magnetic fields
| Thread | Forum | Replies | ||
| Ionisation by a magnetic field? | General Physics | 7 | ||
| Looking for a description of power loss in Latex tubing work in/power out | General Physics | 1 | ||
| Power loss in sinusoidal electric fields | Advanced Physics Homework | 2 | ||
| Magnetic fields from power lines | Introductory Physics Homework | 1 | ||
| Magnetic fields inducing electric fields - turning on lightbulb with magnetic field | Introductory Physics Homework | 3 | ||
